Brians F/R Locked Long Travel Camping and Overland Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Brian422, May 17, 2019.
  1. Feb 10, 2021 at 7:31 AM
    #721
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    No. I meant engaged. With an open diff you only get torque to one wheel, which ever wheel has the least traction.
  2. Feb 10, 2021 at 7:33 AM
    #722
    Brian422
    Brian422 [OP] I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    so the other front wheel dosent spin at all in any situation if your in open 4wd? Ive seen mine spin in air when open before
  3. Feb 10, 2021 at 7:37 AM
    #723
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    In this vid i only locked for a sec and then unlocked it again when i got over the hump. Wheel spins in 4lo unlocked
    https://youtu.be/w3aCvHU2bT8
  4. Feb 10, 2021 at 7:53 AM
    #724
    jowybyo
    Joe
    Baltimore, MD
    The other wheel obviously turns if it’s on the ground and you are moving. But if you are stuck with one wheel is on the ground and the other is in the air, the on in the air is the one that will be mostly likely to spin. You can “trick” it a bit by holding the brake.
    Brian422[OP] likes this.
  5. Feb 10, 2021 at 7:56 AM
    #725
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Ok thats what i was getting at if on flat ground and i engage 4wd with ADD all 4 will spin at 25% split between wheels lol. I was saying if ADD is off on flat ground and you engage Tcase then only front left wheel will spin. I set my drive train up on the floor and saw this happen when i turned by hand. also feels like it when i did it one time. When you engage the ADD the right wheel will spin too.
  6. Feb 10, 2021 at 8:29 AM
    #726
    jowybyo
    Joe
    Baltimore, MD
    This ^^^^^
  7. Feb 10, 2021 at 8:30 AM
    #727
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    I’m understanding a bit better. So what happens if the front locker is on but ADD is off? Will the same thing happen?
  8. Feb 10, 2021 at 8:35 AM
    #728
    jowybyo
    Joe
    Baltimore, MD
    You get 3-wheel drive, where the driver side front wheel is the only one that gets power.
    pdaddy[QUOTED] and whatstcp like this.
  9. Feb 10, 2021 at 8:36 AM
    #729
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Im confused lol. But ive driven on flat ground before with the add disconnected in 4lo and had 3 wheel drive. Thats all i know lol.
    whatstcp[QUOTED] likes this.
  10. Feb 10, 2021 at 8:44 AM
    #730
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    no
  11. Feb 10, 2021 at 8:47 AM
    #731
    jowybyo
    Joe
    Baltimore, MD
    What makes you so sure? I can't tell what wheels are getting torque when I'm just driving along on flat ground. It's not until I'm stuck or in mud that I notice which ones are doing work.
    Brian422[QUOTED][OP] likes this.
  12. Feb 10, 2021 at 8:49 AM
    #732
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Wheel spun on wet pavement.
    whatstcp likes this.
  13. Feb 10, 2021 at 8:52 AM
    #733
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    IDK maybe add got engaged somehow without me knowing because my add light stopped working but it still engages lol.
  14. Feb 10, 2021 at 8:52 AM
    #734
    jowybyo
    Joe
    Baltimore, MD
    Idk man. I know for sure if I don't engage the ADD, I'm only doing donuts with the rear wheels (only one rear wheel until I hit the locker).
  15. Feb 10, 2021 at 8:54 AM
    #735
    jowybyo
    Joe
    Baltimore, MD
    Try it again sometime and report back to us. If you are getting power to the front wheels with the ADD disengaged that would be really interesting.
  16. Feb 10, 2021 at 8:56 AM
    #736
    jowybyo
    Joe
    Baltimore, MD
    If you're really feeling crazy, disconnect the rear driveshaft at the t-case. Then see if you can move at all without engaging the ADD.
  17. Feb 10, 2021 at 8:57 AM
    #737
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I like how you think lol.
    But yea idk man maybe since the wheels were drooped it had an effect on them.
  18. Feb 10, 2021 at 8:58 AM
    #738
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I was thinking of doing that but too much work lol
    jowybyo[QUOTED] likes this.
  19. Feb 10, 2021 at 9:10 AM
    #739
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Ive got to replace my steering rack bushings soon.... Thats going to be a pain in the ass.
  20. Feb 10, 2021 at 9:41 AM
    #740
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Im thinking of buying a new rack altogether. People say the energy bushings suck if you actually wheel your truck. Buddy says hes replaced his like 3 times in the span of a year because they cant take the abuse. There's no where to get just OEM bushings.
