Broke Down 1st Gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by rackomint, Mar 2, 2021.
Am I screwed?
Poll closed Mar 9, 2021.
  1. Yes
    38.5%
  2. No
    15.4%
  3. Sell a kidney for money
    46.2%
  1. Mar 3, 2021 at 7:17 AM
    #81
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    His tires were different sizes and he was doing 60 in 4HI for an extended length of time. Front diff got over loaded and the pinion was the weak link causing everything else to blow :(
    rackomint[OP] likes this.
  2. Mar 3, 2021 at 7:54 AM
    #82
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    For what its worth I dont totally buy that theory. That the pinion would entirely shear off before something else like a CV or even DS failed. I suppose it could have been weakened by some other event at some point in its lifetime, but still..
    Im more curious about the trans thing. Wondering if I misunderstood what he was saying, or if I missed something altogether
  3. Mar 3, 2021 at 8:51 AM
    #83
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    I'm a little late to this party but I think your list is dead on. Only thing I would say before getting a new transmission is check the old one out thoroughly. If its ok he may just need a new bell housing not the complete trans.
    @rackomint You should be able to find all these used parts for less then $1,000
    Clutch slave and line $40
    Transmission $300
    Front differential $200
    Driveshaft shop $60
    Clutch disc, pressure plate, Throw out bearing, pilot bearing. $250 (all new parts)
    Thorough check of T-case and
    rackomint[OP] and Abeyancer like this.
  4. Mar 3, 2021 at 9:00 AM
    #84
    Abeyancer
    Jimmie
    PNW
    When I've seen this happen to a Subaru, it's always been the diff that fails before the CVs do:notsure:
  5. Mar 3, 2021 at 9:03 AM
    #85
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I think the thing is that the load is being split across both CVs, but the driveshaft is taking the full force of the mismatch.
    Abeyancer likes this.
  6. Mar 3, 2021 at 9:04 AM
    #86
    0xDEADBEEF
    I don't think that transmission bellhousing is removable.
    But, a decent welder should be able to whip up a new slave cylinder mount.
    Tour991[QUOTED] likes this.
  7. Mar 3, 2021 at 9:07 AM
    #87
    0xDEADBEEF
    Also, for full clarification, he needs a transmission from a V6, not from a 4 cylinder.
  8. Mar 3, 2021 at 9:17 AM
    #88
    Tour991
    James
    South Reno/Tahoe
    R150f has a removable bellhousing
  9. Mar 3, 2021 at 9:19 AM
    #89
    0xDEADBEEF
    Oh nice catch, looking at the pics he posted I swore it looked like one piece.
  10. Mar 3, 2021 at 9:35 AM
    #90
    Tour991
    James
    South Reno/Tahoe
    @rackomint I did have a similar thing happen but not near as bad. My front diff had a bearing seez on the pinion. Lucky I was only doing 35mph and on a light dusting of fresh snow. My truck just skidded to a stop. after shifting it out of 4wd. I could move the truck BUT it turns out I lost some teeth on the rear diff. Point being check the rear diff as well.
  11. Mar 3, 2021 at 1:53 PM
    #91
    ZUK
    ZUK Gearinstalls.com
    Ken
    Chandler AZ
    2001 white Taco TRD 3.4L auto (SAS FJ60 flip) 35" KO2 5" AllPro leafpacks front and rear,
    SAS,1985 FJ60 flipped axle, 35" KO2,5" AllPro leafpacks front and rear,
    Wow Rackomint
    1st gen Taco.....7.5" front clamshell(shown left) and 8.4" rear 3rd(right) . I think your front pinion just super heated which weakens it tremendously..... and sheared in 2 where the pinion splines meet the actual solid pinion. As shown in the pic, your pinion shaft probably sheared just above the top of the splines. The rear 8.4" 3rd had the same strain as the front but it is so much more beefy. The front clam is a high pinion and that hi-pinion arrangement kind of starves the pinion bearings for oil anyways. Even thou the rear 3rd lived it is best to check the oil and if it is black change it out for fresh unburnt oil.
    The front pinion teeth might have melted down too. Open that clamshell up(Ten 14mm bolts) and post a pic of the pinion head.
    ZUK
    PS----Sounds like the chain driven transfercase lived....a testimonial to its strength.
  12. Mar 5, 2021 at 8:54 PM
    #92
    rackomint
    rackomint [OP] Well-Known Member
    Anna TX
    2001 5-spd SR5 3.7L V6 4WD
    I will when I get around to opening it. Thanks for your advice.
    I don't have the expertise to tackle these repairs so she will sit for a little bit.
    Going to try and find someone local to help me with it and I'll try to get those pics
  13. May 13, 2021 at 9:36 PM
    #93
    rackomint
    Anna TX
    Finally got to working on her.
    Been going for a almost a week after work.
    Here is the inside of the bell housing, broken pivot pin IMG_20210513_194845905.jpg
    I took advantage of this to give the tranny a quick clean
    Here is the front driveshaft, where it connects to the front diff, I'm not sure what's it's called, but it is sheared off..
    And the front diff
    Any chance I can replace this broken shaft and possibly salvage the diff?
    Can I take out the front diff or disable it to make it RWD temporarily?
    I haven't found a front diff just yet
  14. May 13, 2021 at 10:34 PM
    #94
    Tour991
    James
    South Reno/Tahoe
    You might be able to as long as the bearing didn't seeze up. If it did the pinion shaft may be stuck in there unless you have a super strong press.
  15. May 13, 2021 at 11:35 PM
    #95
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    OUCH... now thats carnage...
  16. May 14, 2021 at 8:26 AM
    #96
    ZUK
    Ken
    Chandler AZ
    Hey Rackomint,
    If you did send that to me for rebuild it means you could drive it around without the clamshell as long as you have the outer piece(birf end) in the spindle and the nut tiighten to 300 ft/lbs I think. That is what holds the spindle together. In the picture, the axle was being stubborn about coming apart at the birf so I cut the %$#@! in the middle of the birf and was then able to drive my Tacoma around. The truck was about to see an SAS so I did not care about the CV axles anymore.
    I'd be happy to rebuild but that is a more expensive route.......better off finding a used 7.5" clamshell with stock 410 gears(check your ratio). I assume you still have stock gears and did not regear. 41 teeth means 410 gears.
  17. May 14, 2021 at 9:31 AM
    #97
    rackomint
    Anna TX
    Thanks man, I will try to get this done. I'm not 100% sure what some of these things mean.
    I'm a summing the clamshell is the front diff housing and gears and the birf is the silver nut in the picture?
  18. May 14, 2021 at 9:35 AM
    #98
    eon_blue
    Azusa, CA
    You can run in 2wd with the axles removed up front, but the outer part of the CV axle (birf end) has to be in the hub with the axle nut torqued on the end to 173 ft/lbs....the birf end and axle nut is what keeps your wheel bearing together, without it the wheel bearing will fail in short order.
  19. May 14, 2021 at 12:11 PM
    #99
    ZUK
    Ken
    Chandler AZ
    173 :thumbsup:
    The birf is that sideways looking ashtray. I destroyed my birf to keep my 01 Taco drivable for a few more weeks. You might not have the "tools" to separate the axle from the birf....shop might have to do that. Anyways, that would at least keep you on the road.
    rackomint[OP] and eon_blue like this.
  20. May 20, 2021 at 9:03 PM
    #100
    rackomint
    Anna TX
    Working on le truck and here are some pics of the frond diff.
    It's destroyed inside.
    I had to take the drain plug with a breaker bar the whole way out.
    Diff fluid and a piece of metal that came off with drain plug..
    View from drain plug, decorated with beautiful metal shards
    I can't believe how pretty this drain plug is, I think I'll auction it for 10 million dollars, it's probably haunted, I'll ship it for free to whoever wants it
    View from fill plug, nothing too interesting, except for Becky's (my truck) empty chamber of secrets
    Doesn't this thread keep getting better and better?!?
    Also, I want to thank Timmah! Timmy the toolman because his videos have saved my ass so far, Tour991 for sending me a new diff I am receiving tomorrow and all of you suckers that have helped go through this.
    I love you all, these forums, and (still) my heart breaking tacoma
