Brightest led bulbs on the market for turn signals/brake lights/ reverse lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by SkunkMan17, Jan 29, 2019.
  1. Jan 29, 2019 at 7:55 AM
    SkunkMan17
    SkunkMan17 [OP] Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    trying to find the best type of led for reverse lights, turn signals or brake lights. I’m honestly tired of buying lights of Amazon or eBay that have the same amount of light output as a cheap Chinese one that I got from my friend. I’m trying to find the best option for led’s that have the most output possible. I’m also not looking to spend over 25$ on them, I would rather ask on here and see if anyone has some good led light recommendations with some before and after pictures. Thanks y’all.
  2. Jan 29, 2019 at 8:46 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    VLEDs - You get what you pay for. In this case, quality, and no bogus lumen claims.
    Budget option - SuperbrightLEDs. Cheaper, but again no bogus lumen claims. The lumens they say the product has is the lumens it has. Not some false claim of 20000 lumens per bulb.
    MESO and rogerman like this.
  3. Jan 29, 2019 at 8:50 AM
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    x2 on superbrightleds.com They are so easy to order from and ship fast.
  4. Jan 29, 2019 at 9:03 AM
    SkunkMan17
    Owen
    Montana
    1997 Tacoma RC 4x4
    alright! Thanks y’all!
  5. Jan 29, 2019 at 9:05 AM
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    Is there a set of front and rear turn signals that don't hyperflash without resistors? Have the ones built in?
  6. Jan 29, 2019 at 9:07 AM
    SkunkMan17
    Owen
    Montana
    1997 Tacoma RC 4x4
    Your able to get a plug and play resistors that don’t require you to get a new flasher. But running multiple of these would cost more then to just do your flasher.
  7. Jan 29, 2019 at 11:03 AM
    SkunkMan17
    Owen
    Montana
    1997 Tacoma RC 4x4
    Here’s a website that sells led’s with built in resistors, but once again it’s going to cost you a pretty penny to buy ones for both your front and rear and so on. https://www.siriusledlights.com/
    Then there’s also the way that most people go (don’t see why you wouldn’t) is with buying a led flasher that supports all your turn signals so you don’t have hyperflash, I picked mine up at my local O’Reillys, but there’s also many other options, for example : https://www.amazon.com/TOMALL-Adjus...5&keywords=2019+tacoma+led+flasher&psc=1&th=1
    I would definitely do a led flasher rather then spending over 100$ for resistors
  8. Jan 29, 2019 at 12:18 PM
    bonifacio
    Central PA
    I was looking into those. Saw they worked for older models. Not sure if they were compatible with 3rd gens for whatever reason. I'm not too familiar with electrical. I will definitely check it out. Rather just get that with plain LED turns.
  9. Jan 29, 2019 at 1:21 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Keep in mind the shape of the bulb versus shape of housing makes lights look different. Some LED turn signals only look brighter if you look straight into them but dimmer from side if they don't make use of the reflector bowl in the housing.
    Recently got a pair from Amazon for $20 that has leds pointing forward plus some around sides angled backwards slightly. In my 4Runner, they weren't much different looking from oem but made big improvement in my FRS making the whole lens glow due to reflections off the back.
  10. Jan 29, 2019 at 4:44 PM
    tony2018
    tony2018 Well-Known Member
    philips has decent led bulbs, the seem to be angled and aimed at the reflector housing to make bright at night and seen during the day. good warranty too.
