Brights don't work, Flashers do! HELP.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LightedTaco4x4, Aug 1, 2020.
  1. Aug 1, 2020 at 5:41 PM
    LightedTaco4x4
    LightedTaco4x4 [OP] Active Member
    Andrew
    Eau Claire Wi.
    2005 TRD SR5 SPORT V6 Double cab.
    Map light mod, Fogs anytime, skid plate chrome painted, LED clearance lights, Hella Rallye 4000 Halogen Chrome off road lights, bed lights, interior LED cockpit lights, mud flaps, temp/compass repair. FJ cruiser alloy wheels, Air lift Air bags! and many more coming!
    Hi, I have a 2005 DCSB Taco 4x4. While trying to figure out which wire does what in the fuse box (whhith a jumper wire and a multimeter) to tie in a set of hella ralleye 4000's , my brights stopped working. Though the flashers do work, so I know the Bulbs are fine, ALL fuses are good, and I even bought another stalk on eBay and plugged it in and it didn't fix the problem any ideas? no aftermarket lights wired to the headlights as of right now. the relays all seem to click. no indicator on dash when stalk is pushed forward, but when pulled back to flash it appears.
  2. Aug 1, 2020 at 7:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I am assuming that what you mean by flashers is that the headlights come on high when you pull the stalk back.
    I would start with the DIM Relay and check voltage on pin 5 with the lights on and selected to high beams. Then select low beams and have someone flash the highs while checking voltage at pin 5.
    I seem to remember another poster that had a similar issue and it was the Body ECU. I'll see if I can locate that thread.
    Here it is a bit different but may help guide your troubleshooting without me retyping everything.
    https://www.tacomaworld.com/threads/no-headlights.665247/
    This may assist:
  3. Aug 1, 2020 at 8:49 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The only difference I see between Hiagh Beams and Flash is,
    Flash send a ground signal to the HF and HU pins on the Body ECU.
    The High Beams only send Ground to the HU pin on the Body ECU.
    If you have power to pin 5 on Flash, but not on High.
    The the only thing between the 2 is the Body ECU.
    What do you think Jimmy?
    I’m really hoping there is never power to pin 5.
    Jimmyh and Muddinfun like this.
  4. Aug 1, 2020 at 8:57 PM
    TnShooter
    Deogee
    STOCK
    Jimmyh likes this.
  5. Aug 1, 2020 at 10:38 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That does appear to be the only difference HU and HF.
    About the power to pin # 5 well he said the flash works, high beams do not...
    He will need some voltage measurements while someone operates the switch to see what is really what. Seems kind cut and dry Switch Stalk, Wiring to the Body ECU or the Body ECU itself.
    TnShooter[QUOTED] likes this.
  6. Aug 2, 2020 at 3:08 PM
    LightedTaco4x4
    Andrew
    Eau Claire Wi.
    I suspect the body ECU myself, but am wondering how to go about finding one? or testing it to verify that it is really the problem?
  7. Aug 2, 2020 at 3:12 PM
    LightedTaco4x4
    Andrew
    Eau Claire Wi.
    Also, do I need to program new keys if i replace it?
  8. Aug 2, 2020 at 6:41 PM
    TnShooter
    Deogee
    STOCK
    I suppose you could check for continuity on pin 11 of C11 to GROUND.
    Put the headlights on High, if there is continuity, move to connector 1l pin 9.
    I’d start here, since you have tried 2 head light switches.
    If it Is good there, it’s likely the body ECM.
    Let’s wait and see if @Jimmyh agrees.
  9. Aug 2, 2020 at 7:22 PM
    LightedTaco4x4
    Andrew
    Eau Claire Wi.
    Thanks! that makes a LOT more sense. will try tomorrow. where exactly is C11 and 1? on the stalk or Body ECM?
    TnShooter likes this.
  10. Aug 2, 2020 at 7:39 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is exactly what I would do to verify the ground side of the circuit.
    C11 is the connector on the stalk.
    1l is the connector to the Body ECU from the stalk Red wire with a Green Stripe.
  11. Aug 2, 2020 at 7:45 PM
    TnShooter
    Deogee
    STOCK
  12. Aug 7, 2020 at 9:20 AM
    LightedTaco4x4
    Andrew
    Eau Claire Wi.
    If I replace the Body ECM, do i have to get new keys?
  13. Aug 7, 2020 at 11:58 AM
    LightedTaco4x4
    Andrew
    Eau Claire Wi.
    Ok, I tested C11 (on the stalk tho) for continuity, and got a circuit when the brights where on from C11, Pin 11 to Pin 20. Pin 20 I surmise is ground? does that mean its the Body ECU? or is there another relay somewhere I could have burned out?
  14. Aug 7, 2020 at 7:55 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    On the stalk switch C11 Pin 11 ( is the High Beam wire to the Body ECU ) read to pin 12 ( Pin 12 is ground ) resistance. Should read as a short circuit when the switch is on and in High Beam Position.
    Or you could just read a continuity check from Pin 11 to any ground on the body. If it reads near zero Ohms with the headlights on and high beam selected then the switch is good as far as the high beam signal goes.
    If so that only leaves the wire between the stalk switch and the Body ECU ( Red Wire with a Green Stripe ) or the Body ECU itself.
    Pin 20 (HEAD) is the Headlight Signal to the body ECU.
    Pin 11 ( HU ) is the High Beam Signal to the body ECU.
    Pin 17 ( HF ) is the Flash Signal to the body ECU.
    Pin 15 is the Left Turn signal.
    Pin 13 is the Right Turn signal.
    Pin 12 is the Common Ground for all signals.
    TRDSport10 and TnShooter like this.
  15. Aug 10, 2020 at 9:50 AM
    LightedTaco4x4
    Andrew
    Eau Claire Wi.
    OK, everything seems to point to the body ECU, I located one, but before I order it i'm wondering if i'll need to program new keys which, if i do I will need to a key programmer too.
  16. Aug 11, 2020 at 2:16 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You shouldn't have to reprogram anything. The keys are read by the Key amplifier and feeds that data to the Transponder Key ECU which is separate from the Body ECU.
    Muddinfun likes this.
  17. Aug 19, 2020 at 7:24 PM
    LightedTaco4x4
    Andrew
    Eau Claire Wi.
    Got them working, it was the Body ECU! bought a replacement on eBay.
    TRDSport10 likes this.
  18. Aug 19, 2020 at 7:32 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Good job!
    Thanks for the update. I was pretty damn sure it was after all the checks.
    :thumbsup:
  19. Aug 19, 2020 at 7:45 PM
    LightedTaco4x4
    Andrew
    Eau Claire Wi.
    Thanks for all the help, never could have figured it out without you guys!
