Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Sep 2, 2016 at 5:51 AM
    #361
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How vertical is the center cartridge? For oil feed and drain.
  2. Sep 2, 2016 at 6:38 AM
    #362
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    If it's isolated then it's totally fine and this is the typical solution for pcv. I was just trying to get more input from people whom have been running turbo for a while here on there setups and if any of them had tried anything different. If I can come up with anything legitimate I'll post it here.
  3. Sep 2, 2016 at 7:04 AM
    #363
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Maybe 10 degrees off vertical to the left if you're looking at it form the front.
  4. Sep 2, 2016 at 7:22 AM
    #364
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ok, good.
  5. Sep 2, 2016 at 7:29 AM
    #365
    Brice
    Brice
    Texas
    Yeah so nothing crazy. It was like 30 off before I cut the flange, which I'm sure was also contributing. Of course if I had a bigger/different turbo I could get it straight up and down...but hey the cheap one hasn't broken yet!
  6. Sep 2, 2016 at 10:00 AM
    #366
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    How far off is too far?
  7. Sep 2, 2016 at 10:29 AM
    #367
    Brice
    Brice
    Texas
    I'd say 30 degrees or more past 180 vertically.
    Edit: that wasn't from anything it's just what worked for me.
  8. Sep 2, 2016 at 11:05 AM
    #368
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I would have to look at Borg Warner's instructions again, but it gave a specfic number. I don't want to say without checking again. It wasn't much.
  9. Sep 2, 2016 at 12:51 PM
    #369
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Is the issue pooling oil or drain restrictions? Or is it a bit of both? Mine is sitting at near 30 degrees but my drain line is a damn near perfect shot to the pan.
  10. Sep 2, 2016 at 1:05 PM
    #370
    Brice
    Brice
    Texas
    In my case, with a smallish turbo, pooling is caused by drain issues. Smaller turbos have a smaller drain therefore drain slower, in turn causing your oil to pool. A fix is to get a smaller restrictor or make the center section more upright. Don't worry to much on having a restrictor that's too small, the 5VZ makes tons of oil pressure. I believe it was 4 psi at idle and 75 psi at 3000 rpm, in other words It'll shove enough oil through anything. (obviously it's a good idea to not go smaller than the recommended restrictor size for your turbo)
  11. Sep 2, 2016 at 5:18 PM
    #371
    Brice
    Brice
    Texas
    Converted to pre-turbo maf today. @Blackdawg. Overall idle is ok but I still need to move the primary o2 sensor. Before idle was 14.5-16.0 but it is now 14.3-15.5 which is slightly better. Also before the AFR wouldnt drop till boost, now with the MAF being able to intercept and process the air better (atleast thats how I understand it) it begins to get rich as soon as it leaves idle.
    New 3" to 4" adapter.
    Goodbye nice AFE filter :(
    How it sits on the turbo.
    Blackdawg likes this.
  12. Sep 3, 2016 at 4:02 PM
    #372
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
  13. Sep 3, 2016 at 7:59 PM
    #373
    Brice
    Brice
    Texas
    Hm good question. I'm only oil cooling atm. Model T's ran exclusively off the siphoning technique.
  14. Sep 3, 2016 at 11:21 PM
    #374
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Does your turbo have coolant ports? If so you'll definitely want to set them up.
  15. Sep 3, 2016 at 11:28 PM
    #375
    Brice
    Brice
    Texas
    Yeah it does, and eventually I will. Garret will stress the importance of water cooling more so than the engineers to cover their butts if something breaks. Plus I have ceramic bearings which can withstand alot more heat than other types of bearings, so I should be ok for now, that and I have an oil cooler between the block and the turbo.
  16. Sep 4, 2016 at 6:51 AM
    #376
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    You'll want to do that sooner than later. Its actually pretty easy. On your TB there are coolant lines that are used to heat it up to keep it from icing over in cold weather states. They can be safely removed if you live in Texas (a lot of people do this to keep air intake temps low as these can heat up your intake air), and new water lines re-routed to your turbo instead. I kept the water flowing to the TB but re-routed the water feed to the turbo, and from the turbo to the TB feed, keeping the TB water return lines stock.
    The coolant connections are on the block way in the back towards the firewall and are a little difficult to reach.
    It does more than just keep the turbo cool. It keeps the oil from baking on the bearings especially when you turn it off after a hard run, with no more oil feed to cool and coat it with fresh oil, the remaining oil coating in the bearing housing can get baked in the bearing housing. It also isolated the heat on the hot side of the turbo from soaking into your intake side. But even with the water lines, always be sure that after driving around a little, let the engine idle a 10-15 seconds before shutting it off to let the turbo cool.
  17. Sep 4, 2016 at 7:26 AM
    #377
    Brice
    Brice
    Texas
    Ok cool so just use the throttle body lines. Now it's just a matter of finding hardware
  18. Sep 4, 2016 at 1:25 PM
    #378
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    @StAndrew Do you happen to know which of the TB lines is the cool line? Don't know if you read through that article I posted but if you have your turbo clocked at the optimal 20 degrees and have you lines backwards your looking at a peak temp difference of almost 100 degrees F in the center housing which is roughly 20% more heat.
    Did you also ever figure out why your brake booster wasn't working with the check valve in place? Were you using a true check valve or a pcv valve?
  19. Sep 4, 2016 at 5:39 PM
    #379
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I wouldnt worry about dialing in your angle at 8-10psi of boost. On the TB, you can see the two lines going in and coming out pretty easy. I kind of misspoke, its actually your IAC that has the water lines. In the picture below, the j shaped fitting on the top is actually on the bottom when installed and faces your firewall IIRC. The two other fittings splayed out like a "T" are the water lines.
    Maybe I had a cheap one way valve but basically it reduced the vacuum the break booster was seeing. I didn't have it in backwards, it just was very restrictive. I'm not saying don't put on in, just beware and test your brakes if you do. Also, as I stated, your brake booster already has a one way valve built in.
  20. Sep 4, 2016 at 5:42 PM
    #380
    Brice
    Brice
    Texas
    My brake line was touching the downpipe which caused the fluid to boil and the pedal to become stiff, I believe that same brake line is on all first gen but Idk. Moving that freed everything up.
