Brightest LED bulbs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Highrob, May 20, 2021.
  1. May 20, 2021 at 9:31 PM
    Highrob
    Highrob [OP] Well-Known Member
    Rob
    Los Angeles
    2019 Tacoma Off-Road
    Bought some shitty LEDs for my headlights on my 19 tacoma online, they lasted about a year. I’m looking for some Nice bright White LEDs. What do you guys recommend?
  2. May 20, 2021 at 9:43 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Not LEDs. We have several threads on why HIDs are better in projectors.
  3. May 21, 2021 at 5:41 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Check the stickies above, @crashnburn80 has a great review of types and brands.
    grogorat, D500 and Skydvrr like this.
  4. May 21, 2021 at 5:57 AM
    ktmrdr
    ktmrdr Well-Known Member
    I ran Philips 12953BWX2 XtremeUltinon LED in my 07 and they were awesome. They most likely make the size for the 2019.
  5. May 21, 2021 at 6:10 AM
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
  6. May 23, 2021 at 5:10 AM
    inertiadriven07
    inertiadriven07 Well-Known Member
    Maine
    2019 DCSB SSM TRDOR
  7. May 23, 2021 at 9:26 AM
    William H. Bonney
    William H. Bonney Well-Known Member
    2016 TRDOR
    That would be appreciated
    musicisevil, TS4x4, Prestovie and 4 others like this.
  8. May 23, 2021 at 9:31 AM
    William H. Bonney
    2016 TRDOR
    I never understood why people need lights so bright they can see into the future. Hell I think the swap over to LED street lights is obnoxious enough that there’s no point in even turning your headlights on to begin with.
  9. May 23, 2021 at 9:36 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    It's the world we live in unfortunately, many (if not most) truly only care about their wants and needs.
  10. May 23, 2021 at 9:43 AM
    William H. Bonney
    2016 TRDOR
    It doesn’t help that auto makers install them factory and companies sell it as keeping you and your family safe. Personally I see it as just the opposite...and if I can’t see when your coming at me your definitely not going to.
    D. Lengua and davidstacoma like this.
  11. May 23, 2021 at 10:03 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    When you live where there's no street lights and tons of animals running around, you wanna see all you can.
  12. May 23, 2021 at 10:05 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    When 90% of your commute is long, dark highway, LEDs make a big difference. Especially if you actually research the proper bulb first.
  13. May 23, 2021 at 10:09 AM
    RedWings44
    Michigan
    The problem is people who don't bother to do any research and just buy the first things they see off of Amazon. I can tell you I've never once been flashed with my LEDs (except when I've forgotten to dim my brights). And before you say that it isn't a big deal in this day and age, consider that in my 2008 Canyon, which I traded in just last year, I got flashed all the time with my low beams in. The truck was bone stock and had the original, factory halogens.
    William H. Bonney likes this.
  14. May 23, 2021 at 10:09 AM
    William H. Bonney
    2016 TRDOR
    Who’s to say I don’t! I have high beams that work fantastic
  15. May 23, 2021 at 10:32 AM
    William H. Bonney
    2016 TRDOR
    What gets me too is that the bright white light most people have is horrible in my opinion for snowy conditions..assuming it’s the same as the LED streetlights, and correct me if I’m wrong but you don’t get the heat off the bulb to keep the headlights from freezing over either.
    Syncros and davidstacoma like this.
  16. May 23, 2021 at 10:45 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
  17. May 23, 2021 at 11:05 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Leds produce a lot of heat. The difference is in the proportion of light to heat so the same heat waste produces more light. The problem is a filament is much closer to the ideal point source so it can be that much more accurately focused and/or cut off. Led bulbs are arrays of leds with each individual led generating a beam aimed differently than the others. It’s simply not possible to retrofit an led bulb into an HID housing and not have it blinding oncoming traffic and wrecking their night adjusted vision for miles to come.
  18. May 23, 2021 at 11:19 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Correct, there are other viable options out there, not all are bad, I was referring to the folks that are blatantly blinding others with lights that clearly made for show. That's why I initially referred OP to the sticky that has actual research from someone who seems to know what he's talking about, much more than the guy selling LED headlights at the local flea market.
    RedWings44[QUOTED] likes this.
  19. May 23, 2021 at 11:26 AM
    RedWings44
    Michigan
    Not exactly. LED lights don't emit much heat at all. The drivers definitely do though. For this reason I tend to run halogens in the winter since LEDs won't really self clear snow and slush unless it is damn near freezing and not much below. As for the LED light itself, it is much easier to get that to closely mimic the position of the halogen filament than it is for an HID bulb to do the same since HIDs produce light from the gas inside, essentially making the entire bulb a filament. Thus, HIDs generally produce far more glare than appropriately spec'd LEDs.
    William H. Bonney, eurowner and TS4x4 like this.
  20. May 23, 2021 at 11:29 AM
    RedWings44
    Michigan
    This is accurate. The white light itself isn't the issue. That's actually great in the snow if appropriately aimed so as to not reflect back at you. However the light itself doesn't produce much heat and so it cannot self clear appropriately unless the temps are at or very near freezing. However, due to the background being white, I find halogens are adequate in the winter and replace my LEDs just after deer season.
