Broke antenna
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeb1000, Oct 21, 2024.
  1. Oct 21, 2024 at 1:09 PM
    jeb1000
    jeb1000 [OP] Member
    jim
    2007 tacoma
    none
    My Grandson broke the antenna off of my 2007 tacoma.
    Man tried to "tap" out the part on the right front fender and screwed it up. Is there an easy way to replace that part without pulling the fender - they want $200 to do so?
    Tks - jeb
  2. Oct 21, 2024 at 2:29 PM
    RockfordTaco2006
    RockfordTaco2006 Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    Hey sorry to hear this....
    The parts alone from Toyota are over $100.
    86300-04070 - Antenna Down Shaft
    86396-04040 - Antenna Base Nut
    86392-04040 - Antenna Bezel
    86309-04080 - Antenna
    I had to remove the inner plastic fender well to get up in there and the A piler inside even thou I don't have a shark fin the connector is still up in that area. It was def not a hard fix but it may take some time.
    Good Luck!
  3. Oct 21, 2024 at 2:51 PM
    jeb1000
    jeb1000 [OP] Member
    jim
    2007 tacoma
    none
    Tks Rock - Instead or the original longer antenna I have bought one of the ones about 10 inches or so and am looking at using some conductive epoxy to attach it to the old place. Downside would be it couldn't be taken through a car wash any more. I really like my truck but it seems almost everything one wants to do is a problem. It is a 2007 - I am 84 years old and it only has a little over 130K miles on it. Had a couple of dents taken out and repainted a few years ago and it looks brand new, inside and out.
  4. Oct 21, 2024 at 3:26 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I've heard and tried to loosen the base nut on mine and it doesn't want to budge, even soaking it with penetrating oil hasn't worked. I thought if I could loosen it, then I'd purchase a new antana and give the replacement a try as my reception is pretty poor. I even made a spanner-type tool to use.
  5. Oct 22, 2024 at 6:53 AM
    jeb1000
    jeb1000 [OP] Member
    jim
    2007 tacoma
    none
    dtaco, I tried to get that nut off as well and was not able to do so. Guess Toyota doesn't want it to ever come off, huh? :)
  6. Oct 22, 2024 at 9:05 AM
    skiergd011013
    skiergd011013 Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    The carwash broke mine a long time ago. I superglued it back together and ran it like that for years. It would occasionally flop down and be crooked if it got hit, and i would just re-glue. It worked good and had perfect reception. I eventually ordered all the parts and replaced the whole assembly. I now carry an antenna tool and take it off before going through washes.
  7. Oct 22, 2024 at 11:30 AM
    jeb1000
    jeb1000 [OP] Member
    jim
    2007 tacoma
    none
    You used superglue? I was thinking of using epoxy but it would have to be the conductive type and all I can find of that is what is used by jewelers. Spoke to one and he said he didn't think it would be
    strong enough to hold up very well.
  8. Oct 22, 2024 at 4:15 PM
    skiergd011013
    I sure did. Loctite superglue gel. I covered the threads on the antenna bolt end, and threaded it in the best it would. Then, covered the joint where the two meet with more glue. I let it sit for a few hours before driving. I'm a cheapskate, and this worked for quite some time. It failed twice. Once, the antenna smacked a branch, and the other, i hit it with my snowbrush clearing snow. Your break may not be the same as mine was. I was able to at least catch a few threads when screwing it in. I eventually ended up doing the whole assembly replacement
  9. Oct 23, 2024 at 5:33 AM
    jeb1000
    jeb1000 [OP] Member
    jim
    2007 tacoma
    none
    Tks, Skier. Take care - jb
