Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Jan 19, 2017 at 10:30 AM
    #1321
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Got to be a lot in the cam profiles. Wasn't there a guy in here who said that another engine's cams would fit? Those 3vz cams correct? If a dyno shows them to have a better high rpm stability then either swapping in the oem 3vz cams or a set of aftermarket 3vz cams would have great potential.
    Be pretty easy, considering that the 5vz is has a timing belt.
  2. Jan 19, 2017 at 10:32 AM
    #1322
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    You're assuming people are logical and rational LOL
    I trust the FIC completely from what I've seen/done. But I will look into the timing complaints that you're talking about to make some there's not a caveat I've missed.
  3. Jan 19, 2017 at 10:33 AM
    #1323
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Yeah he was doing a fully forged 5vz. Hasn't updated for a while, think he said his target was spring of this year. He did fit the cams and the crank in and said it was a perfect fit but I don't think he's run the engine yet.
  4. Jan 19, 2017 at 10:33 AM
    #1324
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    I remember a guy recently saying they fit maybe with a slight mod(not entirely sure on a mod being needed) And it's the 3vz-fe from a Camry NOT the 3vze truck motor
  5. Jan 19, 2017 at 10:34 AM
    #1325
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    :laugh:
    yota243[QUOTED] likes this.
  6. Jan 19, 2017 at 10:39 AM
    #1326
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct on Camry.
  7. Jan 19, 2017 at 10:40 AM
    #1327
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Didn't he post in this thread as well?
  8. Jan 19, 2017 at 10:43 AM
    #1328
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I think it was that brice kid
  9. Jan 19, 2017 at 11:00 AM
    #1329
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    That's who's tread you are currently posting in... we have gotten a bit off topic LOL
    Brice[OP] likes this.
  10. Jan 19, 2017 at 11:00 AM
    #1330
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    This dude^
    And I haven't gotten a chance to drive it yet. I finished inputting values at like 11:00 and then went to bed lol. I am gonna drive it later today though so we'll see how the new maps go.
    Torspd likes this.
  11. Jan 19, 2017 at 11:01 AM
    #1331
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Awesome, yeah that one.
  12. Jan 19, 2017 at 11:02 AM
    #1332
    yota243
    E.J.
    north Alabama
    I know...:anonymous:
  13. Jan 19, 2017 at 11:06 AM
    #1333
    Brice
    Brice
    Texas
    Lol what is even happening :goingcrazy:
    Torspd and vasinvictor like this.
  14. Jan 19, 2017 at 11:11 AM
    #1334
    Brice
    Brice
    Texas
    I gotta replace my cam seals (or atleast I think they are my oil leak) so maybe I'll get some of those 3vz-fe cams...
  15. Jan 19, 2017 at 11:13 AM
    #1335
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    I don't see what it would hurt, except midrange torque. If you do valve cover gaskets, DEFINITELY do cam seals, and use plenty of RTV in the appropriate corners.... I use RTV along the entire outside edge of the cam seals. Also, pull the half moons out and re-seal those with RTV.
  16. Jan 19, 2017 at 11:19 AM
    #1336
    Brice
    Brice
    Texas
    I did do my valve cover seals but neglected to do my cam seals when I did them...the valve cover seals are in good shape still so a bit of RTV and some seals should remedy my ability to bleed oil like Trump bleeds money
  17. Jan 19, 2017 at 11:57 AM
    #1337
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Did you get the cams yet??? :goingcrazy:
  18. Jan 19, 2017 at 11:58 AM
    #1338
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Think you'd need an entirely need head to run those cams anyway. Springs alone are like $1000. I'll stick with high torque, my truck will never run a tire under 31".
  19. Jan 19, 2017 at 12:00 PM
    #1339
    Brice
    Brice
    Texas
    But mine probably will :D #dragslicks
    Also if the stock valve train holds together at 5800rpm then swapping cams will just make it perform better at those higher rpms, or atleast that's what makes sense in my head. Plus I could just get valve springs for like $250 bucks and probably be just fine at the 5800rpm redline, which I'll never get to with an automatic
  20. Jan 19, 2017 at 12:00 PM
    #1340
    Brice
    Brice
    Texas
    Lol no it's been like 15 minutes
