Bright lights
Discussion in 'Lighting' started by Patang35, Mar 11, 2023.
  1. Mar 11, 2023 at 5:54 PM
    Patang35
    Patang35 [OP] New Member
    Michael
    1997 Tacoma
    Bright lights quit working, bulbs are good, can make them come on with power probe. Could it be the switch in the column or is it a short and where is there a common place for a short?
    Thank you
  2. Mar 12, 2023 at 8:58 AM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Is this for your '97? If the filament is intact and you can get highbeam filament to energize, then check the fuse box. There ahould be a 10Amp fuse for the highbeam circuit. If the fuse is blown, you may have a short circuit somewhere in the wire harness. Either from chafing, or animals chewing on the insulation.
  3. Mar 13, 2023 at 10:20 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to the forum. If your fuse is good (double check by swapping, not just visual) then I’d look at your high beam relay. At 26 yrs old a relay failure would not be uncommon.
    Toy_Runner likes this.
