Broke driver side rear window?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Phillip11625, Jul 2, 2021.
  1. Jul 2, 2021 at 5:34 AM
    Phillip11625
    Phillip11625 [OP] Member
    Phillip
    21 White TRD OR
    3” level, 285/70/17, 17x9 fuel vectors
    Well I went to roll my window down and it broke. I’ve searched like hell and this seems to be a rare issue. Anyone else experienced this? It will roll down about half way and stops, when I roll it back up it pops like hell.
  2. Jul 2, 2021 at 5:39 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Sounds like one of the plastic bits inside the motor is broken. You might be able to pull up on the window and use the button to get it up for now. If you get an aftermarket window regulator make sure it's lifetime warranty. I've never had good luck with the chinesium ones.
    Tacospike and Chew like this.
  3. Jul 2, 2021 at 9:29 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    Its a 2021 that would be back at the dealer vs. me fucking with it.
    513Mugsy likes this.
  4. Jul 2, 2021 at 9:30 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Yeah fair enough. Didn't notice that.
    Tacospike likes this.
  5. Jul 2, 2021 at 3:53 PM
    Phillip11625
    Phillip
    21 White TRD OR
    Yea I scheduled a appointment at the dealer for next week but now the damn thing works perfect. It popped, snapped and you could literally see the panel move as it tried to roll the window up. Now it’s working flawlessly like it never happened.
  6. Jul 2, 2021 at 4:33 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Take it in anyway,it wont keep working.
  7. Jul 2, 2021 at 4:50 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    Honolulu, Hawaii
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    this happened to me once. My front passenger window stopped rolling down and then it magically started working again the next day.
    edit: it was like 20f degrees and it rained the night before
  8. Jul 2, 2021 at 4:52 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Sounds like your worm gear sprocket bushing popped.
  9. Jul 2, 2021 at 5:02 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Either one of the small bolts that hold the regulator to the glass came loose/fell off or the plastic tab broke off of the glass.
    If the tab broke off, the glass would have to be replaced. If the bolt is off/loose, it would have to be installed/tightened with some blue Loctite.
  10. Jul 2, 2021 at 5:05 PM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    Put a new window regulator/motor in it and you’re good. Stupid simple. Just put the window all the way up and tape it so when you remove the arms it doesn’t fall down
  11. Jul 2, 2021 at 5:06 PM
    rtilton12
    Robert
    Texas
    Dealer would probably charge you 2 hours labor and have it done it 30 mins
  12. Jul 2, 2021 at 7:56 PM
    lynlan1819
    Tacoma
    Lifted
    His truck should be under full warranty still.
    Skydvrr likes this.
