Broke my engine coil bolt!
Discussion in '1st Gen. Tacomas (1995-2004)' started by WillTheThrill, Sep 15, 2014.
  1. Sep 15, 2014 at 5:42 PM
    WillTheThrill
    WillTheThrill [OP] New Member
    Hi everyone, I am new posting here.
    I was just changing my spark plugs in my 2003 Tacoma V6. I was putting the first engine coil back on, and BROKE the bolt. Thank God I was able to get the broken half out of the engine, but I have no clue where I can find a replacement bolt. Any ideas ? It's a 10mm bolt.
    Thanks!
  2. Sep 15, 2014 at 5:48 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Any decent hardware store should have them. I'd buy stainless ones (so it won't rust and looks pretty for a long time)
    wilcam47 and TheCookieMonster like this.
  3. Sep 15, 2014 at 6:04 PM
    WillTheThrill
    Okay, I'll check out Home Depot tomorrow.
    I tightened that little bastard to 69 FOOT pounds of torque instead of inch pounds haha.
  4. Sep 15, 2014 at 6:50 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    you can get it at any auto parts store, too. BTW-- don't confuse the head size (10mm) with the bolt size. if a bot has a 10mm head, then it's probably a 6mm bolt. take one of the others in with you to make sure you get the right thread pitch, too.
  5. Sep 18, 2014 at 2:16 PM
    WillTheThrill
    They only cost 1 dollar at home depot. It was M6-1.0x20mm bolts. Thanks for the help guys!
  6. Apr 23, 2017 at 7:27 AM
    Sonam
    Sonam Active Member
    2002 Tacoma Xtracab SR5 4WD
    Glad I found this post, because I did this exact thing. Only difference I would add is that for my 2.7L 4cyl I had to replace the bolt with the same measurements you have here, except I had to use 25mm instead of 20mm length. The 20mm is the measurement of the stock bolt, but when I bought a new 20mm, the threads would not hold. 25mm bolt was perfect. Hope this helps someone in the future...
    TheCookieMonster and ThunderOne like this.
