Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Feb 20, 2017 at 10:42 PM
    #1441
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not sure the URD stuff will work well enough. Id just go for the Map ecu. Dont' need the port fueler to use it.
  2. Feb 20, 2017 at 10:43 PM
    #1442
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    It's not a pain to tune oversize injectors at all. My 550s are no prob with AEM F/IC. Not even sure how these rumors get started.
    I guess injector tech used to be shit in its early days.
  3. Feb 20, 2017 at 10:47 PM
    #1443
    Bejabbers
    Bejabbers Well-Known Member
    Shane
    2001 Tacoma TRD DoubleCab 4x4
    3"SL 1.5"BL,2.5" exhaust,custom bumpers,Warn 8274,235-85R16's,Flex-a-lite Electric fans, AFE CAI, 18" Magnaflow, High flow Converter, 1.5" BL, Fabtech coilovers, AllPro Expedition leaf packs, Daystar 1.25" extended rear shackles, Billstein 5165 remote res rear shocks, Custom ARB style plate bumper, Singer 275Amp high output alternator, URD MAF sensor calibrator, Innovate MTX-L Wideband O2 sensor, ScanGaugeII, Tundra front brake upgrade, 3" extended braided stainless brake hoses, Cooper Discoverer ATW on Mickey Thompson Classic Baja Lock wheels
    Good to know, I will monitor my fuel pressure and go from there.
  4. Feb 20, 2017 at 10:55 PM
    #1444
    Bejabbers
    Shane
    There is a lot of misinformation out there that led me to believe that if I wanted to increase injector flow it would be better to let the stock ECU and injectors manage fueling under vacuum and use additional injectors to manage fueling under boost.
  5. Feb 20, 2017 at 10:59 PM
    #1445
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Yeah I've seen that stuff and I think it's mostly perpetuated by gadget to promote using his 7th injector system and port fueler systems. Maybe Injector tech was not as good as it is now though or maybe injectors were much more expensive, not sure. I have a $300 set of eBay "osidetiger" injectors and a $350 AEM FiC and it works like a dream.
    j0shu4 likes this.
  6. Feb 20, 2017 at 11:02 PM
    #1446
    Bejabbers
    Shane
    It sounds like there are more people using the AEM FIC to tune their turbo Tacos
    I am hoping someone out there has some experience with the MAPECU who can point me in the right direction for my base maps.
    I'm new to tuning and I don't have access to a dyno where I live.
  7. Feb 21, 2017 at 4:48 AM
    #1447
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Sorry didn't realize you already had map ECU.
  8. Feb 21, 2017 at 7:10 AM
    #1448
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    MadTaco461 likes this.
  9. Feb 21, 2017 at 7:53 AM
    #1449
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    I've been running the Walbro 190 since 2004 when I installed the SS FTC and larger injectors. I have never had any issues as well as the others that I have installed.
    I also have not had issues tuning for the larger injectors (318cc) either. Maybe you should try it first and see what you r own experience is.
    boostedka likes this.
  10. Feb 21, 2017 at 8:54 AM
    #1450
    elnip
    LC,NM
    Let me preface the above:
    I'm not a huge fan of the FTC, I have a AEM FI/C waiting to go in and think it will be a much better choice for tuning and will eventually dump the SC to go turbo.
  11. Feb 21, 2017 at 9:32 AM
    #1451
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    I have 650cc injectors and have no problems tuning with the AEM at all. My max duty cycle was 28% at 9:1 afr wot, lol so I'm well within what they can do, they were cheap too... And no issues with the AEM 320lph pump so far. If anybody else ends up using it I have a install thread.
    Thanks @Torspd for the text lol, I don't get email notifications anymore for whatever stupid reason... And unfortunately nothing new with the build aside from the fact my cam seal are still leaking oil
    Torspd likes this.
  12. Feb 21, 2017 at 9:47 AM
    #1452
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    I've been wanting to upgrade my fuel pump before turning up the boost... is the AEM fuel pump loud?
  13. Feb 21, 2017 at 10:17 AM
    #1453
    Brice
    Brice
    Texas
    Yeah but it sounds cool :D
    Mine is only loud after the truck warms up for whatever reason, but my exhaust sort of drones it out. You can't hear it at all in the cab.
  14. Feb 21, 2017 at 10:22 AM
    #1454
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    I don't notice it. The Walbro with the URD 7th kit was super loud though.
    Just turned up to 13 psi and this truck is rippin'. I'm strongly considering setting up my meth kit but can't decide if I want pre or post turbo. My turbo is on the small size flow wise so pre would be ideal but I don't want to damage this new $800 turbo I just bought since I'll probably just be running wiper fluid.
  15. Feb 21, 2017 at 10:34 AM
    #1455
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The pumps will be louder on high duty than low duty.
    Aeromotive has the stealth series pumps. Very quiet. My Walbro 485 LPH E85 pump is surprisingly quiet as well.
  16. Feb 21, 2017 at 12:21 PM
    #1456
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Good to know thanks for all the suggestions. Clay, why not a small nozzle pre and post? Better atomization and same flow larger nozzle.
  17. Feb 21, 2017 at 1:18 PM
    #1457
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    That's kind of what I was thinking. i think with dual injection I could lose my IC as well, or at least switch to a smaller one stuffed behind my grill.
  18. Feb 21, 2017 at 2:39 PM
    #1458
    Bejabbers
    Shane
    Sounds like a plan
    I think I'll start off using the URD AFR and MAF calibrators with the stock fuel pump, stock injectors and water/methanol injection for intercooling.
    I'll monitor my fuel pressure and AFR's and if needed I'll install the fuel pump and 310cc injectors.
    Then when I want timing control I'll swap out the URD tuners for the MAPCAL3.
  19. Feb 21, 2017 at 3:50 PM
    #1459
    Bejabbers
    Shane
    Curious what size exhaust to run with the turbo.
    Currently I have 2.25" cat back with 18" Magnaflow and high flow cat.
    I don't really want to replace the exhaust because it's fairly new and all SS so $$.
    The CX downpipe is 3", could I step it down to 2.25" or would this choke the flow too much?
    I thought too large of a diameter would take away torque due to reduced backpressure.
  20. Feb 21, 2017 at 3:54 PM
    #1460
    Blackdawg
    Monte
    Wyoming/St. Louis
    this is true in NA applications. With a turbo, you want very little back pressure so the exhaust fan can spin up faster. Too big for the turbo isn't doing you any favors, too little and you'll choke it.
    probably be okay with the 2.25 but 3'' would be better.
