Brightest headlights..?
Discussion in '1st Gen. Tacomas (1995-2004)' started by WVTaco12, Jan 17, 2018.
  1. Jan 17, 2018 at 5:01 PM
    WVTaco12
    WVTaco12 [OP] Well-Known Member
    Cody
    West Virginia
    2013 TX Baja
    Ok, so I think these retrofit headlights are awesome looking and I’m seeing that people are getting some insanely bright setups with them. As cool as I think they are, I don’t want to spend that much money on my headlights. Unless I’m missing something and that can be a cheap mod...?
    So here’s my question: what is the brightest, most cost-efficient method to getting the brightest, best look out of my headlights? I’m not opposed to getting a different housing if I have to, but didn’t know what everyone was running. Any suggestions. Looking for bright! I’m noticing a slight shadow in front of my truck early in the morning and late at night. Mine are toooo dim.
    Help!
    -Cody
    seniorredwood likes this.
  2. Jan 17, 2018 at 5:14 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    The Philips Xtreme Vision H4 bulbs are a good stock wattage replacement. As far as headlight housings, stick with OEM unless you're gonna do a retrofit. You can buy upgraded wiring harnesses to run higher wattage bulbs as well, but it's expensive, and could get you a good chunk of the way to a retrofit at that point if you were to do it yourself.
    https://www.tacomaworld.com/threads/proper-headlight-upgrade.407879/
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-not-led-or-hid.398066/
    Keep on Truckin' likes this.
  3. Jan 17, 2018 at 5:16 PM
    03 NIGHT TACO
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Or if better lighting directly in front of your truck is what you want, you could look into getting some fog lights. Just make sure they have a proper fog light cutoff of you'll blind other people (no offroad lights).
    The Rigid Industries SAE Fog Lights are great, but are expensive at almost $200.
  4. Jan 18, 2018 at 7:43 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    silverstars. Sorry, can't have the brightest and cheapest at the same time. Pick one.
    devinzz1 and Keep on Truckin' like this.
  5. Jan 18, 2018 at 7:46 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    If you go with Silver Stars, be prepared to buy them again on a regular basis. Every time I've run them I was replacing them every 6-8 months.
    Rocan and 03 NIGHT TACO like this.
  6. Jan 18, 2018 at 7:47 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Osram Night Breaker H4 - 12V-60/55W @ Xenon Depot .com- "stock" Replacement -No wiring upgrades needed
    DerbyCityTaco and XenonDepot like this.
  7. Jan 18, 2018 at 7:51 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I never had this problem... did you clean the bulbs before install? Did you touch the glass with your fingers?
  8. Jan 18, 2018 at 7:53 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    FWIW you can get knockoff Mini H1s on Amazon for like $30. Then get cheap relay, HIDs, and ballasts. Though you are really pushing it with the quality/longevity of the components. Best to buy once. But here's some options on the cheap... total cost $63. How long these parts last or how good they are... who knows.
    Projectors Mini H1 knockoffs $23
    https://www.amazon.com/Nilight-Mini...=1516290872&sr=8-1&keywords=mini+h1+projector
    H1 HID kit $30 (get 4300k as this is the best output)
    https://www.amazon.com/dp/B01H8S89PY/ref=twister_B00WZSFFIC?_encoding=UTF8&psc=1
    H4 bixenon Relay $10
    https://www.amazon.com/NEX-Harness-...8&qid=1516291047&sr=1-5&keywords=h4+hid+relay
  9. Jan 18, 2018 at 7:55 AM
    Noelie84
    Noel
    Wales, Maine
    I've tried cleaning them first, not cleaning them, made no difference. And no, no touchy da glass. Silver Stars don't last because they're so bright. The way that they get the extra light output is by burning the filament at a higher temperature. The higher the temperature the shorter the filament life, so they burn out after a fairly low number of hours. I do a fair amount of driving at night, so they don't last very long for me.
  10. Jan 18, 2018 at 8:05 AM
    Rockbaron1
    Rockbaron1 Well-Known Member
    Pat
    03 Tacoma
    everything
  11. Jan 18, 2018 at 8:08 AM
    Keep on Truckin'
    Jarvis
    Indiana
    I just had my Silver Star Ultras both burn out within 2 days of each other but after 6 Years of DD use. Still going strong in my other truck after 10 years DD use.
  12. Jan 18, 2018 at 8:12 AM
    Noelie84
    Noel
    Wales, Maine
    That's remarkable. The only set of Silver Stars that I ever had that didn't burn out before the 1 year warranty was up were the ones that were in the truck when I traded it in. :laugh:
  13. Jan 18, 2018 at 8:24 AM
    Clearwater Bill
    Billy
    Largo Florida
    Good for you! And always remember 'bright' doesn't always mean usable light. Kewl LEDs, halos, black out stuff and all the other geewhiz stuff are just that. Geewhiz.
    1) if your OE lens are not pristine, as in 'like new', but yellowed/hazed like most several year old vehicles are, cleaning or better, replacing them will get you instant results. With an improved daytime appearance as well.
    2) are they aimed per specs? Most aren't. Or I should say too many aren't. Particularly if the truck is modded in anyway with lift/tires, etc.
    3) Let's see if lighting guru @crashnburn80 might have a suggestion on an optimal PnP upgrade for you.
    Even though this thread is 2nd gen based, there is some good learning to be had here.
    WVTaco12[QUOTED][OP] likes this.
  14. Jan 18, 2018 at 8:38 AM
    zbadboy
    zbadboy Well-Known Member
    Arizona
    1998 Tacoma Xtra Cab V6 Auto TRD
    Palomino Camper
  15. Jan 18, 2018 at 8:49 AM
    Rockbaron1
    Pat
    03 Tacoma
    everything
    I never claimed they are dot approved but then again
    Neither are any of the HID options
    Edit; didn't realize i quoted twice
  16. Jan 18, 2018 at 9:23 AM
    zbadboy
    Arizona
    Palomino Camper
    Never Claimed you Claimed anything......simply added to your post!:oops:
  17. Jan 18, 2018 at 10:25 AM
    WVTaco12
    Cody
    West Virginia
    2013 TX Baja
    Thanks for the responses so far. To answer a couple of things - my housings are clear and almost new. The front clip had to be replaced right before I bought the truck in July (deer damage). I haven’t actually checked the aim of them, per spec (didn’t know there was a spec!). I’ve also run the Silverstars in the past; the most recent ones I used were the Silverstar zXe bulbs. I always wear disposable, clean gloves and never touch the glass. I’ve never (knock on wood) had to deal with super premature burnout of them.
    I really want to stick with a plug and play option. I’m not completely against upgrading the harness and enabling more light that way, but I’m pretty crunched for time.
    Side note: do you experience lighting issues (blinkers not working, bulbs lighting when they’re not supposed to, etc) in these cold conditions? I’ve never really had much issue before, but my little 02 TRD work truck is keeping me on my toes with little issues around every turn.
  18. Jan 18, 2018 at 10:36 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    if you want plug and play then you're limited to whatever you can buy at Autozone. Sorry.
  19. Jan 18, 2018 at 10:53 AM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    WVTaco12[OP] likes this.
  20. Jan 18, 2018 at 10:53 AM
    WVTaco12
    Cody
    West Virginia
    2013 TX Baja
    Yes and No. Amazon has a large variety :bananadance:
    But what about LED bulbs...I’m finding direct 9003 replacements. Do they need any special upgrade or can I try those?
