Brighter headlights?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaEli, Feb 9, 2020.
  1. Feb 9, 2020 at 8:18 AM
    TacomaEli
    TacomaEli [OP] Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    What headlights do you guys run? Wanting something a little brighter. I bought some Sylvanias on ebay but I think they might be counterfeits because they suck.
  2. Feb 9, 2020 at 8:25 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Everything you need is here:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    If you scroll down in the thread there are output comparison charts and best options for stock wattage with no harness vs high wattage bulbs that require a standalone harness.
    Synvanias are not a good choice for a performance bulb, they provide whiter light but not more output and often less than stock.
    License2Ill likes this.
  3. Feb 9, 2020 at 8:25 AM
    Old n' slow
    Old n' slow Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    Just a thought........if you still have original housings just make sure the plastic isn’t cloudy all the way through, otherwise no bulb will work adequately.
