Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Jan 16, 2017 at 8:05 PM
    #1261
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Nice, mine is still doing weird crap. From all of what I've done my wiring should be correct. And from all of the looking I've done, I should have a Wideband o2 sensor (50 state emissions and an auto). But tomorrow I'm gonna wire in that 10k resistor discussed non the install thread and see what happens.
  2. Jan 16, 2017 at 8:07 PM
    #1262
    Brice
    Brice
    Texas
    You never know man. I ate a leprechaun once and I was sick for days.
  3. Jan 16, 2017 at 8:08 PM
    #1263
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    A right bastard a meal it was.
    Brice[OP] likes this.
  4. Jan 17, 2017 at 8:48 AM
    #1264
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    For a 2001, the o2 signal wire is in postion E7 position 12 violet wire AF1+...
  5. Jan 17, 2017 at 9:05 AM
    #1265
    Brice
    Brice
    Texas
    E7 13 for OX1, white wire, on a 1999. And I made a mistake, the wire IS there, it just doesn't respond to voltages. I may have a narrowband so I'm gonna wire in 10k and see what happens because at this point I'm out of solutions.
  6. Jan 17, 2017 at 9:06 AM
    #1266
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    What is the date of MFG on the sticker inside your door jamb? Can you upload your EWD for the ECU or PM it to me?
  7. Jan 17, 2017 at 9:07 AM
    #1267
    Brice
    Brice
    Texas
    In other news I downloaded all ECU EWD's from 1995-2004. I'm also gonna download all 4runner, Tundra and T100 5vzfe applicable EWD's in case someone with a different 5vzfe equipped vehicle wants to do this.
    (And hopefully have more luck than me)
  8. Jan 17, 2017 at 9:09 AM
    #1268
    Brice
    Brice
    Texas
    As in when it was made? (Please excuse my lack in terms of terms lol)
    January, 6th 1999
    And I can send the EWD when I get back to the desktop :D
  9. Jan 17, 2017 at 9:14 AM
    #1269
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
  10. Jan 17, 2017 at 9:18 AM
    #1270
    Brice
    Brice
    Texas
    If I had the wrong sensor wouldn't something be way more off? Also the AEM thread on here says to use a 10k?
    And I bought my sensor off Amazon which told me it was the correct one (doesn't mean it is though) :D
    Edit: it appears I have the wrong sensor lol...
  11. Jan 17, 2017 at 9:21 AM
    #1271
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Post the part number... wideband is 234-9xxx. Narrowband will be 234-4xxx
    I doubt 1k vs 10k makes much difference... just see what others have been using with good luck.
  12. Jan 17, 2017 at 9:24 AM
    #1272
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
  13. Jan 17, 2017 at 11:09 AM
    #1273
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's a big problem solved. How'd you find out specifically?
  14. Jan 17, 2017 at 11:20 AM
    #1274
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    When I mentioned that just because it has 4 wires doesn't make it a wideband :-D
  15. Jan 17, 2017 at 11:52 AM
    #1275
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Probably.
  16. Jan 17, 2017 at 1:08 PM
    #1276
    Brice
    Brice
    Texas
  17. Jan 17, 2017 at 1:53 PM
    #1277
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Dude, big mistake going with Bosch primary o2... I'll cheap out on a few things, but your primary o2 isn't one.
    It does appear to be a narrow band sensor though, so if you wire in your resistor (I'd go with 1k, personally) and tap your o2 on the correct side (ECU side) o2 skewing should work then.
  18. Jan 17, 2017 at 2:09 PM
    #1278
    Brice
    Brice
    Texas
    Alright cool, I ordered a bunch of different resistors previously, so I can try both if need be, but I'll go with a 1k first.
    Also the Bosch vs Denso was only a dollar cheaper and considering Bosch's multiple affiliations with auto manufacturers and performance brands, I figured they were a safe bet. I dunno though, but so far @ 3000 some odd miles it hasn't quit yet.
  19. Jan 17, 2017 at 3:55 PM
    #1279
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Your wideband is a Bosch. ;)
  20. Jan 17, 2017 at 4:00 PM
    #1280
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I think OEM is Bosch.
