Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Oct 4, 2016 at 10:23 AM
    #841
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  2. Oct 4, 2016 at 10:33 AM
    #842
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Hm that reminded me. My turbo doesn't really make any spooling noises, Myself and others describe it as sound like a industrial vacuum cleaner lol...
  3. Oct 4, 2016 at 11:40 AM
    #843
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yours isn't making enough boost yet. Up the boost, and make that jet turbine whistle!
  4. Oct 4, 2016 at 12:38 PM
    #844
    Brice
    Brice
    Texas
    I sure hope so. Speaking of upping the boost, I'm doing that today! Goin out to home depot to get me the stuff to make a boost controller, and hopefully a switch that breaks a connection under pressure so that way I can cut the o2 sensor signal to the ecu when I hit boost, thereby causing the ECU to go into open loop at part throttle.
  5. Oct 4, 2016 at 12:47 PM
    #845
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
  6. Oct 4, 2016 at 1:03 PM
    #846
    Brice
    Brice
    Texas
    Its a 4.5lb spring(s) but its pre intercooler, to respond faster, which in turn lowers the manifold pressure.
    https://howlandtechnology.com/store/psf103-9061-903.html apprently this one work with anything past atmospheric, Im hoping home depot will have something like it. I need it to react relatively low with boost since I start spooling at around 2100 or so and at that point full throttle is a ways off.
  7. Oct 4, 2016 at 1:28 PM
    #847
    yota243
    E.J.
    north Alabama
    :confused: aren't all wastegates pre intercooler? (I guess it depends on where you start tracking) unless you are cooling you exhaust temps???
  8. Oct 4, 2016 at 1:31 PM
    #848
    Brice
    Brice
    Texas
    Well you can put in either spot. Pre IC makes the manifold see less boost due to the pressure drop through the intercooler, but responds faster to boost pressure.
    Post IC and you'll get the true wastegate spring pressure but the wastegate won't open and close as quickly since it will be referenced farther from the turbo. Atleast thats how I understand it...:D
  9. Oct 4, 2016 at 1:34 PM
    #849
    yota243
    E.J.
    north Alabama
    do you mean blow off valve?
  10. Oct 4, 2016 at 1:36 PM
    #850
    Brice
    Brice
    Texas
    No, but I'd assume the same thing applies there...
  11. Oct 4, 2016 at 1:38 PM
    #851
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Lol. Turbo an na motor. Or swap an ls motor.
    What is more complex you ask?
    Turboing. Every damn time.
  12. Oct 4, 2016 at 1:38 PM
    #852
    yota243
    E.J.
    north Alabama
    I'm so confused right now... how can your wastegate let excess exhaust bypass if it is in you cold side piping man, one of us has something going on today haha, do you mean that you have your boost line for your wastegate in you pre IC pipe?
    Gaunt596, j0shu4 and Brice[OP] like this.
  13. Oct 4, 2016 at 1:40 PM
    #853
    Brice
    Brice
    Texas
    Yes :rofl:
  14. Oct 4, 2016 at 1:40 PM
    #854
    yota243
    E.J.
    north Alabama
    thought I was losing my mind for a minute
  15. Oct 4, 2016 at 1:41 PM
    #855
    Brice
    Brice
    Texas
    Lmao me too, I went and re-read a bunch of stuff too to make sure I wasn't insane
    yota243[QUOTED] likes this.
  16. Oct 4, 2016 at 2:10 PM
    #856
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I bought a manual boost controller for $20 on eBay. 0-30 psi. I think if you made one yourself you'd save $10. On the stock system you should be good up to 4-5 psi. You could buy a cheapo stage 1 meth kit for like $150 and be safe to like 7 psi and honestly I would stay that route until you're ready for like 12 psi. The fic6 is great but it's total overkill on my setup IMO at 10 psi.
    Oh and wtf is all this LS swap being cheaper than a turbo? I don't have much knowledge on that swap or experience but that sounds crazy to me. How much does the swap actually cost? I'm pretty happy with my 21 mpg though so it's not something I'd consider on a DD.
  17. Oct 4, 2016 at 2:20 PM
    #857
    Brice
    Brice
    Texas
    Ls's get great mileage on EFI, itd be super cheap for me since I have a spare ls block sitting around, but it can be done for around $2800-3200 dollars if done right. Before I lost it, I had a journal full of everything needed for a Tacoma ls swap, EVERYTHING then I lost it lol. I think speed freak got like 24mpg
  18. Oct 4, 2016 at 2:22 PM
    #858
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Wow, didn't know it was that cheap. That's about where I'm at with the turbo costs. Damn..
  19. Oct 4, 2016 at 2:23 PM
    #859
    Brice
    Brice
    Texas
    *My reaction when I realized what I spent*
    But I'm balls deep now. Gotta keep goin :D
  20. Oct 4, 2016 at 3:46 PM
    #860
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    All manual wastegates have a cracking pressure. It increases as the boost pressure is increased.
    An electronic boost controller can make that cracking pressure much closer to boost pressure.
    The source of the wastegate's reference, pre TB or post TB will depend on how much boost the engine sees. Depending upon how much a pressure drop there is across the intercooler and tubing. The more efficient the intercooler the less the drop.
    Referenced from the manifold, the wastegate will actuate it pressure level from there. Example, 5 psi spring will open at 5 psi when the manifold has 5 psi.
    From the turbo, the wastegate will open at 5 psi, but the intercooler has a 3psi drop, so the boost gauge (referenced from the manifold) only shows 2psi, at the manifold.
    In that example, the wastegate referenced from the manifold will actually make the turbo spin to 8psi, to get five at the manifold.
