Bricked truck, ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by urban, Dec 2, 2017.
  1. Dec 2, 2017 at 3:32 PM
    urban
    urban [OP] Well-Known Member
    Illinois/Michigan
    12 DCLB sport OME lift
    305/65r17's on 17x9.5 Rotiforms Cab mount chop 4.10 gears Detroit true track OME 885's Dakars Camburg UCA's Undercover SE Weathertech liners and visors Black headlight mod Debadged Rock Blokz mudflapps (oversized)
    So I'm trying to help a friend out with his truck. I was hopping someone might be able to help me narrow down where the electrical issue might me. It's a 2010 Trd offroad by the way.
    So he pulled out the electrical box under the dash to get to the headlight relay I think, and in the process I think he damage a pin or pulled a wire out of a crimp. He has cab interior light, headlights, backlight in cluster, door ajar light in cluser, and the security light in dash by passenger seat air bag indicator. Other than that, the tcluster, dead, odometer doesn't come on, truck won't start. Unable to connect with scanner. All fuses checked and truck worked fine before he disconnected battery and installed the new light relay.
    My leading theory is that the ecm power or ground has been damaged. That or possibly something to ignition, so the mechanical switch works but maybe the transponder isn't getting power? These are the first things I was gonna try and confirm power and grounds on.
    Open to suggestions or if anyone can pinpoint this behaviour better?
    Thanks.
  2. Dec 2, 2017 at 3:33 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Main fuse?
  3. Dec 5, 2017 at 12:25 PM
    urban
    Illinois/Michigan
    Solved.
    He managed to pull the ignition connector up inside the column off. I guess on a whim he pulled it apart to check and found it.
  4. Dec 5, 2017 at 12:47 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Wow. That is some trick. Those don't come off easy.
  5. Dec 5, 2017 at 3:08 PM
    urban
    Illinois/Michigan
    Yea, I wasn't there. No idea how.
