Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Sep 12, 2016 at 4:47 PM
    #601
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Would it not be able to keep up on its own?
  2. Sep 12, 2016 at 6:31 PM
    #602
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    OEM N/A tune might have more timing than what it'd run if it were F/I.
    If you're getting any pinging, then being able to adjust timing has its obvious benefits.
  3. Sep 12, 2016 at 7:03 PM
    #603
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Yeah I read that about the o2 sensor sim only being needed for older tacomas. I'm not sure which mine would need, it's 2000 and has 2 o2 sensors. But in either case it'd be the MAF and the o2/afr cal in order to tune both open and closed loop.
    Timing would be nice but I don't think it's necessary for an intercooled turbo setup. I'm sure you'll be at the far end of what the stock ecm can adjust for but it can't be nearly as bad as the TRD s/c which was 85% cured with a completely untuned methanol kit running 30:70 for me. What is the timing situation with your set up @Torspd ?
  4. Sep 12, 2016 at 8:24 PM
    #604
    Brice
    Brice
    Texas
    I have an auto which means I have a wideband primary and since you're a 2000 model you probably have one too...Idk though... And a lot of guys run this kit with no timing help, doing the chevy knock sensor upgrade also helps, along with an intercooler (which I will have to get a bigger one...winter/fall/spring spring may be ok but summer is a bit to warm I think)
  5. Sep 13, 2016 at 6:28 AM
    #605
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Stand-alone with full control everything. With no timing adjustment, it definitely pings and or knocks, above 8 psi. Different engine, different ecu. The point is, better safe than sorry, and follow the paths of those whom have done it all right, with proper engineering practices.
  6. Sep 13, 2016 at 6:34 AM
    #606
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Summer is the most taxing here. The humidity and temp., increase IAT's A LOT. Which it the most critical factor for knock potential. Next is fuel mixture. An intercooler will reduce IAT's over no intercooler, but the turbo will still increase the ingested air temp versus N/A. Since your MAF is now pre turbo, you won't know your IAT's post intercooler, without an additional sensor.
    Luckily the 5vz is an iron block, and the internals are fairly strong. Keep that knock at bay, or parts will bend to its will.
  7. Sep 13, 2016 at 7:23 AM
    #607
    Brice
    Brice
    Texas
    Well I'd be a fool not to listen to yah, an yeah not adjusting timing would be a bad idea the more I think about it...So MAF/Timing Cal and a AFR Cal should be what I need, hopefully they can work in parallel. And with that I should be able to control open and closed loop.
  8. Sep 13, 2016 at 8:51 AM
    #608
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Speak with Gadget on that combo. I know the MAF-Cal can do some closed loop tuning. Ask to remove any doubts of confliction between the two devices.
  9. Sep 13, 2016 at 8:52 AM
    #609
    Brice
    Brice
    Texas
    Just did :D
  10. Sep 13, 2016 at 8:57 AM
    #610
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
  11. Sep 13, 2016 at 9:04 AM
    #611
    Brice
    Brice
    Texas
    IIRC this build was a case of "if you can shove enough fuel into it" it's possible, not reliable, but possible. That apexi would be a good thing to tune with, compact and easy. The issue is finding a wiring diagram for it. It can control open and closed loop by setting afr's at various rpms.https://youtu.be/XjqCzyV800U
  12. Sep 13, 2016 at 9:18 AM
    #612
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    An FMU is a fuel multiplying unit. Interchangeable disks change the ratio. With boost pressure, instead of having a 1:1 rising fuel pressure regulator, the FMU can increase fuel pressure 4:1, 6:1, 8:1, etc, with the disks.
  13. Sep 13, 2016 at 9:21 AM
    #613
    Brice
    Brice
    Texas
    However with stock injectors a ton of psi through them isn't the best idea...
    @Clay_916 FMU's also continue to add pressure regardless of driving conditions, meaning if you're turbo boosts at cruise you can go ahead and say bye bye mpgs lol
  14. Sep 13, 2016 at 9:27 AM
    #614
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It was the go to method to get extra fuel, from "X" sized injectors, before high accuracy electronics allowed for more accurate injector control and larger injectors *EDIT* > For the masses* It was the mechanical method versus the now electronic method.
    It actually wasn't until just a few years ago that High Impedance injectors were offered in a size greater than 550ccm, then 750ccm.
    Brice[OP] likes this.
  15. Sep 13, 2016 at 9:44 AM
    #615
    Brice
    Brice
    Texas
    Yeah, those little units are pretty neat, not to mention they look cool too haha. There like $450 for AFR calibration, timing and MAF calibration. The downside is there's no wiring diagrams I can find otherwise they were my second choice below the fic6
  16. Sep 13, 2016 at 9:44 AM
    #616
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correction. Likely used the APEXi SAFC to refine the added fuel from the fmu a little bit, to get his target or near target AFR's, while in boost .
  17. Sep 13, 2016 at 9:47 AM
    #617
    Brice
    Brice
    Texas
    I think they can manipulate timing too?
  18. Sep 13, 2016 at 9:54 AM
    #618
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Haven't found anything about timing, with the SAFC.
  19. Sep 13, 2016 at 9:59 AM
    #619
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Last time I used one it was a fuel controller only.
  20. Sep 13, 2016 at 10:14 AM
    #620
    Brice
    Brice
    Texas
    Huh so that MAF/timing cal is my best bet then.
