Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Jan 24, 2017 at 9:59 AM
    #1361
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I recall reading something like that although I'm not sure whom posted it. It would definitely be reassuring to know someone has boosted this engine to 350 wheel and not had catastrophe. I can't even imagine how high yours will be safe to with forged rods. Starting to seem more and more like you made the right decision with the 9:1 over 8.5, heck I'd even say upping to 10:1 would be safe with rods and high boost on e85.
  2. Jan 24, 2017 at 2:41 PM
    #1362
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Note to self....this is the year 2016 not 1983. The Chinese make good shit nowadays......
    MrCrowntown and Brice[OP] like this.
  3. Jan 24, 2017 at 2:47 PM
    #1363
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    2017 brah
    j0shu4[QUOTED] likes this.
  4. Jan 24, 2017 at 3:54 PM
    #1364
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    No. No. Still no. Not for export.
    Clay_916 likes this.
  5. Jan 24, 2017 at 9:15 PM
    #1365
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Sadly no e85 until I can run away from emmissions. Engines going to be limited until I can get around that.
  6. Jan 24, 2017 at 9:15 PM
    #1366
    Empty_Lord
    Dan
    But a friend got a job at the local awesome space of precision turbo... I might be doing Something special once I can...
  7. Jan 24, 2017 at 9:31 PM
    #1367
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Hey sorry for not responding to anything, I all the sudden stopped receiving emails for posts on here, not sure why.
    I remember that thread, he used an Apexi and something like a 12:1 FMU...
    Thanks @Clay_916 for the gap info
    After a bit of tuning on sunday, I got it pretty good at 8psi. However I have an issue when flooring it where open loop dumps in waaaaaaaaaaaaayyyyyyyyy to much fuel :rain: like 8:1
    Once open loop gets a bit leaner I think I'll go for 10 psi.
    One other thing is that my AEM UEGO gauge wont interface with the fic, but I think it's a ground issue. Also my LTFTs sit at around -21 when cruising in certain rpms, but my STFT never go beyond +10 and -10 when crusing (I know they can be better). It seems when I'm adjusting the fuel table using control+D and control+U one point up or down seems to be too insensitive making the STFT either lean or rich but never at or near zero, like: control+D = 3 to 7 STFT, but control+U in the same place would do something like -3 to -7.
    But now the truck runs great at 3/4 throttle and 10psi of boost builds at 3000 rpm.
    My plans now are to (listed in order of likelihood to happen before the end of the summer lol)
    1. Get a new boost controller. (Boost falls off in a weird way)
    2. Get some 2.5inch stainless pipe and a new bigger IC. I'm kinda tired of the clamps blowing off of the non bead rolled pipes.
    3. Get a locker
    4. Get caltracs
    5. I'd really like some scs F5 rims, but haven't decided on how I'd wrap them yet... probably a street tire of some sort
  8. Jan 25, 2017 at 1:32 PM
    #1368
    j0shu4
    I'd suggest 3" SS pipe for a turbo. Don't want any back pressure.
  9. Jan 25, 2017 at 1:57 PM
    #1369
    Brice
    Brice
    Texas
    I dunno, the turbo itself has a 2.5" outlet and I read stuff on guys making 700hp on 2.5" tubing... I don't think it matters at this sorta power level, and I don't have to worry about any new clearence issues with 3" piping if i stay 2.5" Plus 3 inch piping would create even more of a boost drop since the boost is "made" if you will from a 2.5" pipe
  10. Jan 25, 2017 at 2:29 PM
    #1370
    j0shu4
    Did you build your own downpipe? Most of us run the cx kit who's downpipe is 3". And our turbos output is 3". Guess I understand if your turbos output is 2.5".
  11. Jan 25, 2017 at 2:37 PM
    #1371
    Brice
    Brice
    Texas
    Wait... I'm talking about the Intercooler piping :rofl:
    My downpipe is the CX one adapted to 4-bolt, that feeds into a Flowmaster pro series straight through that dumps 45 degrees before the axle
  12. Jan 25, 2017 at 2:41 PM
    #1372
    j0shu4
    Lol. 2.5 for intercooler yes.....
  13. Jan 25, 2017 at 2:48 PM
    #1373
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Saw that coming. Lol
  14. Jan 27, 2017 at 10:02 AM
    #1374
    j0shu4
  15. Jan 27, 2017 at 10:18 AM
    #1375
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Get any more tuning done?
  16. Jan 30, 2017 at 5:52 AM
    #1376
    tony2018
    tony2018 Well-Known Member
    Is it possible to replace the drive shaft with a one piece?
  17. Jan 30, 2017 at 6:54 AM
    #1377
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Yes.
  18. Jan 30, 2017 at 7:46 AM
    #1378
    tony2018
    Is it ideal for lifted tacoma's?
  19. Jan 30, 2017 at 4:24 PM
    #1379
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Only issue is you get a little less ground clearance off road. Otherwise, I'd prefer it over the carrier bearing.
    @Brice, what do you mean "boost falls off in a weird way"? What waste gate do you have? Did you check intake/exhaust for leaks?
  20. Jan 30, 2017 at 7:05 PM
    #1380
    Bejabbers
    Bejabbers Well-Known Member
    Shane
    2001 Tacoma TRD DoubleCab 4x4
    3"SL 1.5"BL,2.5" exhaust,custom bumpers,Warn 8274,235-85R16's,Flex-a-lite Electric fans, AFE CAI, 18" Magnaflow, High flow Converter, 1.5" BL, Fabtech coilovers, AllPro Expedition leaf packs, Daystar 1.25" extended rear shackles, Billstein 5165 remote res rear shocks, Custom ARB style plate bumper, Singer 275Amp high output alternator, URD MAF sensor calibrator, Innovate MTX-L Wideband O2 sensor, ScanGaugeII, Tundra front brake upgrade, 3" extended braided stainless brake hoses, Cooper Discoverer ATW on Mickey Thompson Classic Baja Lock wheels
    Hey, just finished reading your entire thread, lots of good info.
    I recently purchased a CX racing turbo kit with a Turbonetics T04E-50, MAP-ECU3 and URD turbo port fueler with 310cc injectors.
    I was hoping someone on here could check out the turbo compressor map to let me know if it is a good match for the 5vz.
    Any help is greatly appreciated.
    j0shu4 likes this.
