Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Feb 7, 2017 at 2:33 PM
    #1421
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Just slower wear and tear...but still its preventable wear and tear.
    j0shu4[QUOTED] likes this.
  2. Feb 7, 2017 at 2:34 PM
    #1422
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Bad or not. That flutter makes me all giddy
  3. Feb 7, 2017 at 2:37 PM
    #1423
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    So you're saying if you have any surge at all it's an issue with the bov?
  4. Feb 7, 2017 at 2:41 PM
    #1424
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    or you have a turbo that is poorly matched to your engine, which is less likely.
  5. Feb 7, 2017 at 2:52 PM
    #1425
    Brice
    Brice
    Texas
  6. Feb 11, 2017 at 3:36 PM
    #1426
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Piston style BOV ftw
    Speedytech7 likes this.
  7. Feb 11, 2017 at 9:10 PM
    #1427
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    For the loooooooongest, I have wanted a Synapse.....
    MrCrowntown likes this.
  8. Feb 11, 2017 at 9:11 PM
    #1428
    MrCrowntown
    Alyn
    Ky
    Fastest reacting bov I have ever seen
  9. Feb 11, 2017 at 9:11 PM
    #1429
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Amen :bowdown:
  10. Feb 11, 2017 at 9:14 PM
    #1430
    MrCrowntown
    Alyn
    Ky
    Part of me wants to say F the EFR, and get the synchronic bov and their wastegate... Might be even more controllable than the tight little efr package.... if they havent casted my turbo by this week... I may have to pull that trigger
    :anonymous:
  11. Feb 12, 2017 at 12:52 PM
    #1431
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well the EFR comes with a BOV. Closer to the compressor outlet, the more efficient. No need for an additional, unless you want one.
    As for the w/g, all depends on your packaging requirements. Whether internal or external.
  12. Feb 12, 2017 at 3:22 PM
    #1432
    MrCrowntown
    Alyn
    Ky
    More efficient for blowing off, but still far away from the throttle plate. Thats where the synchronic bov really stands out
  13. Feb 20, 2017 at 9:54 PM
    #1433
    Bejabbers
    Bejabbers Well-Known Member
    Shane
    2001 Tacoma TRD DoubleCab 4x4
    3"SL 1.5"BL,2.5" exhaust,custom bumpers,Warn 8274,235-85R16's,Flex-a-lite Electric fans, AFE CAI, 18" Magnaflow, High flow Converter, 1.5" BL, Fabtech coilovers, AllPro Expedition leaf packs, Daystar 1.25" extended rear shackles, Billstein 5165 remote res rear shocks, Custom ARB style plate bumper, Singer 275Amp high output alternator, URD MAF sensor calibrator, Innovate MTX-L Wideband O2 sensor, ScanGaugeII, Tundra front brake upgrade, 3" extended braided stainless brake hoses, Cooper Discoverer ATW on Mickey Thompson Classic Baja Lock wheels
    Got the port fueler from a guy in Washington State who decided he wasn't ready to turbo his truck, he was worried about reliability.
    Should I consider looking for a different turbo, I only plan to run 9psi.
  14. Feb 20, 2017 at 9:57 PM
    #1434
    Blackdawg
    Monte
    Wyoming/St. Louis
    lucky.
    And all up to you. Not like our motors have a high rpm range anyways. I might go a touch bigger on the exhaust side.
  15. Feb 20, 2017 at 10:01 PM
    #1435
    Bejabbers
    Shane
    $1200 for the port fueler? Definitely didn't pay that. I thought it was only $200 before it was discontinued.
  16. Feb 20, 2017 at 10:03 PM
    #1436
    Blackdawg
    Monte
    Wyoming/St. Louis
    was 250ish.
    The last one on URDs site is FS for $1200
  17. Feb 20, 2017 at 10:19 PM
    #1437
    Bejabbers
    Shane
    Highway robbery!
    I was thinking to start with I may just install the CX headers and turbo without the intercooler, and rely on my Methanol injection and URD AFR and MAF calibrators for tuning up to about 7psi.
    I will monitor my fuel pressure and if it drops off I'll upgrade the fuel pump.
    If I still need more fuel then I'll install the MAP ECU and the turbo port fueler, otherwise I may sell them off if I'm happy as is.
  18. Feb 20, 2017 at 10:22 PM
    #1438
    Blackdawg
    Monte
    Wyoming/St. Louis
    You'll want a bigger fuel pump. Id just go with that right away. Probably run out of fuel with the stock injectors too.
  19. Feb 20, 2017 at 10:29 PM
    #1439
    Bejabbers
    Shane
    I have a Walbro 190 but I've been told to avoid them like the plague, so I will look into getting a Denso 950-0159 or the AEM that Brice bought.
    I have a set of RC Racing 310cc injectors but I've heard it's a pain to tune oversized injectors when not in boost.
    Either I tune the oversized injectors with the URD calibrators or go all out and install the MAPECU and port fueler.
  20. Feb 20, 2017 at 10:42 PM
    #1440
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    I am using stock fuel pump at 9psi (10.5psi peaks according logs) and running ultra rich 10.8 AFR FWIW
    No need to upgrade fuel pump for your goals.
