Broke the Adjusting Bolt on the tension pulley for my power steering belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bluethunder90, Jul 30, 2017.
  1. Jul 30, 2017 at 8:26 PM
    Bluethunder90
    Bluethunder90 [OP] Active Member
    2001 Tacoma
    Hello All,
    I have a question from a non-mechanic. I just changed my power steering belt, and in the process of installing the new one, I broke the adjusting bolt on the tension pulley; it split the bolt right in two with half of it coming off in my hand, and the other half remaining in the block. My question is; is it safe to drive, or do I need to have it towed somewhere to get tapped out and the bolt replaced? I know I'm going to have to get it tapped out, but I wonder about driving it? Will the belt loosen and slip off?
    I know it may be a noob question, but my mechanical skills are 0 to non-existing so I appreciate all the help I can get.
  2. Jul 30, 2017 at 9:24 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    DONT DRIVE IT. Why take the risk? Spend the cash to have it towed, I wouldn't drive it.
  3. Jul 30, 2017 at 10:35 PM
    Bluethunder90
    2001 Tacoma
    1. I don't have the cash to spend
    2. I have to get to work in the morning. I may not have a choice.....
  4. Jul 31, 2017 at 1:18 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Take the belt off if you need to drive it.
    Worse case the belt comes off takes out the other ones now you do have a problem
    OneWheelPeel likes this.
  5. Jul 31, 2017 at 1:31 AM
    Bluethunder90
    2001 Tacoma
    How difficult would it be to drive it with out the Power Steering belt?
  6. Jul 31, 2017 at 4:43 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Unless you have big tires not too bad. I drive an 81 pickup w/o ps no problem except for parallel parking w/ 33's.
  7. Jul 31, 2017 at 7:12 AM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    For a truck that was designed to be driven with power steering it won't be super fun, but doable in a pinch. It won't be terribly safe as it'll feel like you're steering a cruise ship. Get it fixed asap.
    You said adjustment screw, but that one doesn't go into the block. If it is the adjustment screw and you can grab the stuck part of the bolt with a vice grips, soak the bolt in pb blaster or a 50/50 mix of acetone and ATF overnight. Spray it again in the morning, then try to slowly get it out later that evening.
    If the bolt you're talking about is going into the block, and there's nothing left to grab the bolt will likely need to be drilled out.
  8. Jul 31, 2017 at 7:37 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Steering is only heavy at slow speeds when you're parking or taking off from a stop sign. Once you're moving there won't be much of a difference.
  9. Jul 31, 2017 at 8:30 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Just saw this video tonight - don't know if this would help you. It's a pretty cool tool for guys that can't have a cutting torch around the house / apartment:
  10. Aug 4, 2017 at 12:56 PM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    If you were installing the bolt when it broke, it won't be frozen in place. Take off the power steering brackets around the bolt so you can get to it. As stated in post #7 hit it with PB blaster or other penetrant. Try grabbing it with vise grips.
  11. Aug 4, 2017 at 2:42 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I had a 87 4Runner that the Pump started making noise I took the belt off drove it till it got parked over 15,000 miles to do a head gasket
    It still sits
  12. Aug 4, 2017 at 3:32 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I broke my adjuster bolt, I just set the tension with a pry bar and tightened the mounting bolts down real tight. Has been fine for 2yrs now.
    Saw something about the block, pics of the bolt? I broke the bolt that sets the tension on the pully.
