Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Dec 28, 2016 at 5:07 PM
    #981
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    NotMineNotMineNotMineNotMineNotMineNotMineNotMineNotMineNotMineNotMineNotMineNot
    Found this on facebook from a guy named JZ Swap and Wiring shared
    I think I can wire both PWR GND connections to E02 since thats all that my ECU has (E02 and E03)
    Toyota Ecu pinout abbreviations
    I was asked to define the abbreviations of what I thought everyone would know. I forget that everyone had to start somewhere (myself included)
    Here is a list of every Toyota abbreviation I could find. If there is anything missing or incorrect please feel free to share!
    +B1 Permanent +12V
    +B Permanent +12V
    BAT Permanent +12V
    BT Switched power via EFI main relay
    IGSW Switched ignition power
    E01 Earth 01 GROUND
    E02 Earth 02 GROUND
    E1 Earth 1 GROUND
    E2 Ground/earth output for sensors
    #10 Injector 1
    #20 Injector 2
    #30 Injector 3
    #40 Injector 4
    #50 Injector 5
    #60 Injector 6
    ^Non-batch fire fuel injection
    #10 Injectors 1 & 4
    #20 Injectors 3 & 5
    #30 Injectors 2 & 6
    ^Batch fire fuel injection (Older/non-vvti 1jz's)
    RSO Idle air control output
    RSC Idle air control output
    HT Oxygen sensor heater output
    STJ Cold start injector output
    IGT Ignitor signal
    IGT1 Ignition coil 1
    IGT2 Ignition coil 2
    IGT3 Ignition coil 3
    IGT4 Ignition coil 4
    IGT5 Ignition coil 5
    IGT6 Ignition coil 6
    EGR output (emissions* Exhaust gas re-circulation)
    G2 Distributer input /Cam sensor 2
    G1 Distributer input /Cam sensor 1
    NE Distributer input /Crank sensor
    G- Distributer input (Ground circuit for cam/crank sensors)
    IGF Ignitor signal
    TPC Turbo pressure control output (to turbo VSV)
    TVIS Control Signal to TVIS solenoid
    VF Check connector signal (EGO feedback signal)
    TE1 Test signal Diagnostic
    TE2 Test signal Diagnostic
    VF Diagnostic
    OX Oxygen sensor input
    PIM MAP sensor input
    KNK Knock sensor input
    THW Coolant temperature input
    IDL Idle switch on throttle position sensor
    THA Intake air temperature input
    VTA Throttle position input
    VG Airflow sensor
    THG EGR function sensor
    VC 5V ouput for MAP, throttle position and airflow sensors
    STA Clutch start switch input
    AC Aircon request input
    SPD Speed sensor input
    PS Power steering signal
    PSCT Power steering signal
    FPR Fuel pump relay output
    W Warning/check Engine light output (Ecu may ground this circuit)
    STP Brake light input
    ABS ABS signal
    FC Fuel cut ouput
    ELS idle up input
    Abbreviations and Toyota/SAE terms:
    Glossary of SAE and Toyota Terms
    ACH Air Cleaner Housing Air Cleaner
    ACS Air Conditioning Sensor Air Conditioning Switch
    AFS Air Flow Sensor Air Flow Meter
    AIR Secondary Air Injection Air Injection (AI)
    ALT Alternator Alternator
    B+ Battery Positive Voltage +B, Battery Voltage
    BARO Barametric Absolute Pressure Sensor HAC Sensor / P sensor
    CAC Charge Air Cooler Intercooler
    CARB CArburetor Carburetor
    CL Closed Loop Closed Loop
    CLS Closed Loop System Closed Loop System
    CPS Crankshaft Position Sensor Crank Angle Sensor
    DI Direct Injecttion Direct Injection
    DLC1
    DLC2 Data Link Connector 1: Check Connector 2: TDCL
    DLI Distributerless Ignition Distributerless Ignition
    DTC Diagnostic Trouble Codes Diagnostic Codes
    ECTS Engine Coolant Temperature Sensor Coolant Temperature Sensor, Water Temperature Sensor or THW
    EEPROM Electrically Erasable Programmable Read Only Memory Electrically Erasable Programable Read Only Memory (EEPROM), Erasable Read Only Memory (EPROM)
    EFE Early Fuel Evaporation Cold Mixture Heater (CMH), Heat Control Vavle (HCV)
    EGR Exhaust Gas Recirculation Exhaust Gas Recirculation
    EGRS EGR Function Sensor EGR Gas Temperature Sensor
    EGRV EGR Valve EGR Valve
    EI Electronic Ignition Electronic Spark Advance (ESA)
    EM Engine Modification Engine Modification
    EPROM Electrically Programmable Read Only Memory Programable Read Only Memory (PROM)
    EVAP Fuel Evaporative System Evaporative Emission Control
    FPR Fuel Pump Relay Fuel Pump Relay
    GND Ground Ground
    HO2S Heated Oxygen Sensor Heated Oxygen Sensor
    IACV Idle Air Control Valve ISC Valve
    IATS Intake Air Temperaure Sensore Intake or Inlet Air Temperature Sensor
    IDI Indirect Diesel Injection Indirect Injection Diesel Engine
    KS Knock Sensor Knock Sensor
    MAP Manifold Absolute Pressure Sensor Manifold Pressure Sensor
    Turbocharger Pressure Sensor
    Vacuum Sensor
    MCS Mixture Control Solenoid Electric Bleed Air Conrtol Valve (EBCV)
    Electric Air Control Valve (EACV)
    MPI Multipoint Fuel Injection Electronic Fuel Injection (EFI)
    O2S Oxygen Sensor Oxygen Sensor, O2 Sensor
    OBD On Board Diagnostic System On-Board Diagnostic System
    OC Oxidation Catalyst Oxidation Catalyst, CCo
    OL Open Loop Open Loop
    PAIR Pulsed Secondary Air Air Suction (AS)
    PCME Powertrain Control Module (engine) Engine ECU
    PCME&T Powertrain Control Module (engine and transmission) Engine and ECT ECU
    PCMT Powertrain Control Module (transmission) ECT-ECU, Transmission ECU
    PNS Park/Neutral Switch Neutral Start Switch (NSW)
    PTCS Powertrain Control Signals Output Signals
    PTIS Powertrain Input Signals Inp[ut Signals
    RAM Random Access Memory Random Access Memory
    ROM Read Only Memory Read Only Memory
    SABFV Secondary Air Anti-Backfire Valve Check Valve
    SABV Secondary Air By-Pass Valve Air By-Pass Valve (ABV)
    SAPV Secondary Air Pulse Valve AS Reed Valve, Air Suction Valve
    SASV Secondary Air Switching Valve Air Switching Valve (ASV)
    SC Supercharger Supercharger
    SMPI Sequential Multipoint Electronic Fuel Injection Electronic Fuel Injection (EFI), Sequential Injection
    SPS Steering Pressure Sensor Air Control Valve (ACV)
    TB Throttle Body Throttle Body
    TBI Throttle Body Electronic Fuel Injection Single Point Injection
    Central Fuel Injection (Ci)
    TC Turbocharger Turbocharger
    TCC Transmission/Transaxle Converter Clutch Switch Lock-Up Solenoid
    TGSS Transmission Gear Selector Switch Shift Possition Switch
    TOP Trap Oxidizer-Periodic Diesel Particulate Filter (DPF)
    Diesel Particulate Trap (DPT)
    TPS Throttle Possition Sensor Throttle Possition Sensor
    TVS Thermal Vacuum Switch Bimetal Vacuum Switching Valve (BVSV)
    Thermostatic Vacuum Switching Valve
    TWC Three Way Catalyst Three Way Catalyst
    CC80
    VR Voltage Regulator Voltage Regulator
    VSPG Vehicle Speed Pulse Generator Speed Sensor
    VSS Vehicle Speed Sensor Vehicle Speed Sensor (reed switch type)
    WOTS Wide Open Throttle Switch VL Switch
    Power Switch
    WUTWC Warm Up Three Way Catalyst Manifold Convertor
    gray223, mechanicjon and Torspd like this.
  2. Dec 28, 2016 at 5:08 PM
    #982
    Brice
    Brice
    Texas
    Haha welp Im gonna wire it to E02 and see what happens :notsure::D
  3. Dec 28, 2016 at 5:16 PM
    #983
    Brice
    Brice
    Texas
    Done. Time to test it :D
    Torspd likes this.
  4. Dec 28, 2016 at 8:32 PM
    #984
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    7 out of 11 e3 plugs failed on me. 5 of them physical breaking. Never using that garbage again.
  5. Dec 28, 2016 at 9:42 PM
    #985
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    @Brice
    @Clay_916
    Where'd you guys get your fic from? They seem to range in price a lot. I've seem some on eBay for as low as ~$300 saying they're shipped from Thailand and Malaysia. Know anything about those? Also Brice, where'd you buy that harness from that your wiring into to? Lastly what do you guys think of this compared to the mapecu3? Asking b/c of the potential GB that may happen. Thanks
  6. Dec 28, 2016 at 10:23 PM
    #986
    Brice
    Brice
    Texas
    I got mine from Amazon, er my mom did since it was also a gift.
    I got that extension harness from URD. Its on there website under electronics I believe.
    And I had looked into the mapecu3 back when I first started this and I'd say you could probably use either one with the same results, the mapecu I believe is a bit newer so you may have more features (I believe it has two step and fast car stuff like that, not sure) and as long as the map ecu tells you what it needs to intercept and see, wiring should be fairly straightforward
  7. Dec 28, 2016 at 10:40 PM
    #987
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I got mine off Amazon for $390. I wouldn't gamble on anything cheaper that might end up being a fic3.5 or something like that. I think the map3 is easier to configure but it has a smaller range of injector sizes that can be used because it only indirectly controls injector pulse width through the MAF while the fic can directly control pulse width. I've read the fic has issues communicating with the crank position sensor but it seems a simple resistor can fix this issue(?).
    I honestly don't know a lot about the map3 and only opted for the fic because of price. At the end of the day they both will accomplish the same thing so I say buy the one that's cheaper.
  8. Dec 29, 2016 at 5:04 AM
    #988
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well did it power up and connect?
    Bxnanaz likes this.
  9. Dec 29, 2016 at 7:50 AM
    #989
    boostedka
    James
    NM
    Thanks for the info guys. Looks like they're about the same still on Amazon so definitely a better price than the MAPECU. Brice, how much did the PNP harness end up costing? URD doesn't list a price so I'm guessing it must vary depending on the exact application.
    Is there a way that either of these fuel/timing controllers replace the MAF with a MAP sensor completely?
  10. Dec 29, 2016 at 8:33 AM
    #990
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The MAP3 can do both. Maf Intercept or Maf Delete (MAP only I.E. speed density).
    Not sure about the AEM.
    boostedka likes this.
  11. Dec 29, 2016 at 10:16 AM
    #991
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    You can technically remove it with the fic since it has a maf offset table. I'm not sure how the map removes it but with the fic you would need to set up the entire table manually so that the computer is seeing what you want in MAP via MAF, if that makes sense.
    Did some reading on the map3 last night. It looks like it has an EBC which is really nice since most I've seen are in the ball park $200-300. In general it claims to be able to do a lot more stuff but having tinkered with the 5vz ecu personally I doubt it's as capable as it claims, at least with this particular engine.
    what is the GB price that you're likely to hit? $450? If it's near that I'd say just go for it for experimentation sake. In the very least you'll have a piggy back that can get you a spot on tune equivalent to the fic and at most you'll have all the extra features.
  12. Dec 29, 2016 at 10:29 AM
    #992
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    DONE YET BRO?
    Brice[OP] likes this.
  13. Dec 29, 2016 at 10:31 AM
    #993
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I thought about trying the MAFT pro piggy back too. It does MAP conversion, EBC, and a lot more. But our motors ECU is such a bitch idk if it would be worth it.
  14. Dec 29, 2016 at 10:35 AM
    #994
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    we have the $500 rate now, I think their are 5 of us in on the GB to get to 450 we would need 11 people in, and we are gonna order feb 3rd I think
  15. Dec 29, 2016 at 10:55 AM
    #995
    Brice
    Brice
    Texas
    Yeeees, Well no this thing will never get finished lol
    Sorta
    It started with the AEM plugged in but ran crazy lean for some reason. I may have messed up some wiring somewhere along the line so I may have to go back. I can use the bypass harness to troubleshoot.
    Another thing is that when I installed the AEM fic 6 software, it didn't give me the bas_cal.fi6 file for a base map, and I can't find one anywhere on the internet, so I'm essentially left without any way to make a map...Not sure what to do there.
    The PNP ext harness was like 189 dollars? Much more reasonable than the Boomslang one which admittedly comes pre wired but is $550 I believe lol.
    That was a type C harness for a 99 V6, You would need a type D harness which is $199 You should be able to scroll to the very bottom of URD's website where the harnesses are and see the pricing :D
    Random non-blurry pics
    Where the ecu sits behind the glovebox
    Stock Injectors, Thinking about trying to decap these and have the flow tested...
    The mess in the shop this thing leaves routinley
    New injectors, you can kinda see em, phone didnt want to focus
    touch
    Shot of the engine bay with that slick new snail blanket
    because_wumbo-truck likes this.
  16. Dec 29, 2016 at 11:00 AM
    #996
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    There is no base map, it just all zeroes. Running lean worries me. No idea why that would be.
  17. Dec 29, 2016 at 11:01 AM
    #997
    Blackdawg
    Monte
    Wyoming/St. Louis
    So holy shit.
    Mega squirt does PNP now. They don't have one for tacomas..yet. But can happen..
    http://www.megasquirtpnp.com/mspnp_on_demand.php
    That said, looks like they only have ecu plugs for 95-97 tacomas with manuals.
    But hot damn. Id go for the program if I could find 9 others with 95-97s who wanted boost and a guy near Georgia for testing....
    Not good odds. Haha
  18. Dec 29, 2016 at 11:06 AM
    #998
    Brice
    Brice
    Texas
    From what I read there should be a "nothing map" wherever AEM installs the software, but there's nothing there and it wont let me make one...
  19. Dec 29, 2016 at 11:13 AM
    #999
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    As I recall you can only connect to the fic from your pc once you have a map loaded on the program and you have to make the base map. Don't remember how you make it, I think I had some generic instructions that were shipped with the fic and it was pretty simple.
  20. Dec 29, 2016 at 11:13 AM
    #1000
    yota243
    E.J.
    north Alabama
    if only there were a website where people could post videos on how to do things
