Brians F/R Locked Long Travel Camping and Overland Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Brian422, May 17, 2019.
  1. Jan 24, 2021 at 5:46 PM
    #661
    Brian422
    Brian422 [OP] I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    you should come get it..... and come wheel lol
    TacoFMS[QUOTED] likes this.
  2. Jan 25, 2021 at 2:59 AM
    #662
    gixxerphil
    gixxerphil @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Keep me informed. I planned to head back out there the end of Sept. I'll take 2 weeks off and have 20 days to dick around.
  3. Jan 25, 2021 at 4:50 AM
    #663
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    If only...
  4. Jan 26, 2021 at 5:44 PM
    #664
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    amazing build. i found your truck because someone linked to this tread and your writeup about 4x4 conversion in a thread I started here: https://www.tacomaworld.com/threads/wwyd-the-old-sell-trade-in-prerunner-for-4wd-predicament.705104/
    curious to know your thoughts on my dilemma. I'm on the fence because I'm not super mechanically inclined. i think i can be patient in sourcing the parts, but that's about it. i wonder if anyone in southwest region does these installations if i were to source all the parts? gotta think long and hard about this.
    Brian422[OP] likes this.
  5. Jan 26, 2021 at 6:36 PM
    #665
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I was in the exact same boat man. I started out with a rear locker and then realized I needed more traction. Truck was paid off and only had 109k. I researched TW for like a year and then when I felt comfortable with my knowledge I sourced the parts. I put the guid together to make it easier for people. So you could have everything you needed in one place. I had to look all over the place and get part numbers and stuff.
    it’s really not that bad. If you can put on a lift you can do the conversion. It’s 90% bolt on. The only modifications is the crossmember to the frame and if you want your shifter for the tcase to come up in the coin slot for a clean look. I would strongly recommend doing the conversion since it sounds like you have a lot already invested. It brings a huge amount of satisfaction when your done. I’ve put about 5k on my truck and wheeled it pretty hard since and everything is perfect. Factory like.
  6. Jan 26, 2021 at 6:53 PM
    #666
    dirtnsmores
    Southern California
    06 DCLB Prerunner
    thanks so much for the response. I think i'm going to start exploring this idea more and possibly go this route. did you lose any safety features by doing this? this will be our family hauler as well.
  7. Jan 26, 2021 at 7:10 PM
    #667
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Nope all is the same as before. Just added front diff t-case and cv. I even was able to make the dash lights for 4x4 work. Your dash cluster is prewired for the lights.
    ovrlndkull likes this.
  8. Jan 29, 2021 at 12:32 PM
    #668
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Welp in for one of @Arcticelf shock relocation kits and bought some fox 2.0 RR with adjustors 12 inch shocks to go along with it:thumbsup:.
    Might finally have a completed rear suspension. Just need need brake lines now.
    Arcticelf, whatstcp and ovrlndkull like this.
  9. Jan 29, 2021 at 12:34 PM
    #669
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Call Crown they'll get you right with whatever length you want.
    Brian422[QUOTED][OP] likes this.
  10. Jan 29, 2021 at 12:37 PM
    #670
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Thinking of just doing +4 plus the mod that @EatSleepTacos did with the 1 inch spacer.
  11. Jan 29, 2021 at 12:47 PM
    #671
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yeah you could do that or just order the correct size you need and not have a secondary part to get the extra length :rofl:
    I literally called them told the what I had and what I wanted and only ordered enough to do the rear. It isn't on their website but in sets of 4. If you call you can just order the rears. Mine are like 30" or something like that. +4 is like 28 iirc
    TacoFMS and Brian422[QUOTED][OP] like this.
  12. Jan 29, 2021 at 12:49 PM
    #672
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    LOL, just buy some plus 5 then?
    ovrlndkull[QUOTED] likes this.
  13. Jan 29, 2021 at 12:51 PM
    #673
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    @ovrlndkull Maybe the kit will be in by 18th and we could install at place then go wheel it lol
  14. Jan 29, 2021 at 1:12 PM
    #674
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Yes i will get full droop, hes making mine almost same height as archive kit. I have Dakar HD i think can only droop 12 inches anyways. Ive got the best setup for the droop with the archive shackle hangers and the poly bushings.
    whatstcp[QUOTED] likes this.
  15. Jan 29, 2021 at 1:13 PM
    #675
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    thinking of actually adding a limit strap.
    whatstcp likes this.
  16. Jan 29, 2021 at 1:19 PM
    #676
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Every time i read this thread i get the urge to convert my truck to 4wd. Your write up just makes it look simple
    whatstcp and Brian422[OP] like this.
  17. Jan 29, 2021 at 1:21 PM
    #677
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    :boink:Give me an excuse to drive to texas lol
  18. Jan 29, 2021 at 1:44 PM
    #678
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Maybe mine were 32" I completely forgot. I remember reading a bunch of the LT guys lengths and got something a little shorter.
    I'd be down. I may be doing rear brakes in your driveway if I don't get them done before then :rofl:
  19. Jan 29, 2021 at 1:51 PM
    #679
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Lol drums are a pain in the ass. I busted mine right before our wind rock trip and said fuck it and took it to the dealership which all things considered wasnt that outrageous haha. Plus i had no time to fix before trip so i kind of had no option.
  20. Jan 29, 2021 at 1:55 PM
    #680
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Eh they aren't bad. I've done so many I can do them pretty easily. I blew my wheel cyl at windrock on trail 15 pinched the line off got off the trail and had it repaired the next morning in less than an hr.
