Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Jan 7, 2017 at 5:27 PM
    #1161
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Tried starting and tuning the truck today after wiring in a 2.2k ohm resistor, however this crazy Texas weather killed the battery I think. Its totally dead, so i put it on the charger, Guess we'll see tomorrow. :(
    It got into the 20's last night so idk if its coming back, the battery that is.
    EDIT: The Positive terminal is crazy corroded/was. I fixed it. It starts no problem :D
    I'm happy it was that and not electrical problems...well not THOSE kind of eletrical problems.
  2. Jan 7, 2017 at 6:39 PM
    #1162
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Lol, can't catch a break.
  3. Jan 8, 2017 at 8:38 AM
    #1163
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Quit making excuses. Get that sucker tuned. :p
    Brice[OP] likes this.
  4. Jan 8, 2017 at 11:21 AM
    #1164
    Brice
    Brice
    Texas
    Lol that's my plan for today.
    Runs way to rich in low boost
    Runs lean after letting off the gas (more fuel in vacuum?)(need to change o2 values?)
    So yeah gotta fix those problems :D and it should be A-ok.
    Other than those minor things, it hauls butt :D and does great burnouts.
    But first lunch and some videos games.:sandwich:
  5. Jan 8, 2017 at 1:28 PM
    #1165
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I might know why. This is one reason why I want to check out your truck.
  6. Jan 8, 2017 at 2:45 PM
    #1166
    Brice
    Brice
    Texas
    Well name a day and time and lets see what we can work out! :thumbsup:
    I tuned it some more.
    Still goes lean after letting off the gas.
    No longer rich in low boost, and AFR's are good up till open loop kicks in and dumps in waaaaaaaaaaaay to much fuel
    1-4 psi are 13.5-13.0
    5-6.5 psi are 13.0-12.5
    6.5-10 psi? haven't turned it up yet...:D but I'll go do that real quick since 6.5 is pretty good lol
  7. Jan 8, 2017 at 3:33 PM
    #1167
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    In boosted aplications im not sure but when i let off the gas in my N/A truck my afr drops into the 17's... pretty sure that might be normal?
  8. Jan 8, 2017 at 3:36 PM
    #1168
    Brice
    Brice
    Texas
    5vz's will fuel cut till 1200rpm above 2000~rpm. Mine is just being lean i think, although I am dropping to around 17afr so maybe? Never done that before but maybe it does now? Lol. What are your afr's when you pump the brakes?
  9. Jan 8, 2017 at 3:58 PM
    #1169
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    It's always going to show lean the instant after you close the throttle since it's cutting fuel completely. Open loop is tuned with only the fuel table so just keep dropping the fuel till you find a number you like. There is also an open loop condition which is something like over 60% throttle for 6 seconds. You're pretty much always going to be rich under this condition so I wouldn't even try to get the afrs over 12 otherwise you're cutting fuel from the transient phase where you go from low to high boost which is a big no-no.
    SconnieHailer likes this.
  10. Jan 8, 2017 at 4:12 PM
    #1170
    Brice
    Brice
    Texas
    Low to high boost is smooth with nice AFR's so that's good. I need to log something since I've pretty much passed my drive and guess method lol. Baby steps :D
  11. Jan 8, 2017 at 7:45 PM
    #1171
    SconnieHailer
    Marc
    Well im a manual trans so when I let off the gas completely it fuel cuts no brakes needed. I'm not sure how autos do it?
  12. Jan 8, 2017 at 7:46 PM
    #1172
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Totally normal to lean out like that letting off the gas.
  13. Jan 8, 2017 at 7:54 PM
    #1173
    Brice
    Brice
    Texas
    While yes leaning out after letting off the gas is normal when fuel cutting, mine does it when not meeting the fuel cut requirements.
  14. Jan 8, 2017 at 8:33 PM
    #1174
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Mine does too. Pretty normal. As long as its not going way rich and stauling, I wouldn't worry about it.
  15. Jan 8, 2017 at 9:52 PM
    #1175
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    we really need a 5vz turbo thread
    j0shu4 and Brice[OP] like this.
  16. Jan 8, 2017 at 10:14 PM
    #1176
    Brice
    Brice
    Texas
    In the process :cool:
  17. Jan 8, 2017 at 10:17 PM
    #1177
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also fwiw. 20° shouldnt kill your battery after a day. -20 sure. 20° is nothing though. You may have a drain miss wired or bad battery. Worth looking at.
  18. Jan 9, 2017 at 6:38 AM
    #1178
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I had an issue where I tapped into the wrong 12v lead and when I shut the truck off, some of the sensors didn't shut down and I would get a dead battery in the morning. Had to find a different 12v lead.
  19. Jan 9, 2017 at 7:49 AM
    #1179
    Brice
    Brice
    Texas
    Yeah I thought I did the same thing, but I've turned the truck off and waited overnight multiple times now, so I think I got the right one...or hopefully I did lol
    And My battery was already having some issue starting the truck at other times, which is why I thought it died. But it ended up just being a really really really corroded positive terminal.
    (I posted that above but I guess No one saw it?)
  20. Jan 9, 2017 at 9:17 AM
    #1180
    Brice
    Brice
    Texas
