BRIGHTER BULB THAN 168
Discussion in '1st Gen. Tacomas (1995-2004)' started by scriber007, Nov 11, 2010.
  1. Nov 11, 2010 at 9:38 AM
    scriber007
    scriber007 [OP] Well-Known Member
    I read it here somewhere before you can swap the 168 corner parking light bulb, so it is brighter. I can't remember the the alternative bulb to replace it with. I've tried searching pls. help.
  2. Nov 11, 2010 at 9:49 AM
    03DBLCABTACO
    03DBLCABTACO Well-Known Member
    Dan
    MAGNOLIA,TX
    Silver 2010 doublecab sr5
    Bilsteins at 2.5 stock coils up front,tsb springs rear with 5100s,fog light any time mod, 265/70/16 Yokohama geolanders.
    i used a bulb from a gm pickup 3rd brake light.. do not remember #.. do not use in lic lamp though it will melt housing.
  3. Nov 11, 2010 at 9:55 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
  4. Nov 11, 2010 at 11:00 AM
    scriber007
