Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Oct 7, 2016 at 4:20 AM
    #881
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do you want a locker, or a limited slip? Let'sbe 100 % clear.
  2. Oct 7, 2016 at 7:32 AM
    #882
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    I guess either, but dont limited slips wear out?
  3. Oct 7, 2016 at 7:41 AM
    #883
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I hear Lincoln makes a good cheap locker :stirthepot:
    Brice[OP] likes this.
  4. Oct 7, 2016 at 7:49 AM
    #884
    Brice
    Brice
    Texas
    lol
  5. Oct 7, 2016 at 8:03 AM
    #885
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah, some clutch based ones will wear out and they always need friction modifiers. But the Detroit TrueTrac is a completely mechanical (planetary gear driven) limited slip that would be perfect for what your doing and can use plain ole gear oil.
    Torspd likes this.
  6. Oct 7, 2016 at 9:11 AM
    #886
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This is what I have
  7. Oct 7, 2016 at 10:05 AM
    #887
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    You'll need a new clutch once you go to 10 psi. I'd save money for that.
    j0shu4 likes this.
  8. Oct 7, 2016 at 10:14 AM
    #888
    Brice
    Brice
    Texas
    Automatic:cool: the A430e is supposed to be good for 350hp so we'll definitely test that out!
  9. Oct 7, 2016 at 10:31 AM
    #889
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Damn guess it's just me then :(
  10. Oct 7, 2016 at 10:49 AM
    #890
    Brice
    Brice
    Texas
    Haha sorry man. What clutch are yah gonna go with?
  11. Oct 7, 2016 at 8:29 PM
    #891
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
  12. Oct 8, 2016 at 11:55 AM
    #892
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    trutrac would be great for this build.
  13. Oct 10, 2016 at 1:28 PM
    #893
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    My sources say the a340 is good for 500 before it starts eating itself. I've run estimated 400 crank through it with a valve body and 3,000 stall converter.
    1st gear burnout only, no O/D in any boost.
  14. Oct 10, 2016 at 1:32 PM
    #894
    Brice
    Brice
    Texas
    Where did you get the stall done?
  15. Oct 10, 2016 at 1:40 PM
    #895
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Great Converters in TX
  16. Oct 10, 2016 at 1:48 PM
    #896
    Brice
    Brice
    Texas
    Alright cool Ill have to look em up. Did you redo the stock one or buy a performance one?
  17. Oct 28, 2016 at 12:54 PM
    #897
    yota243
    E.J.
    north Alabama
    bump man, are you still thinkin about getting a mapecu3?
  18. Oct 28, 2016 at 1:56 PM
    #898
    Brice
    Brice
    Texas
    Nah, I've pretty much settled on the AEM, as its more budget friendly and there's more info on it for Taco's.
    I've been thinking for a long while now and I dont think Im gonna build the forged engine, for multiple reasons.
    -It'll cost a lot of money (upwards of $7000 for everything said and done, and that's a bit conservative) that I can put elsewhere.
    -Dealing with turbo's is fun in theory but crap in practice, we all just wanna drive something with a turbo. lol (a tacoma to be exact)
    -at 500-600 hp the Tacoma itself will need things like, tires, caltracs (gonna need those anyway), a new trans (would probably be a t56 or th400), a new driveshaft (to fit the GM trans) and a standalone, Which would be lots of $$$
    I don't regret the turbo, not at all, it's just not something that I want to carry out on this truck via a built engine so it'll stay stock on boost until it blows up and needs some sort of treatment.
    My plans now, are to clean up the IC piping with the CXRacing IC piping kit, get the AEM F/IC and harness, get a proper boost controller, Injectors and turn the boost up to 10lbs and see what happens :D
    At this point in time I have also developed a ticking noise near the passenger valve cover. I think it's valve's but im not sure. I'm gonna check clearances at some point and stay off boost. I also heard that a tick could be the timing belt (needs replacing anyway) so we'll see.
    So, unrelated, My friend has a honda accord that I rode in recently (stock) and as I was riding in it I realized that I kinda wanted a car, but like I said previously a car would not work for me -long term I should say, since I use my truck so often. However we have just finished moving and I don't really need my truck as a truck any more, and it would be nice to have something that rode half-way decent.
    Basically Im looking into buying a new daily and keeping the truck around for work or a spirited 10psi drive. I'm REALLY liking the 1996-2000 sc400's, If anyone has any suggestions go ahead and chime in :D
  19. Oct 28, 2016 at 2:46 PM
    #899
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How many miles does your timing belt have on it?
  20. Oct 28, 2016 at 3:29 PM
    #900
    Brice
    Brice
    Texas
    More than likely it has the odometer's 174K
