Broke a lug nut stud today - a few questions
Discussion in 'Wheels & Tires' started by glock24, Aug 22, 2016.
  1. Aug 22, 2016 at 3:20 PM
    glock24
    glock24 [OP] Well-Known Member
    All this TLC I've been giving my new Tacoma back-fired today. I've worked on vehicles for thirty years, only because I needed to. I work now on my new Tacoma only because I want to.
    Nonetheless, today I broke a lug nut stud during the routine 5k tire rotation. I use a Craftsman torque wrench set to 100 ft/lbs instead of the recommended 85 ft/lbs. (because that's the way I've always done it)
    I use anti-seize on the threads instead of following advice to avoid it. (because that's the way I've always done it)
    It is the driver's side front hub that has the broken stud. And I think I felt a second stud yield slightly when I was torquing the remaining lug nuts. And to make things even worse, I have the '15 TRD Off-Road wheels that use the less than common spline-drive lug nuts.
    So my questions for TW include;
    1. Is this a level one emergency? Have it towed to the nearest dealer and get ready to bend over?
    2. As far as repair, should I consider replacing all 24 lug nut studs (6 x 4 wheels), or simply the broken one?
    Any other advice or insults would certainly be appreciated.
    Thank you
  2. Aug 22, 2016 at 3:23 PM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    Not level one like level 5. Just replace the broken stud unless you plan on running some big ass monster truck tires
  3. Aug 22, 2016 at 3:59 PM
    glock24
    Well that is good news. Thanks. I think I'll just repair it myself.
    Anyone know the correct replacement wheel stud for the front wheel of a '15? Should I consider longer studs now that I'm running the TRD Off-Road wheels?
  4. Aug 22, 2016 at 4:21 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    :facepalm: There's no need to use anti-seize with close-ended lugnuts. However, if you insist, you are supposed to reduce the torque applied when using anti-seize by about half. i.e. if the manual calls for 83 ft-lb dry torque, apply only ~41 ft-lb if using anti-seize. Conversely, what you did (100 ft-lb with anti-seize) would have a similar effect as applying 200 ft-lb on dry threads.
  5. Aug 22, 2016 at 4:24 PM
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    You'll be fine. I found mine broken just before a 4 hour gnarly trail ride. I went on my trip still. Drilled it out the next day and replaced.
  6. Aug 22, 2016 at 4:28 PM
    KenLyns
    Belly of the Beast
    Three major aftermarket vendors offer them in addition to Toyota OEM: http://www.rockauto.com/en/catalog/toyota,2010,tacoma,4.0l+v6,1445515,wheel/tire,lug+stud,7680
    No need to run longer studs if you are using Toyota wheels. In fact it may be detrimental (tip of stud bottoming inside lug nut).
  7. Aug 22, 2016 at 4:34 PM
    perpetualenigma3
    perpetualenigma3 Well-Known Member
    Mr.
    Im here and there. Mostly there than here.
    2016 QuickSand Taco TRD OffRoad
    A new bolt here, a new bolt there, a new bolt everywhere.
    Check with autozone or oreillys they might have some studs in stock. The studs are just pressed into place
  8. Aug 22, 2016 at 5:23 PM
    glock24
    200 ft/lbs . . . YEAH!
    Thanks guys. I feel better knowing this isn't a big deal, and I can fix it myself.
    Biscuits likes this.
