Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Jan 16, 2017 at 12:50 PM
    #1241
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    lol that'd be cool since we're both WBND. I'll go try a larger voltage and see what happens, but dont higher voltages equal leaner?
  2. Jan 16, 2017 at 12:51 PM
    #1242
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Yeah, you're right my bad. Use tenths of voltages then
  3. Jan 16, 2017 at 12:52 PM
    #1243
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Above 4psi I'm pretty sure I have it set at .1v
  4. Jan 16, 2017 at 12:53 PM
    #1244
    Brice
    Brice
    Texas
    Yeah, .1v does nothing... I was in the .01v-1.5v range last night and gave up since within that nothing changed.
  5. Jan 16, 2017 at 12:53 PM
    #1245
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Gotcha, yeah you probably have it tapped wrong then, it should definitely do something lol
  6. Jan 16, 2017 at 12:56 PM
    #1246
    Brice
    Brice
    Texas
    Lol yeah...and I just put my glove box back together...
  7. Jan 16, 2017 at 2:10 PM
    #1247
    Brice
    Brice
    Texas
    @vasinvictor Im kinda in the dark now...
    I went and inspected pin E7 13 on the URD harness, and it was properly tapped with the O21+ wire from the AEM.
    Upon further inspection however pin E7 13 on the factory ECU has no pin/wire in it, Meaning I tapped a wire that goes to nowhere...
    This also means this directory of pinouts (http://www.well.com/user/mosk/images/Early_Tacoma_ECUs_v1.pdf) has a flaw lol... Well I'm not real sure how to find the o2 sensor wire now...Can I tap directly into the correct wire from the o2 sensor itself?
    EDIT: after a bit of looking all ECU's from 98-2001 have the OX1 or o2 sensor 1 at pin E7 13. And I know I have a wideband because of how many wires it has (4 vs 2)
  8. Jan 16, 2017 at 2:18 PM
    #1248
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Wideband doesn't have anything to do with number of wires FYI. Narrowband has 4 wires also. You need a new wiring diagram source. I'm gonna be out of pocket until late tonight or Id help you sort it out.
  9. Jan 16, 2017 at 2:25 PM
    #1249
    Brice
    Brice
    Texas
    Oh huh thought they had 2.
    Well I guess you're right... finding a new diagram is gonna suck. Oh well, off to the Internet.
  10. Jan 16, 2017 at 3:28 PM
    #1250
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    At least your wiring is accurate. ;)
  11. Jan 16, 2017 at 3:37 PM
    #1251
    Brice
    Brice
    Texas
    Haha guess so.
    How's the haltech goin?
  12. Jan 16, 2017 at 5:31 PM
    #1252
    Brice
    Brice
    Texas
    I may now be out of luck.
    I payed for $15 for a 2 day access to EWD's https://techinfo.toyota.com/
    And there diagram says 13(C) or E7 13... Which is the mysterious pin that does not exist on my truck.
    They say it's also supposed to be white. I'm gonna go look around the glovebox area and make sure the pin hasn't come out.
  13. Jan 16, 2017 at 6:19 PM
    #1253
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    What on Earth lol.
  14. Jan 16, 2017 at 6:59 PM
    #1254
    Brice
    Brice
    Texas
    Nevermimd, pin E7 13 IS there.
    I was looking at the connector incorrectly:oops:
    Well the URD harness is wired correctly, the o2 sensor is working correctly (tested by unplugging it) and the stock ECU has to working right to have made it this far, that only leaves the AEM at fault. I even wired the O21+ line directly into the stock harness with no luck. So either both my wiring diagram sources are wrong or the AEM if broken.
  15. Jan 16, 2017 at 7:14 PM
    #1255
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    No offense but based on your current track record I'd say it's more likely you wired it wrong just now than the AEM unit being defective :p
  16. Jan 16, 2017 at 7:31 PM
    #1256
    Brice
    Brice
    Texas
    Yeah, that's possible, however the o2 wiring is just one tap on another wire, so unless I'm still tapped into the incorrect wire (which is possible) than I have no idea what else to do.
  17. Jan 16, 2017 at 7:58 PM
    #1257
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Spray some unicorn farts on it. Magic will happen.
    j0shu4 and Brice[OP] like this.
  18. Jan 16, 2017 at 8:02 PM
    #1258
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Laptop that you saw, has gone off to NEVR NEVR land. Picked up a new Alienware one today. Should get another decade or so out of it. Lol. DBW synced up. Nice and easy after minimal wiring snafu. Annnnd then put it back to stock to drink a beer and watch some Roadkill.
  19. Jan 16, 2017 at 8:03 PM
    #1259
    Brice
    Brice
    Texas
    If only those came gluten free...
  20. Jan 16, 2017 at 8:04 PM
    #1260
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There is no gluten in mysticism.
    Brice[QUOTED][OP] likes this.
