Brilliant !!! Satoshi Emblem Answer: Converted into Mod Write-Up W/ Pics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cape Codder, Jun 25, 2010.
  1. Aug 22, 2010 at 6:18 PM
    #61
    Cape Codder
    Cape Codder [OP] Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    I’ve Been thinking About Your Emblem Paint Scheme Dilemma and Have a Solution, If It Were Mine.
    You Can do It Scientifically or Just Wing It.
    Using ColorZilla, If You Use FireFox, or Use MicroSoft Paint:
    You Can Use the ColorZilla Eyedropper on a Webpage Picture of a Magnetic Gray Truck, or Site w/Paint Code (Sample) Swatch
    Or in MS Paint the Eyedropper on an Imported Picture of Your Truck,
    To Get the RGB (red/green/blue) Values or Hex Value.
    Then You Can Use Paint’s Advanced “Edit Colors” Chart to Fill in the RGB Values
    Use the Slide (In MS Paint Edit Colors) on the Right to Lighten the Mag Gray 10, 20, or 30 Shades
    So There’s Plenty of Contrast to Use as the Emblem Outline Paint.
    You’d Then Have the RGB Values for the Lighter Shade, But You’d Have to Get a Small Amount Mixed.
    Spray All the Emblem Letters Color Matched Magnetic Gray,
    Then (Against My Recommendation) Brush Paint the Outline With the Lighter Shade.
    If Light Enough, It Will Contrast Enough to Stand Out, But Still Match, As It Just A Lighter Shade of the Same Color
    The “Wing It” Alternative to That Is:
    Get a Small Bottle of Mag Gray and a Bottle of White Touch-Up Paint.
    Using a Small Plastic Container, Put Ten Drops of Mag Gray and one Drop of White.
    Adjust By Adding More White or Mag Gray ‘til You Like the Amount of Contrast,
    Remembering the Final Amounts or Equivalent Ratio, If You Need to Mix More.
    Then Paint Like Hell Before the Mix Dries.
    Another Method Might Be, Pick Up a Can of Light Gray Spray Paint, You Think Matches.
    Tape and Spray The Outline in the Lighter Color, After the Overall Mag Gray Coats.
    I Just Read This and It Almost Confused Me. So If It’s Not Clear, Get Back to Me for Clarification.
    Final Product Will Be Worth the Effort, Just Don’t Rush.
    Good Luck and Hope to See Pics Soon.
    cc
  2. Aug 26, 2010 at 4:10 PM
    #62
    ggreen
    ggreen Well-Known Member
    North Bay Area, CA
    2010 MGM TRD Sport DC Shortbed 4x4
    Icon Suspension Lift, TRD Cold Air Intake, TRD Exhaust (Powder Coated Black), Wet Okole Seat Covers, Weathertech Mats
    Thanks for the advice. Everything is on hold right now because, due to work and other obligations, I will not be able to pick up my grill assembly until next Thursday. I won't be able to mark for the drill holes until then.
    I think I will start off by just painting the emblem mag grey. If it doesn't stand out enough I'll look to paint a lighter outline (grey/white?) to it. I like your idea of messing around different configurations on Photoshop or something similar but I'm not too computer savvy with photo editing programs.
  3. Aug 26, 2010 at 4:12 PM
    #63
    TheCheshire29
    TheCheshire29 Well-Known Member
    David
    La Habra (562)
    08 PreRunner Double Cab TRD Off Road White
    Side steps Limo Tint on black 3 windows dark tint in front two JVC KW-AVX820 Head unit Painted dash surrounding black and center console BHLM Plasti dip Fog Sleeves, lower Valence, and Stock Rims AEM Intake Bad A$$ shifter knob Tinted Tails Illuminated cup holders and Door pockets.
    I WOULD!!!! ^^^^^^
  4. Aug 28, 2010 at 2:44 PM
    #64
    victheyankee
    victheyankee Well-Known Member
    arizona
    upgraded sound system eclipse and alpine and mb wheels.
    I bought a marker for model cars that has gray paint and painted the outline of the letter it was fast and easy. All for the low price of $3.86
  5. Aug 29, 2010 at 6:42 PM
    #65
    Cape Codder
    Jack
    Good Luck..........Post Pics............Read About "Paint Pen" Below
    Would What ??? :confused:
    I Ordered a Color Match Paint Pen and Used a Brush :facepalm:
    Thanks for Bringing Up the Paint Marker. It's Definitely the Way To Go
    Ordered It To Have For Future Touch-Up.
    Never Took The Cap Off and Forgot All About It. :frusty::annoyed:
    Emblem Looks Good BTW
    cc
  6. Sep 16, 2010 at 8:17 PM
    #66
    ggreen
    North Bay Area, CA
    I've been very busy with work but I really want to get back into this emblem project.
    UPDATE:
    Got my satoshi back from the paint shop. Came out very nice.
    Emblem is expoxy'd.
    Next step is measuring, marking and tapping.
    I finally got a hold of a #4-40 bottoming tap and access to a drill press. I plan on using some scrap plastic to get the depth set up correctly. I admittedly do not have any experience with taps let alone tapping epoxy/plastic. Should I be concerned with the tap trying to suck up the emblem? Maybe use a couple grip clamps?
    Thanks for all your help thus far!
  7. Sep 19, 2010 at 7:16 PM
    #67
    Cape Codder
    Jack
    Busy Too.............
    Drill Press with Depth Stop for drilling the Holes
    HAND Tap!! I used a Tap "T" Handle, with the "T" Portion removable.
    Take the "T" out of the handle and use it like a Screwdriver to Thread the Tap in by hand.
    You can use one with the handle in, but only turn the Barrel, not the "T".
    Too much leverage with the "T" and You won't "Feel" the threading
    It should take 5-6 complete 360° revolutions, depending on the depth you drilled
    4-40 screws have 40 threads per inch, therefore, 5 threads per 1/8"
    Letters are about 3/16" thick, so 6 threads should be easy if the holes were drilled as deep as possible, without breaking the surface of the letters.
    Stop tapping as soon as it starts binding, keeping and eye on the front of the letter.
    You'll feel it binding, but count the revolutions, to keep track of how deep You've gone.
    The Drill bit is pointed, but the Bottoming Tap is flat and won't go as deep as the bit.
    Push it further (slowly), if you feel comfortable with it.
    I had a couple of bumps I had to sand, 'cause I drilled almost to far.
    You'll start to distort the Letter surface if You drill or tap to far, but You should be able to see it if You watch it.
    It can always be filled with epoxy or finishing putty, if you break thru.
    You'll be cutting the screws with a Screw Cutter, and that'll leave a sharp leading edge on the threads of the screw, which will dig into the bottom of the hole, and act as a Tap (a little).
    I cut one screw, multiple times, until it was the right length, then cut the rest to match
    When I was tapping by hand, I was more concerned with stripping the threads when I bound up and bottomed out, than I was of breaking thru.
    You might go back and read my Post #43, as I probably missed something here and there's info on the hardware I used.
    Good Tapping and keep us up to date (and Pics when done).
    I'm sure I can come up with some more answers, if You've got more questions.
    It's pretty easy, so enjoy yourself and take your time.
    CC
  8. Nov 14, 2010 at 2:08 PM
    #68
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Good work!! I love the color matched avid bar.. very clean!
  9. Nov 14, 2010 at 2:48 PM
    #69
    victheyankee
    arizona
    I tried to thred it. It was to much trouble i used the squares from home depot epoxied them to the emblem and zip tied it. Worked out great.
  10. Nov 14, 2010 at 2:55 PM
    #70
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    how do you open your hood? If u can't grab the latch
  11. Nov 14, 2010 at 5:53 PM
    #71
    victheyankee
    arizona
    You can open it. It works the same way you pop the latch and "wala"
  12. Nov 16, 2010 at 8:16 PM
    #72
    westbank
    westbank Active Member
    Gord
    Calgary
    2010 4WD LB
    Is a Dremmel cutting wheel the best tool to use to cut the aluminum grille to fit behind the grille assembly?
    Thanks for all your info. Love the work you did.
  13. Nov 16, 2010 at 10:13 PM
    #73
    victheyankee
    arizona
    No that takes forever. I used a saw saw to cut the plastic and a grinder with a cutting wheel to cut the grille. Like a hot nife threw butter
  14. Nov 17, 2010 at 9:53 PM
    #74
    westbank
    Gord
    Calgary
    2010 4WD LB
    Like an angle grinder hey... looks like I need to pick up a new tool.
  15. Nov 17, 2010 at 11:04 PM
    #75
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Nice write-up. Subscribed.
  16. Nov 23, 2010 at 7:43 PM
    #76
    Cape Codder
    Jack
    Sorry, life's been cuttin' into my TW time. Haven't been on site in a while
    Thanks, the subtle touch is the grill surround is color matched also, but not noticed much. I think that's what makes it clean
    Threadin' was a PITA, but I'm anal. Whatever works to get 'em on. Good you got 'em fastened.
    I cut an opening in the top of the grill surround (See above 2nd "T" in my Sig Pic), but never adapted the release, because I could reach the release between the hood and grill
    I used aviation tin snips. took a while. Probably about the same time as a Dremel. Grinder would work nicely, but I was listening to the Music that day.
    Music?...........Grinder?.........Music WON.
    But You couldn't hear the Music ;)
    Thank You
  17. Nov 23, 2010 at 7:47 PM
    #77
    mgage10
    mgage10 Well-Known Member
    Salt Lake City, UT
    2010 White Tacoma TRD Sport Long Bed 4x4
    Bilstein 5100s with Add-A-Leaf 18x9 XD Addicts on 285/65R18 Nitto Terra Grapplers G2 TRD Skid Plate Gray Husky Liners Venture Shield Clear Bra TRD Sport Pedals Seat Belt Alarm Disabled LED Map Lights (Cool White) LED Dome Light (Cool White) LED License Plate Lights (Cool White) White Engine Cover White Toyota FJ Grill Badge Viper 2 Way Alarm System Debadged Tailgate Fog Light Anytime Mod Window Tint Black Mesh Upper Grillcraft Black Mesh Lower Grillcraft Black Mesh Grillcraft Triangles Raven Speed Antenna AFE Stage 2 Pro-Dry S Intake Doug Thorley Long Tube Headers
    That looks awesome. Nice work.
  18. Nov 23, 2010 at 7:53 PM
    #78
    Cape Codder
    Jack
    ty
    cc
  19. Nov 23, 2010 at 7:53 PM
    #79
    trd7
    trd7 4wd tacoma
    Tyler
    Columbia, SC
    95.5 Tacoma 4x4 4cyl auto
    AEM air intake
    ^x2 great work!
  20. Nov 23, 2010 at 8:00 PM
    #80
    Cape Codder
    Jack
    ty2
    cc
