Brighter whiter halogens. 2017 off road.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kjpstorm73, Sep 13, 2018.
  1. Jan 13, 2019 at 9:11 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The highest output and whitest non-fully coated H11 is the GE Megalight +130. They have higher lux intensity than any other performance bulb I’ve tried, including against H9s. And I’ve tried many performance bulbs. Their color is ~3500k. You can see a comparison in post #29 here:
    https://www.tacomaworld.com/threads/headlight-upgrade-2017-trd.575174/page-2#post-19035062
    MCDavis and pinochle like this.
  2. Jan 13, 2019 at 9:16 AM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    There are likely few members on here that have the proper body, lens, and know how to do that. That said, I agree that taking pictures of bright white lights is meaningless because halogen, LED, and HID are all going to look fairly similar from that angle.
    If LEDs weren’t satisfactory, I gotta ask.. did you aim them? Mine still aren’t where I want them, but I feel they’re a touch low in my aiming. Going to pull her car in front of mine and aim them just below her side mirrors vice using the ‘center of your housings to the wall, back up 25 ft, aim’ method.
  3. Jan 13, 2019 at 11:11 AM
    Dee1seven
    Dee1seven Well-Known Member
    RVA
    '17 DCSB TRD OR - Quicksand
    '15 TRD Pro Bilstein Suspension HS 3 leaf AAL TRD PRO Wheels 285/75r16 BFG KO2’s Truxedo Soft Roll Up cover
    I run Nokya 3800 65w H9 (modified) for my lows and just added STi-R clear lenses to the stock projectors while I was doing my BHLM, they match the DRL perfect. I tried to put the same bulbs on my highs but they were just as yellow as the stock bulbs so I just kept the stock on the highs.
    I also run these same bulbs on my T4R.
