Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Aug 24, 2016 at 8:07 PM
    #261
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Oh..huh I'll have to check that out tomorrow. If I can get away with what I have then I think I'll do alright. I've run the truck a few times now with now oil leaks from the turbo, let's hope it stays that way.
  2. Aug 24, 2016 at 8:38 PM
    #262
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    It leaks into your intake. Where the blades are. Basically it pools in your bearing and slowly seeps into our intake. Some like a small clock so there is some undrained oil in the bearing to keep it lubricated after sitting around for a while but you don't want the angle too extreme.
  3. Aug 25, 2016 at 5:09 PM
    #263
    Brice
    Brice
    Texas
    Well, to whoever said install the wastegate BEFORE installing the header...I'm so sorry I didn't listen to you...welp time to take off the starter, turbo and crossover V Band to get to the WG. :facepalm:
    SO in case anyone missed it, INSTALL THE WASTEGATE BEFORE INSTALLING THE TURBO HEADER
    because_wumbo-truck likes this.
  4. Aug 25, 2016 at 5:38 PM
    #264
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    NO!!
    NO!!
    NO!!
    You can't get the headers on with the WG and dump pipe. You might be able to do it with the WG installed, I can't remember, but I know for a fact, the dump pipe has to go on after the headers are in place. Its a major PITA!
  5. Aug 25, 2016 at 5:55 PM
    #265
    Brice
    Brice
    Texas
    oops. I fixed it. But im pretty sure to have things go smoothly you should install atleast the WG, this I know because its nearly impossible to tighten the wastegate bolts if you don't.
  6. Aug 25, 2016 at 6:18 PM
    #266
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I seem to remember putting the WG on after the header was on. No, its not easy.
  7. Aug 25, 2016 at 6:27 PM
    #267
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    What makes it not easy?
  8. Aug 25, 2016 at 6:38 PM
    #268
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Just hard to get a good angle on the bolts. It's been a while since I've installed and I try to forget those hours cursing at my truck 3am in the morning.
    Brice[OP] likes this.
  9. Aug 25, 2016 at 7:39 PM
    #269
    Brice
    Brice
    Texas
    Same here.
    Just got it on with no leaks!:yay: Definitely if you can, put the wastegate on before mounting the header. Don't install the dump pipe till after you install the header, and for auto owners, you'll have to maneuver the fill tube around the dumpipe, no big deal as long as you do it in that order. Truck sounds nice and deep with that Pro series muffler. Ill try and have a exhaust note up tomorrow after I get the IC and vacuum piping finished. Things almost ready for a test drive! sorry for the lack of pics, I'll get some up tomorrow as well.
  10. Aug 26, 2016 at 11:55 AM
    #270
    Brice
    Brice
    Texas
    Slight issue. I have the truck fully put back IC piping and all, but thee truck just won't start. It'll crank up and rev to 1500 rpm then cut power and drop till it dies (all within about 3 seconds) Anyone else have this sorta issue?
    @StAndrew
    @GioGuitarDude
    @vasinvictor
    Plz halp
  11. Aug 26, 2016 at 11:57 AM
    #271
    Aw9d
    Aw9d That one guy
    Painting the turbo red was a good choice! I dig it.
  12. Aug 26, 2016 at 12:03 PM
    #272
    Brice
    Brice
    Texas
    Thanks!
  13. Aug 26, 2016 at 12:24 PM
    #273
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Post a video
  14. Aug 26, 2016 at 12:41 PM
    #274
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    MAF sensor installed/conected? O2 sensor?
  15. Aug 26, 2016 at 1:01 PM
    #275
    Brice
    Brice
    Texas
    All installed and connected:notsure:
  16. Aug 26, 2016 at 1:37 PM
    #276
    Brice
    Brice
    Texas
  17. Aug 26, 2016 at 1:40 PM
    #277
    Rod03
    Rod03 Well-Known Member
    14 DCSB OR 300k+ Miles DD
    22 T4R OR, 12 TX Pro, 21 Taco Skewp!, 02 Taco OR (All Sold)
    that happened to me on my 2nd gen when I did the install on my CAI, it will start the rpm's will go up a bit and shut off. it was the sensor that goes on the tube it was upside down so it wasn't reading it correctly. the way the bolts are on it I have to removed the base and turned it around.
  18. Aug 26, 2016 at 3:10 PM
    #278
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Did you check all your vac hoses?
    Good news is I'm pretty sure this looks like user error, in that I don't think anything is broken. Just need to figure out what you forgot to do. Put up a pic/vid of the engine bay.
  19. Aug 26, 2016 at 3:33 PM
    #279
    Brice
    Brice
    Texas
    Well there are 2 open ports on the manifold that would be a vacuum leak, after plugging them, no luck. I checked the wiring harness and all grounds seem to be in order, I even swapped out my MAF for the spare I have and nothing... People on another forum were saying that replacing their "ignitor" fixed the issue. I know what ignition coils are and as far as I know they're all good... What and where is the ignitor? I assume it drives the coils or something? Is it the thing you stick your key into? Fuel pump works as the system will still prime at the ACC position on the ignition, Injectors work as the thing still starts, and so does spark. Something ECU side isn't right and now its just a matter of figuring out what
  20. Aug 26, 2016 at 4:21 PM
    #280
    devinzz1
    devin
    2023 aclb trd or mt
    The fact it starts says alot. Can you keep it going by giving it throttle at all?
