Brians F/R Locked Long Travel Camping and Overland Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Brian422, May 17, 2019.
  1. Aug 16, 2020 at 7:35 PM
    #421
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Did you get the gear oil in it yet?
  2. Aug 16, 2020 at 7:47 PM
    #422
    Brian422
    Brian422 [OP] I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    No, I need to order some drain plug gaskets, but it wasn’t having any issues before?
  3. Aug 16, 2020 at 8:08 PM
    #423
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Brian422[OP] likes this.
  4. Aug 20, 2020 at 6:20 AM
    #424
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    so went on a ride around the yard last night. Finally got everything running again. @jowybyo did you have any noises when you did your first ride? Im getting a noticeably loud rubber like sound(similar to the sound your tires make on smooth garage floor) at full lock. Im thinking its my cv boots rubbing together but im not sure.
  5. Aug 20, 2020 at 6:29 AM
    #425
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Hmmm. I don't remember anything. Your explanation sounds reasonable. Spray a little silicone lube on the boots and try again.
    Brian422[QUOTED][OP] likes this.
  6. Aug 20, 2020 at 6:33 AM
    #426
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I will. Do you have the RST add harness by chance?
    cubie likes this.
  7. Aug 20, 2020 at 7:26 AM
    #427
    jowybyo
    Joe
    Baltimore, MD
    No. But I basically wired up the same thing.
    cubie and Brian422[QUOTED][OP] like this.
  8. Aug 20, 2020 at 7:32 AM
    #428
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I had to take mine apart to get the wires in the truck and im not sure everything was put back right. They send them with some numbers that easy fall off:confused:
    cubie likes this.
  9. Aug 20, 2020 at 7:46 AM
    #429
    jowybyo
    Joe
    Baltimore, MD
    Do they supply a wiring diagram?
    cubie likes this.
  10. Aug 20, 2020 at 7:49 AM
    #430
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    Brian you’re like 97% done with this conversion. Sooooo close!
    BassAckwards likes this.
  11. Aug 20, 2020 at 7:52 AM
    #431
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    no :( just numbers on each wire that match up with numbers on switch. I should have taken a pic but i didn't. I emailed them but they are dick slow at emailing back like 5 days slow.
  12. Aug 20, 2020 at 7:55 AM
    #432
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Yea still got some stuff to handle though. I still dont like my shifter. Maybe if i bring the truck over to @BamaTaco56 he can make something a little better than what i have. I just needed something to get it out of the garage.
    cubie[QUOTED] likes this.
  13. Aug 20, 2020 at 8:05 AM
    #433
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Did you wire up cluster for 4x4 lights?
  14. Aug 20, 2020 at 8:07 AM
    #434
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    not yet.
  15. Aug 20, 2020 at 8:10 AM
    #435
    IvanhoeTaco
    Eastern NC
    It's very easy, although you have to get your own pins for the cluster connector.
  16. Aug 20, 2020 at 8:10 AM
    #436
    jowybyo
    Joe
    Baltimore, MD
  17. Aug 20, 2020 at 8:11 AM
    #437
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    yep i know, i just got other stuff to fine tune before that. You have a place to get pins?
  18. Aug 20, 2020 at 8:12 AM
    #438
    IvanhoeTaco
    Eastern NC
    I work at a Honda shop so we have like 9000 harnesses laying around. I actually pulled the pins from a lexus harness.
  19. Aug 20, 2020 at 8:17 AM
    #439
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    cubie likes this.
  20. Aug 20, 2020 at 8:18 AM
    #440
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    dang really dont want to have to go to a junk yard for a pin connector lol
    cubie likes this.
