Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Jan 4, 2017 at 6:46 PM
    #1121
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    This guy right here gets it haha
    Brice[QUOTED][OP] likes this.
  2. Jan 5, 2017 at 4:18 PM
    #1122
    tony2018
    tony2018 Well-Known Member
    isn't the stock ecu capable of boosting up to 7psi?
  3. Jan 5, 2017 at 4:22 PM
    #1123
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    I can tell you with confidence, No. At 5psi it's alright, but even then it has no added fuel in closed loop.
  4. Jan 5, 2017 at 4:24 PM
    #1124
    tony2018
    so what all comes with the trd supecharger kit?
  5. Jan 5, 2017 at 4:30 PM
    #1125
    Brice
    Brice
    Texas
    So in other news, my LTFT at 1200-1800 are 2+ through -2 at 2000 on up they are 0. I kept track throughout yesterday's drive. The only place they are real bad is below 1200 where they are like +17. Still haven't gotten the STFT working on the scan gauge.
  6. Jan 5, 2017 at 4:34 PM
    #1126
    Brice
    Brice
    Texas
  7. Jan 5, 2017 at 7:12 PM
    #1127
    tony2018
    thanks, the reason i ask is because i'm trying to figure out how much boost can the stock ecu handle. i read on another forum that a guy built a rear turbo setup, custom paddle shifters and all this on a stock ecu. yes custom paddle shifters.
  8. Jan 5, 2017 at 7:18 PM
    #1128
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Burgundy 4runner? If so hes on here too
  9. Jan 5, 2017 at 7:19 PM
    #1129
    Brice
    Brice
    Texas
    Yeah I read that forum. However it is not wise nor safe for long term use to run anything over 5 psi on the stock ecu. Really for better engine health you need a fuel pump and atleast supra injectors (318cc). I don't remember his fuel situation but I don't think it was stock. Also you'll need to reference your fuel pressure regulator to a boost source. At that you'd be running a good supercharged setup.
    And the ecu can handle as much boost as the engine can handle, provided you fuel it right.
    EDIT: Without proper fueling.
  10. Jan 5, 2017 at 7:30 PM
    #1130
    tony2018
    hmm, either way im trying to plan my turbo build. just weighing options.
  11. Jan 5, 2017 at 7:33 PM
    #1131
    Brice
    Brice
    Texas
    Well since you haven't started yet I may as well compile all the information there is to having a turbo 5VZFE into that thread I talked about earlier. You're a V6?
  12. Jan 5, 2017 at 7:35 PM
    #1132
    tony2018
    yezzir, v6 automatic. you can continue your build. i'll just read all i can on the various build threads.
  13. Jan 5, 2017 at 7:43 PM
    #1133
    Brice
    Brice
    Texas
    Well once my build is tuned it will pretty much be finished as far as the turbo is concerned. After that I'll have to edit and post all of my vids on the install and then...yeah that's it :D
    After that I plan for caltracs, a locker and slicks - (not related to the turbo, just caused by it :D)
    Basically at this point I have enough info on the install and references for tuning that I feel I could put it all together. Assuming none of the other turbo dudes mind me referencing people to their builds :D
    But yeah dont worry lol this build will definitely continue.
  14. Jan 5, 2017 at 7:59 PM
    #1134
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Sounds like you're close on the STFT. The LTFT should give you a pretty good idea after even 10-20 mins of driving. Even +18 is not horrible if it will stabilize at that- but ideally closer to +-10. Once you get this dialed in, it's really hands off. I could remove my boost gauge and AFR gauge at this point if I wanted. It just never fails, rock solid.
  15. Jan 5, 2017 at 8:10 PM
    #1135
    Brice
    Brice
    Texas
    Sounds promising! Yah know...once I'm there :D AFR fluctuates quite a bit here and there, but from what I can understand I use the o2 map to correct that. I'm waiting on some resistors for the cam sensor and such, and I made a new timing map that doesn't start pulling boost till like 8 psi just to see what happens. Tomorrow I should be able to tune some more. :D
    Torspd likes this.
  16. Jan 5, 2017 at 8:22 PM
    #1136
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Shoot, you're not far from me at all. :thumbsup:
    Yup. Driving with the cammed 4.3 daily. Just received a few parts necesary to run the Haltech wires through the cab, with good sealing. So still on the oem ecu. :pout:
  17. Jan 5, 2017 at 8:25 PM
    #1137
    Brice
    Brice
    Texas
    Awwwww duuuude I GOTTA see that. High comp or boost?
  18. Jan 5, 2017 at 9:24 PM
    #1138
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    N/A waiting on boost.
    Brice[OP] likes this.
  19. Jan 5, 2017 at 10:20 PM
    #1139
    Brice
    Brice
    Texas
    Ooh how much? :D
  20. Jan 6, 2017 at 6:22 AM
    #1140
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Brice[QUOTED][OP], Torspd and yota243 like this.
