brilliant minds unite please...
Discussion in 'Wheels & Tires' started by gjbonner, Jun 22, 2009.
  1. Jun 22, 2009 at 7:52 PM
    gjbonner
    gjbonner [OP] Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    I'm sure it didnt require brilliant minds maybe just smarter but hey youre here right:D? So i have experienced a slight rub when at full turn and the truck slants to one side. it is minimal but at full stuff obviously it will be much worse. i searched and was referred to the fender mod on TTORA which was very detailed and helpful. This is probably what will happen however i still run into problems with the fender flare. I know the bushwackers flare out further but they still mount to the same mounting point as the old ones right? i had them on an older toy but never paid attention. do i just run without flares or are there flares out there for this or can i cut that bottom portion of the flare(or any flare for that matter) in any way to keep it looking decent? The pics are of the front drivers side.
    The bumper will not be much of a problem as you can see but at full stuff it will have a little rub too. I figure a Budbuilt or similar bumper will run high enough that i will have plenty of room up there.
    So i'm looking for input on what may be possible for rubbing solutions and what could look best in regards to trimming on the flare. I would like to hear some outside the box ideas as well if they are out there. i game for anything really as you can see with the Rhino job:cool:. the firewall speaks for itself and i see only one way to fix it which is to cut like the TTORA post. At full stuff it will hit the firewall i'm sure. I dont think i will pound it in but i guess its an option if a new flare covers it up....
    In the end it doesnt matter how much i bring in the firewall if there is still a flare down there in the way. Hopefully you guys can help me come up with a fix for this.
  2. Jun 22, 2009 at 7:57 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    bust out a sawzall and start trimming
    when you get to the firewall...if you still rub on the firewall...tub that bad boy :)
  3. Jun 22, 2009 at 7:58 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    dammit....beat me to it!:D
  4. Jun 22, 2009 at 8:02 PM
    JimBeam
    JB
    2015 Tundra
    make sure you lay some tape down when sawzall-ing though so you get nice straight cuts...
    sand down the cut...
    touch up with something (how does one touch up rhino liner?)
  5. Jun 22, 2009 at 8:13 PM
    gjbonner
    Guy
    Northern Idaho
    Hhahaha...so you don think it will look too bad if i make a clean "slantedlike" cut(like my word there) in the rear portion of the fender flare. i like the way they look and really dont want to get bushwakers. i may even trim on the front bumper for now. a new bumper is not in my immediate future with the money i have dropped on this.
    Edit: Touch up Rhino Liner??? yeah not sure haha i'm sure th esanding will do the job..
  6. Jun 22, 2009 at 8:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    "slantedlike".....awesome word, and yep....that'd look cool i think.
  7. Jun 22, 2009 at 8:15 PM
    JimBeam
    JB
    2015 Tundra
    i dont see much way around it
    trim what you have
    remove what you have + trim body/firewall
    live with rubbing
  8. Jun 22, 2009 at 8:21 PM
    gjbonner
    Guy
    Northern Idaho
    Thanks, yeah i'll probably be fine trimming the fender up to the fire wall. I'll have to stuff the tires to see if the hit the firewall very hard. I think i might not have to tub there but one day all those 37" tires i've been collecting from work will come into good use and i'll really have to start tubbing... Hey theyre free. I figure a year of collecting and i should be set for off roading for a while:D
