Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Sep 9, 2016 at 1:24 PM
    #521
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    I found with the aal i was still getting quite a bit of axle wrap and wheel hop. Full pack took care of that.
  2. Sep 9, 2016 at 1:25 PM
    #522
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Huh well I may give that a shot :D
  3. Sep 9, 2016 at 1:27 PM
    #523
    devinzz1
    devin
    2023 aclb trd or mt
    That needs to change asap. Thing will be spinning for miles.
    Plus no matter how good a burnout it is its just dissapointing when its just a one tire fire :facepalm:
    Brice[QUOTED][OP] likes this.
  4. Sep 9, 2016 at 1:30 PM
    #524
    Brice
    Brice
    Texas
    Haha agreed. I just need to figure out what I'm doin first. Lift or locker...hmm
    and all the other stuff lol...I'd like to get the lift out of the way first since it would be the biggest bite outta my pocket, gone.
  5. Sep 9, 2016 at 1:38 PM
    #525
    devinzz1
    devin
    2023 aclb trd or mt
    Going with bigger tires?
    If so then its just aswell to wait then and regear while your at it.
  6. Sep 9, 2016 at 1:56 PM
    #526
    Brice
    Brice
    Texas
    Yeah 255/85r16 Cooper discoverer st maxx, so like 33's. But I have a factory ratio of 4.10:1. would that be enough?
  7. Sep 9, 2016 at 2:01 PM
    #527
    devinzz1
    devin
    2023 aclb trd or mt
    Id go 4.56s personally. I mean. You spent the money to make it that much faster then your gona put 33s on it. To put in a posi/locker its gona take up most of the costs to install gears anyways
  8. Sep 9, 2016 at 2:08 PM
    #528
    Brice
    Brice
    Texas
    Well it's not like I can't regear later if need be... I think I'll go Lift>Locker>Regear
  9. Sep 9, 2016 at 2:36 PM
    #529
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Most 2nd gen guys are running 255/85s on stock 3.73s (myself included) just sayin and ur a lot lighter and a little more power, i guess ud be fine
  10. Sep 9, 2016 at 2:38 PM
    #530
    Brice
    Brice
    Texas
    Kinda what I was thinking, and I see stock 3.4 guys running 33's no problem, but we'll see
  11. Sep 9, 2016 at 2:41 PM
    #531
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I didn't have any issue with my AAL but it was pretty thick, 1.5" lift IIRC. I ran it for 2 years but it was so stiff, I eventually got some OME leafs which ride much better. Funny enough, I get some wrap with the OME.
    I'm still running stock 4.1 gears on my 33's and I'm running 285 re-treads which weigh a ton. 4.1 is just fine but 4.56 and 4.88 have more fun factor.
  12. Sep 9, 2016 at 2:42 PM
    #532
    devinzz1
    devin
    2023 aclb trd or mt
    im only on 32s and i can tell you its a major difference. things a pig now...
  13. Sep 9, 2016 at 2:43 PM
    #533
    Brice
    Brice
    Texas
    What's your factory ratio?
  14. Sep 9, 2016 at 2:48 PM
    #534
    devinzz1
    devin
    2023 aclb trd or mt
    3.91. Id never want to go bigger than 32s with it. Within a few percent difference from 33s and 4.10s.
  15. Sep 9, 2016 at 2:53 PM
    #535
    Brice
    Brice
    Texas
    Huh I guess 4.5psi, 33's and 4.10's will feel like stock then haha
  16. Sep 9, 2016 at 3:28 PM
    #536
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Maybe learn to drive within your vehicles limits than blame the hardware :notsure:. And lol at that closing statement, nice job dude :thumbsup:. I can't wait til you actually put on those coilovers you so adamantly defend while not having any real experience with other than through you pals truck you've never actually driven. Do some "research" yourself ;).
  17. Sep 9, 2016 at 3:37 PM
    #537
    Brice
    Brice
    Texas
    If ya'll wanna fight/discuss this further go do it in PM's otherwise I could care less about your disagreement. From what I can tell? MT & LT are far better than stock. Billies are a step up from stock and OME is a step above billies. Am I wrong? I dunno probably I ain't got a clue about suspension, but that's why I'm here, To learn. And I haven't made any concrete decisions either as I'm still researching.
    Bxnanaz likes this.
  18. Sep 9, 2016 at 3:38 PM
    #538
    Bxnanaz
    Bxnanaz Well-Known Member
    2021 Tacoma TRDOR 6MT
    Exactly, quit bitching at each other online
  19. Sep 9, 2016 at 3:44 PM
    #539
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    I would run 32" or 365/75/16's. I run beefy mud 32's and they are pretty cumbersome. 265's will be like 1/2" shorter. 33" tires are quite an investment, you'll need a big lift, largely offset wheels and you'll still have some clearance issues not to mention all of these things are going to wear out your truck at a faster rate. 4.56's are a waste of money, regears are very expensive and 4.56 is barely shorter than 4.10. That said 4.56 would feel just about right with 33".
    That lift you linked is the one I was referring to, seems a little pricey-er than I recall. The different coils have varying lengths and spring rates. A longer coil will give you more pre-load for a heavier bumper, etc, and a higher spring rate will be stiffer ride (essentially sacrificing low speed stability for high speed stability, or low impact vs high impact). It comes with a new rear leaf pack as well which is pretty highly rated by everyone. Aside from being a great lift that doesn't affect your trucks longevity, it's also very affordable.
    I run bilstein 5100's with stock coils and I couldn't be happier. The only thing that gets to me is the shock fade after a long term trouncing which is what a bigger shock (more oil volume) gets you away from and hence my rant on that. I have All Pro Offroad's 3" standard leafs in my rear and I can't really say much for them. They seem very stiff and can't keep up with my front end when I'm really on it. Likely build to hold a bed full of equip.
  20. Sep 9, 2016 at 3:53 PM
    #540
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Theres a lot of debate over OME vs Bilstein front coilovers but I would say they are on the same plane. Still advise against anything labeled "mid travel." If you can get a set of uniball UCA's second hand for around half the cost (~$400) I'd say jump on it but those UCA's can be paired with most any coilover, billy's included, and you'll be in that pseudo "mid travel" bracket which is like 1.5 more inches than stock.
