Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Jan 31, 2017 at 8:42 AM
    #1381
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Looks a tad small but would work fine for a DD.
  2. Jan 31, 2017 at 8:55 AM
    #1382
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    What is your altitude, boost target? pressure ratio and mass air flow must be known in order to determine if this is properly sized for what you want to do.
  3. Jan 31, 2017 at 2:18 PM
    #1383
    Bejabbers
    Bejabbers Well-Known Member
    Shane
    2001 Tacoma TRD DoubleCab 4x4
    3"SL 1.5"BL,2.5" exhaust,custom bumpers,Warn 8274,235-85R16's,Flex-a-lite Electric fans, AFE CAI, 18" Magnaflow, High flow Converter, 1.5" BL, Fabtech coilovers, AllPro Expedition leaf packs, Daystar 1.25" extended rear shackles, Billstein 5165 remote res rear shocks, Custom ARB style plate bumper, Singer 275Amp high output alternator, URD MAF sensor calibrator, Innovate MTX-L Wideband O2 sensor, ScanGaugeII, Tundra front brake upgrade, 3" extended braided stainless brake hoses, Cooper Discoverer ATW on Mickey Thompson Classic Baja Lock wheels
    I hope I'm not hijacking your thread Brice.
    The altitude I will DD at is 1500ft, occasional trips can vary from 1500ft to 6000ft here in the mountains of British Columbia.
    I was going to start out with a pressure ratio of 1.7 to 2.0, hoping for 300-350hp at crank with 5-9psi of boost.
    Approximate mass air flow would be around 30lb/min at 1.7 ratio, and 35lb/min at 2 ratio.
    Can I determine what RPM the turbo would spool at based on the compressor map?
    Does anyone have any good info on wiring and tuning the MAPECU3?
    Thanks for the help
  4. Jan 31, 2017 at 3:55 PM
    #1384
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    There's a Mapecu3 group buy currently going on that ends this week if you're interested. Save you about $200
    https://www.tacomaworld.com/threads/mapecu3-feeler-possible-group-buy-af.458556/
    yota243 likes this.
  5. Jan 31, 2017 at 3:59 PM
    #1385
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
  6. Jan 31, 2017 at 5:57 PM
    #1386
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
  7. Jan 31, 2017 at 7:09 PM
    #1387
    boostedka
    James
    NM
    I had intended to but I recently decided to go with Megasquirt3
  8. Jan 31, 2017 at 7:44 PM
    #1388
    yota243
    E.J.
    north Alabama
    Thats funny i originally was gonna get the MS3 and madtaco talked me into the mapecu3... And i think at the same tine i talked him into the megasquirt. It looks unbeatable for the price as a standalone ecu... Good luck man
    boostedka[QUOTED] likes this.
  9. Jan 31, 2017 at 8:37 PM
    #1389
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
  10. Jan 31, 2017 at 9:32 PM
    #1390
    devinzz1
    devin
    2023 aclb trd or mt
    He doesn't mention anywhere what fuel mods/tuning hes running. Looks like 7th injector and meth injection anyways.
  11. Feb 2, 2017 at 10:09 AM
    #1391
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I hope that is the BOV fluttering, and not the compressor surging.
    MrCrowntown likes this.
  12. Feb 2, 2017 at 1:16 PM
    #1392
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Isn't there supposed to be a sophisticated bypass system in place on those dual charged systems. Looks like he's just boosting straight into the sc.
    Pulled my turbo off to replace with a smaller one and god damn the thing is still in excellent shape. No shaft play what so ever after 4000 miles. It's a CX GT35 with a journal bearing. The only thing wrong with it is the drain on the center housing is too small since it's not for a journal bearing.
    I would not hesitate to run one of these turbos again, at least not a JB. I've read a lot of bad reviews about their BB's being janky.
  13. Feb 6, 2017 at 5:51 AM
    #1393
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Thats just flutter dump from a shitty diaphragm BOV.
    https://youtu.be/nCj6Spwl1CU
    boostedka and Torspd[QUOTED] like this.
  14. Feb 6, 2017 at 5:56 AM
    #1394
    MrCrowntown
    Alyn
    Ky
    There has been discussion over the years as to wether you need a bypass valve, or if the CFMs from the turbo will actually reduce the load on the roots or screw style supercharger like blowinng on a pinwheel. This is supposed to negate the RPM limit of the supwrcharger as the bearings arent being over loaded in one direction (direction opposite of the force of compression) rater they are helping the engine rotate through the pully. In theory, it's a sound determination. Like auto gyro mode for your supercharger haha
  15. Feb 6, 2017 at 8:31 PM
    #1395
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    @Blackdawg
  16. Feb 6, 2017 at 8:32 PM
    #1396
    Brice
    Brice
    Texas
    I don't have any leaks, but my wastegate was constructed from home depot brass fitings, so im pretty sure its the culprit.
  17. Feb 6, 2017 at 8:57 PM
    #1397
    Brice
    Brice
    Texas
    Yup :D About a week or so ago lol... STFT are ok and LTFT are ok too, good enough for me.
    Nope! Not at all. I can't help with the super technical stuff since I haven't looked into all of it personally. But I probably should.
    And again for some reason I'm not getting any emails from this thread and idk why...I unsubbed then subbed back so we'll see
    I've set an EBC as my next buy for the build. I was thinking the GFB one.
    The truck pulls hard at all throttle points, and I fixed the super rich open loop issue. part throttle no/low boost (0-1.5 psi) AFRs are 13:1~ mid boost is like 12:1~ and full boost is 10.6-11.0
    I feel like those are safe AFR's for 8 psi currently.
    Current to-buy list by priority
    • EBC
    • SS intercooler piping.
    • Bigger IC
    • True trac
    • lowered a bit? (It feels strange going fast in something tall...)
    • Cal-tracs? tbd
    • F5 SCS wheels? tbd
    • Street tire? tbd
  18. Feb 6, 2017 at 9:00 PM
    #1398
    Brice
    Brice
    Texas
    Wow looks like he has a 2" to 1.5" SC pulley...But we know he's serious because of the out the hood exhaust.
    with a pulley that small I hope he has billet gears...
  19. Feb 6, 2017 at 9:47 PM
    #1399
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    shit were did you find a URD port fueler?
    You'll be outside the effective range of it. Its a bit small. Will spool super fast but probably choked off on the upper rpms.
  20. Feb 6, 2017 at 9:48 PM
    #1400
    Blackdawg
    Monte
    Wyoming/St. Louis
    No doubt. If he is on a 2.1'' pulley and just 4 psi on the turbo, he is looking at 18-22pis compounded....I don't think it'll last long without a fully built bottom end. Probably not super worth it without built heads either.
    But to all the haters. It IS in fact do able. Compound boost is great and works best with a roots type blower which the trd one is.
    I have seen a guy retro fit our blower onto an MKIII supra motor. His power curve was insane. And torque curve.
    Drove great too.
