Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Sep 8, 2016 at 9:28 PM
    #501
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Potential price difference, idk haven't checked haha
    gray223[QUOTED] likes this.
  2. Sep 9, 2016 at 9:34 AM
    #502
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Get the full Old Man Emu lift kit. It's $1000 and it's the best all around kit available. Comes with new shocks all around, new coils in the front and a new leaf pack in the rear. Gives 2.5" of lift which is really right where you want to be to not break every other part of your truck when you actually want to wheel it.
    Cool overs for the stock front are a total waste IMO. The only advantage they have over the bilstein or OME front shocks are the adjust collars so you can adjust anywhere between 0-3" instead of setting it at 0, 1 or 2.5" in the case of bilstein.
    A true coil over that will actually yield a higher level of performance is going to be a 2.5" body, reservoir, 8" travel which are the shocks used on most bolt on long travel kits. The "coil overs" they sell as OEM replacement lift kits are a total scam. They are the same size shock as the bilstein. Shock performance is largely proportional to its actual size or more specifically the amount of oil it can hold. A larger diameter shock or a reservoir shock is going to perform better than a smaller non res shock.
    They are nice granted but not $1500 just for a set of tiny coil overs nice.
  3. Sep 9, 2016 at 9:40 AM
    #503
    Brice
    Brice
    Texas
    Yeah I think you're right. I myself probably won't utilize $2500 worth of suspension...lemme look into that OME kit
  4. Sep 9, 2016 at 10:07 AM
    #504
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    How full is your catch can and how many miles so far?
    And did you get a nice can with baffles and stuff? I ordered one for $20 and it's just a hollow can so I put some tubing and a stainless steel pot scrubber in it..
  5. Sep 9, 2016 at 10:07 AM
    #505
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I think you need to do more research, even the stock replacement coilovers from King, ADS, SAW, and Icon have 2.5" bores with the availability to have reserviors. They ride so much better than the Billies it's not even funny. Valving is so important, properly valved coilovers will out ride any set of billies or OME. Also you can get extended travel stock replacement coilovers that net you another inch of down travel. Fox is the only company that makes a 2.0 coilover for the front and you're right those aren't worth the money. OME shocks paired with their brand of springs are the next best thing if you're not doing coilovers. Just don't do billies and eibachs, I want to save someone else from the harshness, I cannot wait to put my Icons in.
    Brice[OP] likes this.
  6. Sep 9, 2016 at 10:14 AM
    #506
    Bxnanaz
    Bxnanaz Well-Known Member
    2021 Tacoma TRDOR 6MT
    Not a suspension expert by any means, but I will say my front and rear Bilsteins are rough riding.
  7. Sep 9, 2016 at 10:32 AM
    #507
    Brice
    Brice
    Texas
    It has a baffle with mesh, so not super good or super low quality. And no oil or anything just some condensation. I figured out that I'm only on 2psi atm because my WG is hooked up pre IC so I gotta fix that...otherwise the thing runs good and is faster than before :thumbsup:
    Edit: like 110 miles
  8. Sep 9, 2016 at 12:40 PM
    #508
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    K go ahead and drop 2k for a set of those "coil overs" and tell yourself how worth the $$ it is. Go ahead and put "extended travel" replacement coil overs on your stock suspension and tell yourself you're getting more travel. Yeah, valving is important, got me there. Obviously Fox, King, etc are going to out perform bilsteins, apples to oranges. 2.5" body with reservoirs? Cool, you're still on stock A-arms with what, 6" travel? I'll stick with my $150 Bilsteins.
    I digress, my point is you may as well go LT if you're going to buy legit coil overs since to utilize them you're going to have to upgrade so many other components of the stock suspension. Alternative? Stick with a low end shock which is still better than stock and start saving for LT. What do they charge for these "mid travel" front kits? $3,000-$3500? Lol, no.
  9. Sep 9, 2016 at 12:47 PM
    #509
    Speedytech7
    I've already got a low end shock, it blows. I've ridden in and wheeled with people that have properly set up coilover rides and it's a dream. Also you get more than 6" of travel, I'd really suggest you go and actually do some research instead of blindly fighting something you clearly don't understand. You don't use stock upper arms, they are the limiting travel factor for 1st gens. Is money the only thing your hung up on, it's just money, can't take it with you. Plus your cost figures are massively off anyway. :rofl:
    I'm not trying to pick a fight with you, you're just not right.
    gray223 likes this.
  10. Sep 9, 2016 at 12:53 PM
    #510
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Think you ma have some things switched up. Do some more research.
  11. Sep 9, 2016 at 12:54 PM
    #511
    Brice
    Brice
    Texas
    This OME kit? If this is the one you are talking about then what spring would I choose? I did some math and it'll take around three months to save up for this. Im totally not against a LT setup or MT setup, but money is something that will take a while for me, and I don't wanna spend 6 months saving for this stuff. If this OME kit falls between billies and kings then it sounds good to me.
    Speedytech7 and gray223 like this.
  12. Sep 9, 2016 at 12:58 PM
    #512
    Speedytech7
    The OME kit is definitely a happy medium to get ya on the trail. Call Down South Motorsports and one of the guys there can recommend the right spring for the front based on your weight and proposed height. They are great guys and super knowledgeable.
  13. Sep 9, 2016 at 1:01 PM
    #513
    gray223
    SE Missouri
    2014 Tundra Limited
    Think you will be happy with that setup. Call downsouthmotorsports like speedytech said too
    Speedytech7 likes this.
  14. Sep 9, 2016 at 1:06 PM
    #514
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Ext. Travel co and ucs is around 2k. Lt will cost you over double. Even more if your a 4x4.
    Not everyone can use a wide ass lt setup or wants glass fenders. a decent mid travel setup will put 5100s to shame while lasting longer.
  15. Sep 9, 2016 at 1:11 PM
    #515
    Brice
    Brice
    Texas
    Will do! Thanks guys.
  16. Sep 9, 2016 at 1:19 PM
    #516
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Don't need a new leaf pack. Mine were terrible and the AAL perked them right up.
  17. Sep 9, 2016 at 1:20 PM
    #517
    Brice
    Brice
    Texas
    They didn't sag?
  18. Sep 9, 2016 at 1:21 PM
    #518
    devinzz1
    devin
    2023 aclb trd or mt
    This truck have an open diff?
  19. Sep 9, 2016 at 1:22 PM
    #519
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Mine were frowny. I just hauled a bed of tile and the bumps rode on the frame for most of the trip. Never recovered after that. Put in an AAL and they were happy after :D
  20. Sep 9, 2016 at 1:24 PM
    #520
    Brice
    Brice
    Texas
    For now yes
