Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Jan 19, 2017 at 12:10 PM
    #1341
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
  2. Jan 20, 2017 at 12:21 AM
    #1342
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Howdy all. I'm still alive.. just still sourcing parts for my engine.. Paychecks have been abysmal as of late so its just slow going (gotta love book-time).. Should have the other cylinder head soon... Then its pistons and out to the machine shop.. Building a 3.4 is a financial drain for sure. lol
    Also still haven't gotten much further than seeing if the cams fit.. No mods were needed to bolt them in, I think all i mentioned was the cam is notched for a distributor but that doesn't mean you need one, just leave the full moon cam seal on the head
  3. Jan 20, 2017 at 12:26 AM
    #1343
    Empty_Lord
    Dan
    P.S. let me know how the cams go. I know they'll fit. its the timing I'm curious about. i grabbed the crank and cam gears from the Camry in case it needs those... the 5vz gears might work though.. I haven't investigated very far because the old engine is in a million pieces.. Contemplating getting a junkyard 3.4 to toy with...
  4. Jan 20, 2017 at 12:38 AM
    #1344
    Empty_Lord
    Dan
    If I remember correctly back in the early 2000s there was a post made on custom tacos stating the factory crankshaft can't handle much more that 6k rpm before it fails.. might be a issue to consider before throwing rpms at your engine. Also I'm pretty sure stock valve springs would produce float at the rpm those cams allow.. I'd consider a full valve job with new springs and maybe convert to shim-less buckets if you honestly want to go through with it. Crank too...
  5. Jan 20, 2017 at 8:48 AM
    #1345
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    I'm not raising the redline, I'm just making the engine more efficient past 4800rpm were everything drops off, or atleast that's what I'm assuming will happen. I'm also curious to see what it will do to a dyno chart :D
    It will probably be a couple of months before I get them, since a friend who parts out engines is keeping is eye out for a 3vzfe to pull them from. But that's ok, it gives me enough time to tune and get a before cams dyno run and then an after cams run.
  6. Jan 20, 2017 at 10:28 AM
    #1346
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Dispel the rumors and show forth the data. That will be one of the most significant dynos for a 5vz.
    Brice[OP] likes this.
  7. Jan 20, 2017 at 2:23 PM
    #1347
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    dont think ive seen a cam swap dyno on one of these yet. Id like to see what happens to the power curve.
  8. Jan 20, 2017 at 2:28 PM
    #1348
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Exactly. It is 2017, and not one. Still a myth to the masses.
    If springs are of the same tension and height between the two engines, then it'd be a direct drop in. Minus setting up the lash.
    If it alters the mid range down a little, but has an overall flatter curve, then it will still be more worth it, as the turbo will complement the whole powerband.
  9. Jan 20, 2017 at 2:32 PM
    #1349
    Brice
    Brice
    Texas
    Exactly what I was thinking, if it can just pick up some more top end it'll be alot flatter overall, of course I don't know what mine looks like yet so I can't say where it'll improve but i'd assume it would dip in the same spots as the S/C and NA charts
  10. Jan 20, 2017 at 5:03 PM
    #1350
    Empty_Lord
    Dan
    Out of all my crazy ideas. Not once did I think to just keep factory redline but swap those cams in. Now you have me thinking.
    Brice[QUOTED][OP] likes this.
  11. Jan 20, 2017 at 6:28 PM
    #1351
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Why do you need more top end? Are you going to race this thing or something? For just driving around it seems like a waste money since you won't be up in that rpm unless your wot.
  12. Jan 20, 2017 at 6:55 PM
    #1352
    Brice
    Brice
    Texas
    I don't really need more top end, atleast not right now. And hey we may discover something worthwhile with this cam swap. I'm also doing this for the information, since people ask all about "3VZ-FE cams in a 5VZFE" but no one has actually (on record) driven a 5vz-fe with them installed. Also wouldn't it be great if they were better for a turbo charged application than stock cams? Of course no one knows yet how they'll do so in a few months I may eat my words, but we'll see.
    Yes. Hopefully into the 12's on slicks. I'd like to get 14.5-13.7-9 on the all terrains, but that probably wont happen without the true trac.
    Also Wouldn't all the rock crawlers and offroaders with S/C's benefit from 3vz-fe cams in theory, since, again, in theory they would raise top end power? And off road guys are usually in a low gear with high revs? Idk I dont offroad so idk how much itd actually help.
  13. Jan 20, 2017 at 7:13 PM
    #1353
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I need to start thinking about getting some cams made for mine soon... with dual valvesprings and stainless valves :anonymous:
  14. Jan 20, 2017 at 11:02 PM
    #1354
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Torque is king for off roading.
  15. Jan 21, 2017 at 12:39 AM
    #1355
    Brice
    Brice
    Texas
    @Clay_916 I read that hotrod article, and from what I gathered zero to very little overlap on the cams is desirable? That makes sense as the pressure from the compressor would just shove the intake charge out the exhaust. I'm thinking any gains from the cams will be mild at best simply because they are still stock toyota cams.
    I personally am expecting them to either bring power from 4800 up a bit higher in a plateau fashion or possibly allow power to continue past 4800. Either way it would be better for top end and drag racing.
    Oh yeah and I got those plugs in today or yesterday since it's 2:42am atm. What gap did you settle with?
    MrCrowntown and Torspd like this.
  16. Jan 21, 2017 at 1:01 AM
    #1356
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :anonymous: that is no simple accomplishment.
    MrCrowntown[QUOTED] likes this.
  17. Jan 21, 2017 at 6:05 AM
    #1357
    MrCrowntown
    Alyn
    Ky
    The cams will kill me im sure... the valvetrain exists already though! Thats the beauty of having LCE on your side!
  18. Jan 21, 2017 at 8:54 AM
    #1358
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    28 but I haven't pulled them to check carbon build up, no miss fires though.
  19. Jan 23, 2017 at 7:41 PM
    #1359
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    https://www.tacomaworld.com/threads/5vz-hp-limits-as-i-found-them.280864/#post-6984975
    Those are some reassuring numbers. I vaguely recall him saying his motor blew shortly after but I couldn't find the post on TW and didn't feel like checking the web. Maybe I'm thinking of another person. " 19 psi made 432 whp 555 wtq", this dude is insane. Pretty sure he said it's a .50 a/r, 50 mm Chinese turbo, dafuq. Oh yeah and did I mention it's a completely stock engine with some sketchy fuel adders and an fmu?
    Also an old for sale thread of a forged 5vz:
    "Level 1: 14psi 362.66 hp 471.52 tq
    Level 2: 18psi 410.30 hp 513.35 tq
    Level 3: 24psi 472.22 hp 599.18 tq"
  20. Jan 23, 2017 at 11:08 PM
    #1360
    Empty_Lord
    Dan
    if i remember right he made a post over on custom tacos selling the turbo kit because he returned the engine to stock for his i think mother to daily the truck (granted its been a year or 2 since i saw that)
