Broke my alternator mudding, advice anyone?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeeRadd, Jul 16, 2012.
  1. Jul 16, 2012 at 12:20 AM
    BeeRadd
    BeeRadd [OP] Bought not built.
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    Hey Guys,
    Real sad that this happened but today I went mudding (2nd time in this area and 3rd all together) and Im about 98% sure I broke my alternator.
    Battery light came on a little bit after the mudding and before wheeling around the desert. Got home, washed the hole engine bay out and started noticing the turnover of the engine getting slower and slower each time I started.
    Went to auto zone and had it checked, battery was at 11.6v and the same while running, needless to say the alternator was not running.
    Bought an electrical parts cleaner and hosed down the alternator, let it sit for about an hour, went back to auto zone and retested with the same results.
    Truck couldn't start after that so I got the battery charged by them for free.
    I'm pretty sad because this is the only real problem I've had with my taco and disappointed that I kind of let it happen because ever since I got it, I've been pushing her harder and harder.
    Well this weekend Im supposed to go on a road trip back home (12 hours from el paso to cali) and I don't think Im gonna make it unless I get this fixed.
    To add onto that Im pretty low on cash, I'll be dipping into the CC.
    I need advice on what to do here.
    I tried checking the positive connection on the alternator with no luck. The only thing I can think of doing is taking the truck apart asap, pulling out the alternator, cleaning it up and getting it checked at auto zone for functionality.
    IF that doesn't work I need to have a back up plan already in order so I'm open to any suggestions. Thanks for your time, Taco family.
    -BeeRadd
  2. Jul 16, 2012 at 12:40 AM
    BeeRadd
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    BUMP, I need help.
  3. Jul 16, 2012 at 12:47 AM
    TRDGRL
    TRDGRL My Toys.....
    TRDGRL
    RainForestVille, Honolulu, Hawaii
    '11 BLK Tacoma PreRunner TRD SR5 Access Cab
    See Signature.....
    If something went wrong with the alternator you wouldn't be able to start the truck at all.....:p Maybe something else is loose.....:confused: Take it to a auto repair shop and have them look at it before you go any further.....:rolleyes:
  4. Jul 16, 2012 at 12:48 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    If your battery isn't sealed you can check the electrolyte in each cell and make sure they are full (to the bottom of the plastic top). It it's sealed disregard. Otherwise you can do they following.
    CHEAP WAY: If you have a multimeter check the battery with the truck running and with it off and see if the voltage increases with the truck on, means your alternator is working. Secondly they sell "alternator testers" at Harbor Freight and maybe autoparts stores, whether they work or not...couldn't tell you.
    MORE COSTLY WAY: Take it to a mechanic that can hook it up to a tester meant to check your alternator and load test your battery.
  5. Jul 16, 2012 at 12:58 AM
    BeeRadd
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    This is correct ^
    They checked it at auto zone and the voltage was the same when running as not. As I started it up more it got slower and eventually died completely (consider I had done about 2 hours worth of wheeling with that light on)
    I got it recharged so I would have enough juice to make it back home.
  6. Jul 16, 2012 at 2:13 AM
    BrentPaucke
    BrentPaucke Love Your Leisure
    brent
    Central Pennsylvania
    2007 sr5
    arb bumper blacked out tail lights camper shell hella 500 grill lights cb radio custom black dee zee tool book bhlm pioneer deck OME 3 inch dakar leafs URD stage 4 clutch aluminum fly wheel
    get a bigger alternator .... and get some skids
  7. Jul 16, 2012 at 2:37 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    I had a similar problem with the alternator on my Mustang GT a few years back after push starting it a few times because I left my lights on.
    Pulled the alternator, took it to an electrical shop and they told me the voltage regulator was blown. This is just a chip that's part of the alternator on the outside that usually houses the brush holder as well. They said they can replace the voltage regulator for $100 IIRC. They did so, and I had no problems whatsoever after that. Used the same alternator I had in the car and it ran at full voltage with no problems until the day I sold it a year later.
    I'm not sure if our alternators are built the same way, but it could be a place to start. I can see the VR getting short circuited in the mud.
  8. Jul 16, 2012 at 5:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    x2
  9. Jul 16, 2012 at 6:20 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Buck up and get an alternator.
    If you are going on a road trip and have the radio on, a/c on and use any lights you will toast your battery in no time at all. Then you might end up needing a new batt also.
    Last time I had alt problems the battery did not last more than an hour.
  10. Jul 16, 2012 at 6:24 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Which alternator you have ? Denso (tow package) or that other junk?
    If you have Denso, take a part and just clean it well. Most likely you have dirt on brushes and one of them is stuck.
  11. Jul 16, 2012 at 6:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If/when you get your new alternator, protect it when mudding as best you can using something like dielectric grease or, according to the rep, Fluid Film. Neither will be miracle workers but it's better than nothing!
  12. Jul 16, 2012 at 6:31 AM
    BlueT
    NorthEast
    I would rather get one from junkyard and rebuild it. Al lit takes is new set of bearings and brushes plus few seals.
  13. Jul 16, 2012 at 9:24 AM
    BeeRadd
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    Okay I tried running the truck today and disconnecting the battery to see if the alternator is putting out ANYTHING.
    Nope, nothing. She's shot!
    SO
    Due to my lack of time to go looking around for old ones at a junkyard or taking it off, waiting for it to be cleaned I'm going to order this one off of AUTOZONE.com
    http://www.autozone.com/autozone/pa...scr6Z93xme?itemIdentifier=955082_191610_4449_
    I have the towing package and that one says it comes with it but my trucks voltage used to read about 14 when running, will this still bring me there even though it says it only does 12?
    I'm gonna take the truck to the shop and remove the alternator/get it cleaned by a friend in the meantime and then when I come to pick up the alternator I'll have the old one checked to see if it's functional again. If it is then I'll simply return it to the store, If it isn't then I'll sell that one to the store for the core charge or whatever it's called. I'll let you guys know how it goes.
  14. Jul 16, 2012 at 9:29 AM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    dont go mudding
    and just get the autozone one and install it and call it a day. its what i did after a year and a half of oil leaking on to it finally drestroyed it
  15. Jul 16, 2012 at 9:31 AM
    BeeRadd
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    BTW, can anyone tell me what the difference is between all these?
    I see "w/towing package" w/out, etc. but they are pretty damn cheap, oem, and possibly better? Anybody know If I could possibly score a better alternator on here?
  16. Jul 16, 2012 at 9:40 AM
    BlueT
    NorthEast
    Do you have towing package on your truck ?
  17. Jul 16, 2012 at 9:40 AM
    BeeRadd
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    Oh yeah absolutely, charges faster and can handle more. I will be getting the tow package one already since I have it. Kind of strange though that the towing package is slightly cheaper than some of the non....
  18. Jul 16, 2012 at 9:42 AM
    BeeRadd
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    I know now that I shouldn't. It's just too much of a hassle to clean and I can't observe parts on my truck that may be breaking. Unfortunately, it IS rather fun and rewarding to see pics and the truck after...
  19. Jul 16, 2012 at 1:44 PM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    X2. Be sensible in the mud, or just stay out. Or....deal with the consequences.
  20. Jul 16, 2012 at 3:32 PM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Great pic!
