Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Nov 6, 2017 at 8:08 PM
    #1741
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Are those CA bushings uppers or lowers?
  2. Nov 6, 2017 at 8:34 PM
    #1742
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    When is this mod day going down?
    Brice[OP] likes this.
  3. Nov 6, 2017 at 8:50 PM
    #1743
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    If you order that kit it has both, but I'll warn you, you gotta follow the instructions and make sure you do everything correctly or you'll be doing a very tedious process twice (me) and it sucks. I was able to manipulate a 16 ton press to make everything go together though.
    boostedka[QUOTED] likes this.
  4. Nov 6, 2017 at 8:54 PM
    #1744
    Brice
    Brice
    Texas
    Well I finished most of the drivers side stuff Sunday (waiting on pwr steering rack boots) and I did the upper CA bushings on the passenger side today. I probably won't get a chance to finish til this Friday though, if you wanted to come and help :D. It would also give you the chance to see our shop. the lower control arm bushings are the worst since they have the most rubber to cook and you have to mark camber/caster. A full alignment will be needed afterwards :D
  5. Nov 7, 2017 at 5:10 AM
    #1745
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If it is Friday, I might be able come by. I'll keep you posted.
  6. Nov 7, 2017 at 1:21 PM
    #1746
    boostedka
    James
    NM
    Thanks for posting those links. I have been looking for some endlinks for a while. I didn't even think about RockAuto. One of my links has been missing a bolt for like 3 years now.
  7. Nov 15, 2017 at 3:50 PM
    #1747
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    lmao it took me over a year to pull the trigger but i have my turbo and headers ordered to start my build.
    couple questions.
    what exact plugs are you using?
    did the cx oil line kit come with a 90* for the drain (i tapped my pan near the front rather than side)
    is the od of throttle body 3"?
    il probably be looking this and others threads for reference when i get it.
  8. Nov 15, 2017 at 7:15 PM
    #1748
    Brice
    Brice
    Texas
    I used NKG V-power plugs gapped to .028 (still holding that gap)
    I used my own oil feed and drain setup so im not sure what the CX kit comes with (@StAndrew )
    And the 5vz throttle body is 2.75". 3" or 2.5" IC piping will work, just make sure you can buy appropriate adapters. I just used 2.5" off the turbo
  9. Nov 15, 2017 at 7:22 PM
    #1749
    devinzz1
    devin
    2023 aclb trd or mt
    what temp did you go with.
    i didn't order the full cx kit. i ordered the headers, 5vz oil line kit, and a turbo from them. i pieced together my own 2.5" intercooler setup. i order 2.5 to 3" silicone adapters. il give these a try first i guess.
  10. Nov 15, 2017 at 7:31 PM
    #1750
    Brice
    Brice
    Texas
  11. Nov 15, 2017 at 8:01 PM
    #1751
    devinzz1
    devin
    2023 aclb trd or mt
    thanks. hoping i can get everything together in one weekend before i leave for work again.
    im installing body mounts at the same time so the body will be raised a few inches which should make installing the headers a whole lot easier. I have the drain bung already welded when i resealed base pan. low boost and meth injection should get me around. not wiring in the piggyback until i source a 97 ecu.
    Brice[QUOTED][OP] likes this.
  12. Nov 15, 2017 at 8:03 PM
    #1752
    Brice
    Brice
    Texas
    Together in one weekend? And running? I'll give you my truck if that works out lol. Body mounts was a one weekend job for me when I did them, and the turbo stuff took me a full week in the summer. I wish you the best of luck, and dont forget to drop your starter on the passenger side to tighten down the manifold bolts :D
  13. Nov 15, 2017 at 8:05 PM
    #1753
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  14. Nov 15, 2017 at 8:07 PM
    #1754
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Takes 30 minutes just to figure out the process of jacking the cab.....lol
  15. Nov 15, 2017 at 8:23 PM
    #1755
    Brice
    Brice
    Texas
    No joke I used a 6x6 on the pinch weld...only fell off once haha
    Torspd[QUOTED] likes this.
  16. Nov 15, 2017 at 8:44 PM
    #1756
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    4x4 with a 2x4 here, to disperse the load on that pinch.
  17. Nov 15, 2017 at 9:48 PM
    #1757
    Brice
    Brice
    Texas
    I've been looking for a daily for awhile now, and after seeing porsches and other non toyota stuff...I think I'm gonna stay with something familiar.
  18. Nov 15, 2017 at 9:53 PM
    #1758
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good choice
  19. Nov 16, 2017 at 4:50 PM
    #1759
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    The CX kit oil return is crap. I found also that it was hard to clock the turbo how I wanted it as a 10an return was to big and hitting the turbo flange. I found an 8an hose and adapter and that was better.
    The TB is a bit bigger than 2.75. It's a really tight fit.
  20. Nov 19, 2017 at 10:44 PM
    #1760
    Brice
    Brice
    Texas
    Ok so my wheel hop is incredibly bad.
    In an effort to test what would happen, I flipped my overload leaf :luvya:. Lifted the rear like 2-1/4" - not ideal but I have deemed it temporary.
    I also don't see much room under there for a traction bar...
    I'm considering using the icon 1.5" aal without the overload and maybe minus an OEM leaf to see what happens with the hop, although it seems a traction bar may be the only fix.
    Any suggestions? @Torspd
