Brief Neutral Feeling
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Musubi3, Nov 21, 2016.
  1. Nov 21, 2016 at 1:07 PM
    Musubi3
    Musubi3 [OP] Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I tried searching for a similar case, but couldn't find any on here.
    My Truck: 2017 TRD OR, Auto Trans.
    Symptom
    When S-Shifting to 3rd gear at around 60 mph going downhill (to engine brake), I feel a very brief moment of what feels like a disconnect between the engine and transmission. Like a neutral feeling. This happens shortly after the transmission engages 3rd gear.
    It doesn't happen all of the time.
    My RPM's are about 4K. The engine speed slowly drops from 4K, then I feel that brief disconnect. It's almost like the truck was thinking of shifting, but didn't.
    As it's occurring, there's no drop in RPM's. After it occurs, there's no increase in RPM's. It's just a weird little feeling and not sure if I'm just making a bigger deal than I should.
    Where I live, 55 MPH is the speed limit on highways and sometimes I downshift to 3rd to engine brake when the slope gets steep enough. Once it happens in 3rd gear, it won't occur again unless I shift out of 3rd and back into it.
    I've already done the TSB's (including REV1) for the shift enhancements and had my transmission fluid checked and filled at 300 miles of the odometer (3/4 quarts low).
    I had this from the day I brought home the truck.
    Honestly, it's something minor in comparison to other transmission quirks, but I wanted to find out if others have experienced this. Either way, I have an appointment for Toyota to check it out next week. Perhaps I just don't know enough about auto transmissions, but I haven't felt this in my other auto trans Tacoma's (2003 and 2006).
  2. Nov 21, 2016 at 2:32 PM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    it's the holiday season, even the toughest trucks can sometimes feel sad and disconnected.
    George1441 and jkm25 like this.
  3. Nov 21, 2016 at 4:05 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    :rofl::rofl::rofl::rofl:
    vuTron[QUOTED] likes this.
  4. Nov 21, 2016 at 4:37 PM
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    This is 4th gear oscillating in and out of torque converter lockup. It's not right.
    It feels like a 4.5 gear, then it shifts back to 4th then back to 4.5, then to 5th around the mid 50s
  5. Nov 21, 2016 at 4:40 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    mine does the same thing....you described it perfect....
  6. Nov 21, 2016 at 4:40 PM
    scornwel
    Fort Worth
    None
    This is undesirable, but I'm unsure if it's bad for the trans. My gut says it's ok.
  7. Nov 21, 2016 at 4:42 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Why are you downshifting to 3rd? Brakes are cheap, engines and transmissions aren't
    crymes likes this.
  8. Nov 21, 2016 at 4:42 PM
    scornwel
    Fort Worth
    None
    So 4th gear goes into some semi analog mode. Strange for sure. Damaging, not sure
  9. Nov 21, 2016 at 4:43 PM
    scornwel
    Fort Worth
    None
    can you explain this? I'm not down shifting
  10. Nov 21, 2016 at 4:44 PM
    Aussiek2000
    2016 Offroad AC
    I'm referring to the OP.
  11. Nov 21, 2016 at 4:47 PM
    scornwel
    Fort Worth
    None
    rgr
  12. Nov 21, 2016 at 4:51 PM
    scornwel
    Fort Worth
    None
    At least Toyota is trying. I've been critical of the engineers, but they are trying. Makes me want to ride this out. It is getting better. Give Mike some props for working this.
  13. Nov 21, 2016 at 5:29 PM
    Musubi3
    Big Island
    I suppose it's something I've always done. A habit I guess. Living on the Big Island in Hawaii, I'm always going up or going down a slope of one of the mountains. Some stretches are fairly steep and long and know of people's brakes failing is some areas. So downshifting in those areas help save the brakes from giving. Otherwise, shorter areas, I agree brakes are the reasonable option.
    Thanks for your input. Did you mean 3rd gear oscillating in and out of TC lockup?
    For what's it's worth, this only happens in 3rd gear. Not in any other gear. The transmission is definitely warmed up. But no matter cold or warmed, it happens. Not all the time.
    It doesn't seems like it's getting worse or better. It could just be a quirk with the trans.
    Edit: Didn't catch it earlier. Are you getting the same thing in 4th gear?
    3rd gear as well? Are you downshifting for the same reasons? Just curious.
  14. Nov 21, 2016 at 5:39 PM
    scornwel
    Fort Worth
    None
    Mine is mostly in 4th gear. If you're getting this in 3rd then that is odd.
    Can you drive and confirm it's 3rd?
  15. Nov 22, 2016 at 8:49 AM
    Musubi3
    Big Island
    Tried it again this morning. Shortly after being shifted into 3rd, there's a short neutral feeling. Happened twice.
    It's not getting worse or better since I got the truck. It could just be normal. Thanks for your feedback. I'm taking it into Toyota for a determination next week.
  16. Nov 22, 2016 at 9:40 AM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    i live on maui and use S mode most of the time and just like you when starting to go up a hill i down shift when i want. i find the issue you described to happen a lot when slowing down for traffic or to make a turn then when i give it gas to speed back up is when it occurs.
  17. Dec 6, 2016 at 11:05 AM
    Musubi3
    Big Island
    Wanted to post an update to this since I was the OP with the perceived issue. The following is what I received back from Toyota:
    "when using engine braking the computer will apply and release the selected solenoid as needed for engine braking. That is most likely what you are feeling and will be normal."
    I took the truck in for a scheduled test ride with one of the Service Advisors. None were available, but was told to email the problem to Toyota. This was their response.
