Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Sep 14, 2016 at 11:06 AM
    #661
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You could also do the AEM with the extension harness from URD. AEM doesn't sell an extension harness for the 1st gen? I know they do for the 2nd gen.
    Just received my Boomslang harness for my future Haltech, a few weeks ago. :woot:
  2. Sep 14, 2016 at 11:15 AM
    #662
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Not as far as I know...but I'll have to look again. And nice on that haltech harness :thumbsup:
  3. Sep 14, 2016 at 12:55 PM
    #663
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Anyone know of someone using AEM FIC on a 3rz? I'm having trouble finding info on that.
  4. Sep 14, 2016 at 1:00 PM
    #664
    Brice
    Brice
    Texas
    Well I just took a look at AEM's sight and I didn't find any extension harnesses for a 99 v6...The mapecu deal would be cheaper in the long run anyway, and since this is a budget build I don't see any reason I wouldn't buy it instead of the AEM...I guess if you could get an Ebay aem and extension harness it would be more worth it but since I can't actually find an extension harness the mapecu is winning... @vasinvictor Did you have an extension harness or did you just wire straight to the OEM harness?
    In other news, I may have just gotten a spare 5vzfe...Forged build someday maybe? :D
    EDIT: I'm stupid...I can just use the URD harness with the AEM, Didn't realize what you were saying Torspd lol. In that case The AEM would be cheaper and from what I understand, nearly as capable as the mapecu. So I think I'm going the AEM route.
    MapEcu
    $500(group buy)+$200(harness)=$700
    AEM fi/c6
    $380(ebay)+$200(harness)=$580~600
    I guess the difference in price isn't too much, however like @vasinvictor said (in short) the AEM is much more convenient, especially with wiring. (which I have to agree with since it's all I'm finding on Yota forums, correct me if im wrong)
    EDITT: AEM is $370 on Amazon https://www.amazon.com/AEM-30-1910-Cylinder-Ignition-Controller/dp/B001DX58KA
  5. Sep 14, 2016 at 2:33 PM
    #665
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    AEM does not have boost control built in but that would be awesome. It does have a built in MAP obviously which is how you tune. I compared the two and liked the AEM for their injector intercept, and it seemed to run larger injectors better. I also like how well documented it is because it's been around a long time and there are many many users. There's another guy on customtacos who had fits tuning closed loop boost with his MAP3 and ended up removing the wideband o2 altogether and creating the whole fuel map, thus making it more like a standalone. Ugh I aint got time for that. The AEM was CAKE to tune closed loop, by contrast. Not only is the AEM way cheaper, but I personally feel like it's a better product.
    I'm on 9psi with stock fuel pump at 10.5 afr 93 octane pump fuel. Stock pump handles it fine.
    I used the "flying leads" harness that AEM provides. They're like 3' long and I wired them directly into the factory wiring harness. Soldered every connection too.
    Brice[OP] likes this.
  6. Sep 14, 2016 at 2:47 PM
    #666
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    What do you mean? The universal universal F/IC will wire up just like any other. Just tap or intercept the wires based on the wiring diagrams. It will work and tune just like any other motor.
  7. Sep 14, 2016 at 2:56 PM
    #667
    Brice
    Brice
    Texas
    I guess my only worry is there not being enough wire in the OEM harness...Also isnt 10.5 to 1 a bit rich? Wouldn't you want 11.5 to 12.0 at full boost?
  8. Sep 14, 2016 at 3:06 PM
    #668
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Yeah I am being overly cautious. I've always run meth but I do not it hooked up currently. I will feel much safer at 11.5 with windshield washer fluid. Plus I guess I am losing some power, but it's really strong at 9psi and goes 11.4 in the 1000' (mid 13 second 1/4 mile) so I'm not concerned with losing 10-20hp for longevity.
  9. Sep 14, 2016 at 3:14 PM
    #669
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Think I'm going with fic as well. How much does a typical EBC run? My wg is 7 psi and I am definitely bumping it up. Anyone know a good place for injectors? Found a place, racetronix, which sells them for around $50 a pop. Everywhere else I've looked they are at least $80. Also, I'm assuming I need high impedance?
  10. Sep 14, 2016 at 4:11 PM
    #670
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  11. Sep 14, 2016 at 6:27 PM
    #671
    Brice
    Brice
    Texas
    Thanks man :D don't we only need to worry about retarding it though?
  12. Sep 14, 2016 at 6:31 PM
    #672
    Brice
    Brice
    Texas
    I found a set of 440cc's on eBay for like $190 :notsure: also what does EBC stand for?
  13. Sep 14, 2016 at 6:32 PM
    #673
    Brice
    Brice
    Texas
    Makes sense
  14. Sep 14, 2016 at 6:41 PM
    #674
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Electronic boost controller
  15. Sep 14, 2016 at 7:58 PM
    #675
    boostedka
    James
    NM
    I figured wiring was fairly straightforward. I was mostly wanting to see what hands on experience anyone had and any tuning tips or issues. Thanks for the reply though. Still very helpful :thumbsup:
  16. Sep 14, 2016 at 8:32 PM
    #676
    Brice
    Brice
    Texas
  17. Sep 15, 2016 at 11:03 AM
    #677
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    MAP3 can advance. Timing advanced would be useful if you're running e85 or maybe 116 race gas. Otherwise with pump gas, you only need to worry about retard. I'm not even retarding any timing on 9psi FWIW. I used OsideTiger injectors from ebay and they work great. Their customer support is also good, I had to call twice and got an english speaking human immediately both times :)
  18. Sep 15, 2016 at 11:09 AM
    #678
    Brice
    Brice
    Texas
    Lol good to know, I'll keep a look out for them. What injector designs fit the surfaces on the manifold and rail? I'm just curious. Also, have any pictures of the ones you got?
  19. Sep 15, 2016 at 11:11 AM
    #679
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    I use a cheap manual boost controlled (MBC) and a boost solenoid. If I bypass the MBC (using the solenoid) it runs on wastegate spring, 9lb. If I flip a switch to activate the solenoid and make it run through the MBC, then it will go to 15psi (or whatever you have teh MBC set at). You can also use that same switch to automatically switch the AEM F/IC to "Map B" and use your high boost tune. Alternatively you can use an EBC to simply things ($$) Many way to skin this cat
    Yes, you need high impedance injectors.
    :turtleride: ha rocking chair on a turtle wtf
    Clay_916[QUOTED] and Brice[OP] like this.
  20. Sep 15, 2016 at 11:14 AM
    #680
    Brice
    Brice
    Texas
    Personally I think I'll spend the cash and skip the headache and just get an ebc
