brighter corner light?
Discussion in '1st Gen. Tacomas (1995-2004)' started by socal19, May 27, 2010.
  1. May 27, 2010 at 8:01 PM
    socal19
    socal19 [OP] TACOMA03
    California
    03 tacoma pre runner
    2.5" Front spacers, 16inch wheelers steel wheels on 265-75-R16 BFG All Terrain, N-FAB prerunner bar, Flowmaster Exhaust
    Hey guys I wanted to know I have silverstars on my truck and there bright I have clear corners on my truck and I installed the stock white bulb on it but there not bright at all is there any other light I can get to make it brighter I believe the stock light is a 168 bulb?
  2. May 28, 2010 at 3:38 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    The 921 (18 Watt) and 922 bulbs (12W) plug right in. You should be able to find them in both white and amber. I started with the 922 in white and then switched to the 922 in amber. I have stock clear/amber corner plastic.
  3. May 28, 2010 at 3:57 PM
    socal19
    California
    Ok so it won't do anything like blow if I go from the 168 stock bulb to the 921 white
  4. May 28, 2010 at 5:19 PM
    mtucker
    Escondido, CA.
    03 Prerunner DC
    It should not. I and others have been running the 921 and 922 bulbs for a long time. You will feel the corner lens get warm from the increased heat, but I have not had a problem with fuses blowing or overheating the plastic.
    Going to the 18W bulbs (instead of the stock 5W) only draws about 1 Amp more for each corner.
  5. May 28, 2010 at 5:31 PM
    socal19
    California
    Ok man thanks alot
