Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Feb 21, 2017 at 3:55 PM
    #1461
    Bejabbers
    Bejabbers Well-Known Member
    Shane
    2001 Tacoma TRD DoubleCab 4x4
    3"SL 1.5"BL,2.5" exhaust,custom bumpers,Warn 8274,235-85R16's,Flex-a-lite Electric fans, AFE CAI, 18" Magnaflow, High flow Converter, 1.5" BL, Fabtech coilovers, AllPro Expedition leaf packs, Daystar 1.25" extended rear shackles, Billstein 5165 remote res rear shocks, Custom ARB style plate bumper, Singer 275Amp high output alternator, URD MAF sensor calibrator, Innovate MTX-L Wideband O2 sensor, ScanGaugeII, Tundra front brake upgrade, 3" extended braided stainless brake hoses, Cooper Discoverer ATW on Mickey Thompson Classic Baja Lock wheels
    I was also wondering, if you use MAF intercept with larger fuel injectors and take away fuel in vacuum by altering the MAF voltage that the Toyota ECU sees, will this make the ECU think there is less load on the engine and therefore advance the timing more?
  2. Feb 21, 2017 at 4:11 PM
    #1462
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Dont know for a fact but from my experience the timing advance is based mostly if not entirely on the knock sensor. The timing is pretty much always maxed out in vacuum anyway since you'll be running at least 91 with a turbo.
  3. Feb 21, 2017 at 4:17 PM
    #1463
    Bejabbers
    Shane
    Is there any worries about too much advance before 3000 RPM when the knock sensors are active?
    Would it be wise to retard the timing a bit below 3000RPM?
  4. Feb 21, 2017 at 4:33 PM
    #1464
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    What are you using to retard timing? My piggyback runs off MAP and works pretty well. I can imagine pulling timing off engine speed to be pretty ineffective. The biggest concern for me is part throttle boost and that is where the ecu cuts the most timing. 12 psi at 13.5 afr and I see 25 degree retard at most. Which is inside the stock ecu's range so it's not a huge concern. This is all at like 40-60F ambient though. As long as your afrs are rich-good you shouldn't have any significant detonation issues.
  5. Feb 21, 2017 at 4:39 PM
    #1465
    Bejabbers
    Shane
    I would use the MAPCAL3 to control the timing.
    I thought the Toyota ECU only monitors knock above 3000RPM so if you are making part throttle boost below 3000RPM you could have too much advance and the ECU wouldn't correct it.
    I will also have Methanol/Water injection start spraying progressively starting at 1psi which should help as well.
  6. Feb 21, 2017 at 4:43 PM
    #1466
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    I don't know a ton about it but I've never heard that about the knock sensor. Can you provide a source? From my experience detonation most readily occurs at high load and low rpms so that's why I'm scratching my head.
  7. Feb 21, 2017 at 4:48 PM
    #1467
    Bejabbers
    Shane
    Looks like I was wrong according to service manual it is monitored between 2000-5600RPM
    DI-204
    -DIAGNOSTICS ENGINE (5VZ-FE)
    464Author: Date:
    2001 TOYOTA TACOMA (RM835U)
    DTC P0325 Knock Sensor 1 Circuit Malfunction (Bank 1)
    DTC P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
    CIRCUIT DESCRIPTION Each knock sensor is fitted to the right bank and left bank of the cylinder block to detect engine knocking. This sensor contains a piezoelectric element which generates a voltage when it becomes deformed, which occurs when the cylinder block vibrates due to the knocking. If engine knocking occurs, ignition timing is retarded to suppress it.
    DTC No. DTC Detection Condition Trouble Area
    P0325
    No signal of knock sensor 1 to ECM with engine speed between 2,000 rpm and 5,600 rpm
    Open or short in knock sensor 1 circuit Knock sensor 1 (looseness) ECM
    P0330
    No signal of knock sensor 2 to ECM with engine speed between 2,000 rpm and 5,600 rpm
    Open or short in knock sensor 2 circuit Knock sensor 2 (looseness) ECM
  8. Feb 21, 2017 at 4:55 PM
    #1468
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Did you tap the threads on these? I think i'll be trying this this weekend maybe on my truck. But probably put the sensors on the block exterior as I don't wanna take off the blower and Intake.
    Brice[QUOTED][OP] likes this.
  9. Feb 21, 2017 at 5:19 PM
    #1469
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Go for it, it's fairly straight forward.
    You gotta take off the lower intake to get to the harness, and no the they thread right in :D Make sure you get SU1075 SPECIFICALLY. If you don't the resistance will be off and it'll throw a code potentially.
  10. Feb 21, 2017 at 5:20 PM
    #1470
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah damn. You can't just disconnect the harness without taking it off? was gonna buy a whole new harness and just leave the old one to die..haha
  11. Feb 21, 2017 at 5:22 PM
    #1471
    Brice
    Brice
    Texas
    I don't remember if you can get the the rear most plug where it splits... But if you can then go ahead, although I'd say you'll have to lengthen the new stock harness.
  12. Feb 21, 2017 at 5:22 PM
    #1472
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Thank god I was about to be real worried
  13. Feb 21, 2017 at 5:24 PM
    #1473
    Blackdawg
    Monte
    Wyoming/St. Louis
    was planning on it. Give it a go i suppose.
  14. Feb 21, 2017 at 5:31 PM
    #1474
    Bejabbers
    Shane
    No doubt, shouldn't be much boost below 2000RPM
  15. Feb 21, 2017 at 6:12 PM
    #1475
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    3"
  16. Feb 21, 2017 at 6:17 PM
    #1476
    Brice
    Brice
    Texas
    I didn't see this till now, but larger exhaust taking power is a myth, and a larger exhaust can significantly improve spool. Although I must say I tend to like the tone of exhaust through a smaller pipe...
    https://www.youtube.com/watch?v=_PVXvHkr-Vs&index=10&t=753s&list=PLGvTvFzdMg_O2T3UdUEt5dIHutSOu7srE
  17. Feb 21, 2017 at 6:18 PM
    #1477
    Blackdawg
    Monte
    Wyoming/St. Louis
    this is important. And better flow.
    Remember, a motor is just a giant air pump. When you add FAI you want as litte resistance as possible for the air to leave the motor because you're already forcing in the air to flow more.
    If that makes sense.
  18. Feb 22, 2017 at 7:35 PM
    #1478
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Yupp! EBay injectors too. Another false belief thinking Ebay or "Chinese" is garbage. Lol. And I think you're right about that Gadget dude.
  19. Feb 22, 2017 at 7:45 PM
    #1479
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Umm the urd injectors are $54 a piece so that would be $324 for a set for a v6 and urd has a tw discount of like 5% just sayin... Not bashin anything or anyone cuz i have plenty of ebay stuff in my build but i did go with urd for injectors because they came with an adapter harness ($11 a piece i think) and i got my fuel pump kit there also
  20. Feb 22, 2017 at 9:44 PM
    #1480
    Brice
    Brice
    Texas
    My ebay injectors were $254 at the time and were a direct plug in :D
