Broke down on road. Truck just stopped running. (Formerly a HELP post, now a Getting It Towed post)
Discussion in '1st Gen. Tacomas (1995-2004)' started by BuelltonTacoma, Nov 10, 2022.
  1. Nov 10, 2022 at 5:35 PM
    BuelltonTacoma
    BuelltonTacoma [OP] Well-Known Member
    2000 Tacoma 4x4 V6 3.4L MT
    I know the “help” is only for situation critical, but this warrants it.
    Was driving up a grade at 45mph/4th gear when out of nowhere I felt something “slip” underfoot and the truck shut off completely. Fortunately was able to coast in reverse into a pullout and off the road but I’m now stranded 5 miles up a country road from my house trying to diagnose the problem. Truck won’t start, battery is good, starter is good. OBD II not pulling any codes.
    Any ideas? I’m at a loss with such an instant failure out of nowhere. Thanks all.
    2000 Tacoma, V6 3.4, 4x4, 350k.
  2. Nov 10, 2022 at 5:38 PM
    BuelltonTacoma
    Full tank of gas and no visible issues under the hood or under the truck.
  3. Nov 10, 2022 at 5:39 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    What happens when your crank it?
  4. Nov 10, 2022 at 5:40 PM
    BuelltonTacoma
    Starter turns over but there is zero ignition.
  5. Nov 10, 2022 at 5:42 PM
    shankyjones
    shankyjones Well-Known Member
    Richard
    Marina CA
    2003 Brown Tacoma Prerunner V6 3.4L TRD
    Maybe a lose ground?
  6. Nov 10, 2022 at 5:51 PM
    BuelltonTacoma
    It does feel like that could be it. The battery ground is ok, the two on the drivers side connected to the plenum are ok also. Still looking around, not sure what others there are to check.
  7. Nov 10, 2022 at 5:54 PM
    shankyjones
    Richard
    Marina CA
    There should be one connected to the block as well. I say this because mine was lose after a valve cover gasket job and the ground was lose. Tightened it and did the trick
  8. Nov 10, 2022 at 5:55 PM
    shankyjones
    Richard
    Marina CA
    buuuuut, if you are not getting any spark...hmmmm...battery terminals are clean? no corrosion?
  9. Nov 10, 2022 at 5:57 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Check the am1 and am2 fuse under the hood...
  10. Nov 10, 2022 at 5:58 PM
    O'Silver_Taco
    MD
    My truck would start and run.....for a few miles.....
    and then pop the am2 30amp fuse.....
    If I let cool down for an hour or so.....replace 30amp fuse
    and then on my way......for a few miles.....
    then pop.....
  11. Nov 10, 2022 at 6:00 PM
    BuelltonTacoma
    that ones solid as well, so are the battery terminals.
  12. Nov 10, 2022 at 6:00 PM
    O'Silver_Taco
    MD
    Turns out to be my ignition switch....
    usally dont fail at start up......only hot and under a new load....
    like leaving stop light.....
  13. Nov 10, 2022 at 6:01 PM
    BuelltonTacoma
    funny thing about that AM30 fuse, I just broke the housing trying to pull it out with a finger and a key. So there’s that, although the copper inside appears to be fine.
    wilcam47 likes this.
  14. Nov 10, 2022 at 6:05 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Do you hear the fuel pump whine when you turn the key on.
  15. Nov 10, 2022 at 6:07 PM
    shankyjones
    Richard
    Marina CA
    Diablo, I was thinking the same. But with no spark, fuel doesn't seem to be the issue
  16. Nov 10, 2022 at 6:08 PM
    O'Silver_Taco
    MD
    Ignition system on these are stupid simple too...
    am2 fuse to ignition switch to neutral switch to coils......
    I believe am1 is what powers fuel pump and everthing else.....
  17. Nov 10, 2022 at 6:10 PM
    O'Silver_Taco
    MD
    You can check for fuel flow by popping off fuel press regulator return hose and cranking ......
    gonna throw a lot of gas if good .......careful.....
    1997tacomav6 likes this.
  18. Nov 10, 2022 at 6:11 PM
    02hilux
    Planet: EARTH
    Timing belt snapped I bet. Or check your 120amp ALT fuse in the engine bay.
    koditten likes this.
  19. Nov 10, 2022 at 6:12 PM
    BuelltonTacoma
    Hard to say. It’s turning over, just not firing. That’s all I can hear.
  20. Nov 10, 2022 at 6:13 PM
    BuelltonTacoma
    hopefully not, the TB is only 30k old.
