Brice's NA V6 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Brice, Jun 19, 2016.
  1. Sep 10, 2016 at 7:20 PM
    #581
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    How are your o2 sensors?
  2. Sep 10, 2016 at 7:34 PM
    #582
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    Idk how old they are and I'm no o2 specialist...so I honestly have no idea. I just don't understand why all the sudden they would stop working
  3. Sep 10, 2016 at 8:29 PM
    #583
    Brice
    Brice
    Texas
    Upon further internet investigation I'm thinking it IS the upstream o2 sensor.
  4. Sep 11, 2016 at 8:23 AM
    #584
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    After some reading I think if it were the o2 sensor you'd have a rich condition, not lean. I think it's pretty easy to test fuel pressure but I also think fuel pumps aren't very expensive and the stock one is pretty tiny so it may be time to upgrade.
  5. Sep 11, 2016 at 8:37 AM
    #585
    Brice
    Brice
    Texas
    I had read it could do either :notsure: but I agree it could also be the pump...just gotta see
    EDIT: ordered a new AEM 320lph fuel pump
    https://www.amazon.com/gp/product/B00A0J00UQ/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A7BGBK5DRMKFY
    Torspd likes this.
  6. Sep 11, 2016 at 7:44 PM
    #586
    Brice
    Brice
    Texas
    Managed to limp it home by unplugging the upstream o2. AFR's were 16.5-17 so not good... stayed off boost and it made it all ok. Lets hope a pump and new o2 fix my issue here...
    Bxnanaz likes this.
  7. Sep 12, 2016 at 7:11 AM
    #587
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How many miles does your old pump have?
  8. Sep 12, 2016 at 7:29 AM
    #588
    Brice
    Brice
    Texas
    Probably 172,000 miles
  9. Sep 12, 2016 at 9:12 AM
    #589
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yeah. Really taxed. I bet those brushes are worn really thin.
  10. Sep 12, 2016 at 9:29 AM
    #590
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Hey @Torspd what are your thoughts on URD's electronics? Their MAF and o2 sensor simulators allege to be able to run 2x larger injectors and easy to tune etc. reading through @j0shu4 s build and seeing he had his fic6 tuned at a shop for a pretty penny makes me consider URD route.
  11. Sep 12, 2016 at 9:31 AM
    #591
    Brice
    Brice
    Texas
    Could always tune yourself if you have the time
  12. Sep 12, 2016 at 9:31 AM
    #592
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Tuning shops average ~$90/hr. Doesn't matter the device. That being said, the tuning of the the MAF-Cal is fairly easy with the U-tune guide. For the turbo, I would get the MAF-Cal with the MAP sensor.
  13. Sep 12, 2016 at 9:38 AM
    #593
    Brice
    Brice
    Texas
    Would URD stuff be a better solution over the fic6?
  14. Sep 12, 2016 at 9:51 AM
    #594
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That depends on how capable each unit it. You'd have to look at the capabilities of both and compare. Then weigh that against your budget.
  15. Sep 12, 2016 at 2:29 PM
    #595
    Brice
    Brice
    Texas
    I just read some stuff @Gadget was saying on custom taco's about how the URD MAF calibrator can support 550 cc's, that makes me wonder if it can do 440's... If it can I'd be super interested since that calibrator is way cheaper than an AEM and harness. (doubt he'll respond but eh wth)
  16. Sep 12, 2016 at 3:15 PM
    #596
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    The fic6 looks like a nightmare to wire, most people don't even speak of the wiring without mentioning a boomslang, as if it's a necessity. From what I can gather I'd say the URD stuff is capable at under 10 psi and even beyond that it's debatable. That said though the hardware itself is about on point with a fic 6 since I think you also need the o2 simulator to do any real tuning in closed loop? So there's a little over $400. The fact that URD specializes in Toyota is a comforting one as well. Ah, what to do..
    Are Supra injectors 550? I think URD kit's them with the MAF cal if you ask so that's gotta mean something.
  17. Sep 12, 2016 at 3:23 PM
    #597
    Brice
    Brice
    Texas
    I read that stock TT supra's have 440's but idk... And IIRC an o2 simulator is to skip having a cat and not popping a CEL code. An o2 calibrator is what you would use to tune the o2 on older vehicles and a AFR calibrator is what you use on new tacomas with the primary wideband sensor.
  18. Sep 12, 2016 at 3:34 PM
    #598
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
  19. Sep 12, 2016 at 3:38 PM
    #599
    Brice
    Brice
    Texas
    The AFR and MAF is what Im talking about and is what tacomas with wideband sensor use
    The o2 and MAF is what older tacomas with non wideband o2 sensor would use. MAF cal is for open loop and AFR/o2 cal is for closed, the way I understand.
    gray223 likes this.
  20. Sep 12, 2016 at 4:25 PM
    #600
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You want to be able to adjust timing as well.
