British Columbia BS thread
Discussion in 'British Columbia (BC)' started by TacoPacific, Aug 8, 2021.
  1. Apr 2, 2023 at 10:18 PM
    #321
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Seen that they were in Surrey and 2 other locations this weekend. Curious but not interested yet.
    BC Hunter likes this.
  2. Apr 9, 2023 at 1:52 PM
    #322
    TacoPacific
    TacoPacific [OP] Just a Joe in a Taco
    Vancouver BC
    2021 Tacoma TRD OR DCSB
    Smartcap Evo Sport, Gar-FAB tailgate panel, TRD Performance Suspension/Lift
    yah I am starting to feel that Overland Tune would be pretty scooby. But same as you… keep finding other things to spend $600 on.
  3. Apr 9, 2023 at 2:47 PM
    #323
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I am on the fence... if I do it, I will most likely do the install myself. That means a bit more investment.
  4. Apr 10, 2023 at 8:08 AM
    #324
    DuffyBank
    DuffyBank Well-Known Member
    Same boat, different river
  5. Apr 17, 2023 at 7:25 AM
    #325
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Someone buy my tent
  6. Apr 22, 2023 at 10:39 AM
    #326
    DuffyBank
    Happy Earth Day
  7. Apr 26, 2023 at 1:21 PM
    #327
    TacoPacific
    Vancouver BC
    Jeepers... Can you say Jeepers on TW? hmmm. Thoughts.
    Speedfreak likes this.
  8. Apr 26, 2023 at 5:16 PM
    #328
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Reported!!!:eek::boink::rofl:
  9. Apr 26, 2023 at 8:05 PM
    #329
    DuffyBank
    Damn Creepers
  10. May 1, 2023 at 8:11 PM
    #330
    TacoPacific
    Vancouver BC
    Right?
  11. May 15, 2023 at 9:39 PM
    #331
    VXEric
    VXEric Well-Known Member
    Eric
    Worcester, PA
    07 ACS V6 6 Spd TRD Sport
    265/70/17 ATs on 17x8"wheels and 0 offset Morimoto XB LED Fogs Reinforced tailgate 2011 Honeycomb grille URD Short Shifter and cue- ball style knob
    Spent some time on the Fraser this weekend. It was HOT! But a good time.
  12. Jun 24, 2023 at 9:24 AM
    #332
    TacoPacific
    Vancouver BC
    4th service for the 3rd Gen Tacoma. What should the dealer be doing?
    anyone?
  13. Jun 24, 2023 at 9:45 AM
    #333
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Enter your info here and it will tell you what Toyota recommends. Of course the dealer will suggest lots of others for extra cash out of your wallet.
    https://www.toyota.ca/toyota/en/owners/maintenance-schedule
  14. Jun 24, 2023 at 12:06 PM
    #334
    TacoPacific
    Vancouver BC
    Perfect so … let’s look at a bunch of stuff that will be just fine. Change the oil and… that’s it.
    I think I have got this one.
    Speedfreak[QUOTED] likes this.
  15. Jul 25, 2023 at 9:25 AM
    #335
    TacoPacific
    Vancouver BC
    If you have a ‘21 TRD OR running the stock 16’s because you don’t mind them.
    But you have a 2.5” lift and want to run the biggest tire .. w/o needing a CMC or any other things (ps I do have Dirt King UCA’s).
    I seem to recall a post on TW but of course… when I need it… I can’t find it.
  16. Jul 25, 2023 at 3:43 PM
    #336
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    I have 265/70R17's on a +5 offset rim with a 2" lift with Terrain Tamer UCA's. I have cut the mudflaps and I still rub on the left side when backing up. That is on a 1/2 tall diameter tire over stock. The offset makes a difference too. I might not rub with the factory +30 offset rims, but the TRD Pro wheels are +4 so... Toyota really didn't want big tires on these trucks!
  17. Jul 26, 2023 at 5:22 AM
    #337
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    I have a 21 OR with a TRD lift and run 255/85 on the TRD beadlocks (10 mm offset). The stock OR wheels are 25 mm offset and should have similar results.
  18. Jul 27, 2023 at 5:59 PM
    #338
    TacoPacific
    Vancouver BC
    Well I changed my mind. Ordered some
    method 305 double Blacks.
    I think I’m going to slap 265/75/16’s.
    Anyone got thoughts on P vs LT?
    I have P’s now. Wildpeaks at that. But now I’m carrying RTT, Awning 100% of the time. The. We add 800lbs of people and animals for trips.
    Access and FS roads are the extend. And a bit of and dunes. I have aired down once in my life. lol.
  19. Jul 27, 2023 at 7:01 PM
    #339
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Just looking at a 265/70R17 in SL and LT... (Toyo AT III ) the SL has a weigh capacity of 2679lbs per tire (10,716lbs total). The LT has a rating of 3195/2910lbs per tire ( 12,780/11,640lbs total). Yes the LT has more capacity but it is at a rated psi. The SL is 44psi where the LT is at 80psi. Now the tire pressure is already adjusted for GVRW as seen on you door sticker for SL tires. So the max pressure isn't needed but it shows the difference of pressure needed to switch to an LT tire. has a calculator that will calculate the needed pressures needed to maintain the weight capacity of the new tires. As an example I entered the above tires into the calculator and used 29psi as the stock pressure for the SL tires. The LT tires need 41psi to meet that capacity of the SL tires. This will affect everyday driving by being a firmer ride. And only for a 2064 lbs increase in capacity when the tire is inflated to rated pressures.
    I stayed with SL's. I would suggest putting your truck on a scale and see if you really need LT tires. I don't think anyone on this forum does. Unless they have a huge camper in the bed.
    Some sizes are only available in an LT so the SL / LT debate is mute at that point.
  20. Jul 27, 2023 at 8:19 PM
    #340
    TacoPacific
    Vancouver BC
    This is why I like you. That’s a good solid comparison of enough data that tells me I should save 320$. Which is almost an entire tire.
