Bridgestone REVO 2
Discussion in 'Wheels & Tires' started by TRDsport253, Sep 28, 2011.
  1. Oct 3, 2011 at 4:36 PM
    YotaMark
    YotaMark Well-Known Member
    Mark
    Mentor, Ohio
    08 Tacoma 4 cyl 5 speed 4X4
    Rear Gate security Mod (although I seldom take my eyes off it) "Harsh Ride" Shocks and Springs TSB performed by "Me" New Cooper Discoverer AT3s 265/75R16s (fit well) Front "Tacoma Mike" light mod! Rugged Ridge floor mats. Bought another set of D rings and installed them in my wheel well. Perfect! Just hit the big 6000 Miles 12/19/11, Installed an alarm system to go with my factory power door locks 1/21/12
  2. Oct 4, 2011 at 1:48 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  3. Oct 4, 2011 at 2:06 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    If you want to carry heavier loads, or want to travel on harsh roads, then the best tires are the LT tires, as they are tougher on the roads than the P tires. If you just want to ride on the highways, and if there is nothing much to tow or carry, then the P type is the best choice.
    P tires refer to Passenger tires and LT refers to Light Truck tires. One of the main differences that can be noticed between the two types of tires is that the LT tires are not as flexible as the P tires.
    When comparing their durability, the LT tires are more durable than the P type tires. Moreover, LT tires are stronger when compared to the P types. LT tires ride rougher than the P tires, which ride smoother on the roads.
    Another difference that can be seen between the two types, is that the Light truck tires come with maximum inflation. Unlike the Passenger tires, the Light Truck ones are used for carrying more loads. LT tires have a load range of 10 ply, whereas P tires only have a 4 ply load range.
    Light Truck tires are made of more aggressive treads than the Passenger type tires. LT tires will give a more stable feeling on the road.
  4. Oct 5, 2011 at 12:01 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
  5. Oct 5, 2011 at 4:38 PM
    YotaMark
    Mark
    Mentor, Ohio
    I thought the car tires are 3 ply and the LT are 4 ply tires but dont quote me. LT tire handle more weight for towing and loading.
