Broke plastic filter housing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacosauro, Nov 3, 2024.
  1. Nov 4, 2024 at 12:15 PM
    #41
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    My composite is my back-up. lol
    I'm glad I got my aluminum almost 2 years ago...I waited to install it but eventually made the switch.
    IronratPR and Chew[QUOTED] like this.
  2. Nov 4, 2024 at 1:10 PM
    #42
    Max8
    Max8 Thinking Outside The Box until they close the lid
    23 SR5 DCLB stock
    2012 ARE DCU contractor cap, Transmission aftercooler kit (Iconic Fabrication & Hayden 698), Bed Stiffeners (Kwikfab LLC), Firestone airbag leaf springs, wye connector and pressure gauge, Tailgate security mod (mfgr. by Christian06 on TW), OEM mud flaps, OEM tailgate electronic lock, Tow-Pro Elite Electric Brake Controller, Anytime Backup Camera hardwired 42 ft to camper, RCI Alum. Skid plates & cat covers, 2WD LO mod (BB Tuning), Fumoto oil drain, ECT Always-On Mod (hardness by Funman1steve), 6awg DC DC tow charger wiring, inline 60 amp breakers & battery terminals, Kill switch, KJTO driver side grab handle, Hood hold open gas struts, Scangauge III, Seat Covers (Seat Covers Unlimited... wearing poorly),
    Housing cap is excessively tight on plastic housing three times now. Square drive extension fitted into cap spun the whole plastic assembly and i needed huge channellocks and extra hands above cbi skid plate to separate cap from plastic body.
    Am wiping all mating surfaces clean, prelubing seated gaskets, hand tightening both items not wrenching them down. Put cap on gently this time. Are others having this issue?
    90% towing with oil Temps consistently 194 to 196 degrees. Am I running hot and baking gasket?
    20k did seventh change to date while on the off grid farm. Fumoto and motivix made it super clean and painless. Lots of towing through mountains.
  3. Nov 4, 2024 at 1:13 PM
    #43
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    You will probably melt the plastic housing if the o-ring is being baked.
  4. Nov 4, 2024 at 1:14 PM
    #44
    Max8
    23 SR5 DCLB stock
    Yep. Believe 194 is a normal temperature?
  5. Nov 4, 2024 at 3:25 PM
    #45
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
  6. Nov 13, 2024 at 4:35 PM
    #46
    MITaco6MT
    MITaco6MT Member
    2023 Barcelona Red DCSB Sport 6MT
    I ordered the aluminum version and it came in so it's definitely available.
    MGMDesertTaco, Max8 and TacoTime55 like this.
  7. Nov 14, 2024 at 2:25 PM
    #47
    Tacosauro
    Tacosauro [OP] Well-Known Member
    23 SR5 V6 & 24 TRD OR
    roof rack
    Oh well, I am not surprised he just said " we dont make them anymore ". Considering he told me he didnt know anything about filters , engines or cars in general, while working in Toyota parts. I might just get it i guess and have it around for next oil change.
  8. Nov 14, 2024 at 5:21 PM
    #48
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I wouldn't deal with that guy.
    It ask for someone else or go somewhere else.
    They're still made by Toyota.
  9. Nov 14, 2024 at 11:37 PM
    #49
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    is the tube the same length?
    kahanabob and TacoTime55 like this.
  10. Nov 15, 2024 at 4:03 AM
    #50
    Houstoner
    Houstoner Well-Known Member
    Daniel
    2020 DCSB SR V6 4WD
    OldSchlPunk[QUOTED] likes this.
  11. Nov 15, 2024 at 8:05 AM
    #51
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    I did not swap out the center tube. The filter sits the same height--works same as OEM.
  12. Nov 15, 2024 at 12:34 PM
    #52
    RIX TUX
    i have seen some of the metal ones that the tube was longer, i think its some kind of pressure valve
    TacoTime55[QUOTED] likes this.
  13. Nov 15, 2024 at 3:11 PM
    #53
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    It is slightly longer/taller but when I saw how the filter covered it, I felt better knowing the extra length wasn't substantial.
    RIX TUX[QUOTED] likes this.
  14. Nov 16, 2024 at 3:05 AM
    #54
    ImpactTaco
    ImpactTaco New Member
    Gator Country
    2021 OR 4x4
    As others have said use a breaker bar and not an impact. I’ve been working on my own cars last 10+ years and always torqued to the “that feels about right” spec. This truck is the first one I’ve ever had with a plastic reusable oil filter housing. I broke the housing on the 3rd oil Change and had to get another from the stealership. The oil filter calls for a 18-ft spec on third gens. It’s really not much. I would highly suggest getting a new housing, torque wrench and an oil filter wrench and never let those “free oil changes” get you again.
    Tacosauro[OP] likes this.
  15. Nov 16, 2024 at 12:34 PM
    #55
    RIX TUX
    Where did it break
  16. Nov 25, 2024 at 7:09 PM
    #56
    apotter
    apotter Well-Known Member
    Southern Maine
    2023 Tacoma
    Good golly Toyota! Owned a ‘82 Hilux, ‘83 Hilux, ‘98 Tacoma, ‘09 Tacoma, ‘13 Tacoma, and now this ‘23 taco - never has an oil change ever been this involved. Can’t believe on this ‘23 you have to drop the skid plate and rebuild the filter assembly. First time on this truck changing the oil myself, purchased the special filter wrench, tried to take it off with a ratchet and snapped one of the tabs. Grabbed the 1/2” impact and that was the only way to get it off (no side loading). Put it back on using the ratchet, brought it to snug, one extra (light) tug, and shattered all the tabs. No where close to torque specs printed on in the part. I’m no Hercules ladies and gentlemen. Truck only has 10k miles.
    Does it just fall apart going down the road on the ‘24 with their new and “improved” engineering methods?!
    this is normal maintenance item
    :facepalm:
    Just ordered the aluminum replacement - I miss the standard metal filters in a convenient location
    (Rant complete :thumbsup:)
  17. Nov 25, 2024 at 7:14 PM
    #57
    RichochetRabbit
    Motivx adapter that grips the housing at the strongest point: https://www.motivxtools.com
    Get 2 ft breaker bar that does NOT impact the housing badly.
  18. Nov 25, 2024 at 7:17 PM
    #58
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    It sounds like you need one of these filter wrenches. I’ve been using this wrench every 5K intervals with absolutely no problems.
    Motivx Tools Oil Filter Wrench for Toyota Camry, Tundra, Tacoma, 4Runner, RAV4 and More - 64mm 14 Flute Precision CNC Machined Aluminum Oil Filter Removal Tool https://www.amazon.com/dp/B00XTAGHU0
  19. Nov 25, 2024 at 7:20 PM
    #59
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    You beat me to it.
  20. Nov 25, 2024 at 7:29 PM
    #60
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
