Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Sep 23, 2016 at 11:34 AM
    #781
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Like mentioned, the low price seems to make up the mpg hit u get from using e85. E85 has less chemical energy density from what I understand, and our motors and ecus are not optimized to use its strengths (not high compression or advancing timing or running the block a bit hotter) but all that is null when you zero out your timing retard and go romp on the truck and know ping is not even near happening.
    Oh and yeah you need to run about 30% more fueling to run a stoich ratio so your fuel system needs to be up to par, and e85 is corrosive, use an e85 friendly pump, injectors etc and might even have to upgrade lines, fuel rail etc from heavy usage.
    Looots of e85 knowledge out there from lots of gear heads running it.
  2. Sep 23, 2016 at 12:35 PM
    #782
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Yeah I think the only conceivable downside is you'll blow up your motor because you can push it so hard.
  3. Sep 23, 2016 at 12:45 PM
    #783
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    well that and they usually actually don't sell e85 in the winter because it is harder to crank (usually about e70 from what I gather) so if you have a tune just on the very top side of safe and get a batch with 15% less ethanol you may run into some issues that require a large box to put pieces in. I think this happened to superwerty
  4. Sep 23, 2016 at 1:09 PM
    #784
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Yeah I suppose that's an issue although I would think due to the cooler ambient air in winter you wouldnt be dealing with as high a magnitude of pinging issues as summer. Yeah that's pretty annoying though, especially if you're tuned at that upper edge like you mentioned. I think I would need a fully forged build before I could properly utilize ethanol anyway.. I can dream though.
    yota243[QUOTED] likes this.
  5. Sep 23, 2016 at 1:12 PM
    #785
    yota243
    E.J.
    north Alabama
    well I know that werty hates the stuff from what little I have interacted with him, but I also no he had a 12 second 2nd gen on stock internals with the stuff so...
  6. Sep 23, 2016 at 3:28 PM
    #786
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Still don't have money :D
    And I think I'll take the turbocharger-kit off of the current engine and stick it on the fully built one once I have funds to actually build the spare engine lol
    As far as custom fabbed parts go, I've started "prototyping" if you will, a new design for the plastic trim around the shifter. IMO that space is wasted, especially on bench seats which dont have that nice arm rest/center console piece. I don't really use the cup holders (except to put my phone in) so In the design I made I did away with them and replaced that area with a deeper recessed area, I also put a little tray up in from of the shifter for smaller stuff like a phone or something. The thing that sucks is, is that I have a 2wd drive auto, Which means this thing I'm making wont fit a 4x4 manual or auto... Eh who cares though, I'm really making it for myself and hoping other people will like the idea lol
    And why not buy a performance car? Well because I need a truck for where I live and what I do on a daily basis, a car simply wouldn't work in my life, as weird is that sounds. So in my desire for goin fast I mod my truck since its what I have :D
    gray223[QUOTED] likes this.
  7. Sep 23, 2016 at 3:32 PM
    #787
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    If you are building an engine, keep the turbo on the truck, turn up the boost, and have fun blowing it up :D
    Clay_916 and Brice[OP] like this.
  8. Sep 23, 2016 at 4:28 PM
    #788
    yota243
    E.J.
    north Alabama
    And video it^^^
    Brice[OP] and gray223 like this.
  9. Sep 23, 2016 at 6:03 PM
    #789
    Brice
    Brice
    Texas
    lol maybe...I'll just replace the oil with shampoo and turn up the boost
  10. Sep 23, 2016 at 6:09 PM
    #790
    yota243
    E.J.
    north Alabama
    I think conditioner would be better for a healthier shine or atleast 2 in 1
  11. Sep 23, 2016 at 6:10 PM
    #791
    Brice
    Brice
    Texas
    Maybe both, Its pretty dirty. Maybe shampoo, drain it then conditioner.
  12. Sep 23, 2016 at 8:14 PM
    #792
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    So I've ordered 2 oil drain flanges now and both were two big, or the bolt holes are spaced too far apart. Wtf? There doesn't seem to be any measurements listed on any of these in the first place. Need something that has a slight bend and is a long solid piece. Halp
  13. Sep 23, 2016 at 8:26 PM
    #793
    Brice
    Brice
    Texas
    What is the turbo you bought specifically?
  14. Sep 23, 2016 at 8:42 PM
    #794
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    - T4 GT35 Turbo
    Turbo and Wastegate:
    - 4" Air Inlet
    - 2.5" Compressed Air Outlet
    - Standard T4 Turbine Housing Flange
    - 3" Vband Exhaust Outlet
    - Journal Bearing
    - 300~500 WHP
    - Oil and Water Cooled
    - 6-25 PSI Working Pressure
    - .70 A/R Compressor
    - .68 A/R Turbine
    - 61.3 /82 mm Compressor Wheel
    - 62 /67.8 mm Turbine Wheel
    - 38mm 8 psi Wastegate
  15. Sep 23, 2016 at 8:47 PM
    #795
    Brice
    Brice
    Texas
    And you're looking for the drain correct?
    If so, this one appears to be correct. The bigger T4 drain flange is longer and doesn't have flat edges unlike the GT28-35 turbos which have flat edges on the drain flange and are shorter, I learned that the hard way as well :D
    http://www.ebay.com/itm/BILLET-6061...m4af7b94323:m:mAO9GOiEEGgUi0ryhPRcORA&vxp=mtr
    Clay_916[QUOTED] likes this.
  16. Sep 24, 2016 at 8:00 AM
    #796
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
  17. Sep 24, 2016 at 8:25 AM
    #797
    Brice
    Brice
    Texas
  18. Sep 24, 2016 at 2:31 PM
    #798
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Raised rpm with TRD "high boost" ripped the rods apart.
    Ethanol content analyzer, is the key.
  19. Sep 30, 2016 at 2:33 PM
    #799
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    this thread slowed to a halt. any updates?
  20. Sep 30, 2016 at 2:56 PM
    #800
    Brice
    Brice
    Texas
    That's what happens when you run out of money lol. No updates atm, I'm about to install a boost controller to turn it up to like 5psi or so vs 2psi. Im also about to go pick up the spare motor, maybe next weekend? Other than that I'm still saving for the AEM F/IC injectors etc, Im also rendering a video as we speak so that should be up in a matter of hours.
    devinzz1[QUOTED] likes this.
